I have just ordered this Lance Head. Is the label "Indo Persian" consistent to its origin ? Would there be a more specific provenance ?
Blade 8" Socket 9". Its looks a bit old. Any coments would be so much welcome. fernando |
I would place it as Qajar period, Persia.
Thank you so much, Battara.
Would you say 19th century? |
Yes, that is when I believe the Qajar revival occured.
Thanks again
After Battara's observation, i did some web search under his appointed area and eventually found out the etching on the blade is an inscription in Farsi, entangled with a Snake.
I have just received it, and now i need further kind help. Two vital questions remain unclear to me: Would it be a Cavalry ( Persian Lancers ) or an Infantry pattern? It measures 45 cms. ( 18" ), blade and socket + - equivalent. The other problem is i don't get to know the material of its inexistant haft, as i allways strugle to imagine an entire weapon's aspect. I have read that it could either be cane or wood, in the period context, but i can't judge for myself. I wonder if the type of socket is decisive for such conclusion. This one has a narrow entry ( 20 m/ms= 3/4" ) and a much pronounced tapering ... to 10 m/m= 5/16" at the end. This would require a spicky sharpened haft tip; maybe cane, at least hollow cane, would crack ... But above all and, for my layman's surprise, there isn't any hole in the socket for the haft fixation ! How come ? Were sometimes Spear hafts "glued" or "swallen" inside sockets ? would that be enough ? Could any of the Forum Members give some lightning in these subjects? Thanks a lot in advance. |
I would guess that any fixation short of socketing would be too weak to allow this lance to be used for any hard contact purpose. Therefore... decorative?
I could agree with Ariel's assesment of this piece ; possibly not due to the reasons he has given but to this detail which strikes me as fairly lightweight for combat use .
I think that in the Qajar period there were many ceremonial and parade pieces used and certainly made. I would guess that this is one of them.
I am much obliged and fully enlightened with the sum of your three postings.
The blade is also too thin for impact, so i notice ... now. I will file its identity as a parade lance head, late Qajar period ( Nasir ed-din ? ). In this case its haft, if there ever were one, would probably be a short type wood rod, as it should sufise for ceremonial evolutions, probably infantry. Just a pitty i fancy more the collecting of older and efective weapons, although to my eyes i find this still an elegant and meaningfull blade. The socket is fully etched with micro arabesques, probably lettering familiar with the alegories to the Shah on the blade. The brass seaming is perfect and almost invisible. All in all, i like it. Thank you again fernando Last edited by fernando; 8th June 2006 at 07:48 PM. |
