#61 |
Naaa, they went south for warmer weather..
#62 | |
Here the BIOGRAPHY of a great arms specialist. PS I have now sen t e-mail to the present museum curator. . Last edited by fernando; 10th February 2021 at 12:57 PM. |
#63 | |
#64 |
Interesting discussion on this pistol. Here is one that I own. The stock finish is almost completely worn off. Looks like someone was going to refinish it but never completed. But there is no evidence of later sanding. Also, it appears the lock and barrel were chemically cleaned sometime in the past.
I've always known this pistol by it's generic name of Belgium Navel Pistol, in use from about 1810 to 1835. I recall reading somewhere that this pistol was made by the thousands and sold everywhere. That Bannerman's early catalog had surplus still for sale probably attests to the quantity made. Interesting the lack of a ramrod provision. My guess is that a separate loading rod suspended from a leather cord around the neck, was the thinking behind the pistol's design. But I may be wrong in that I've never seen what you might call a "European" type standardized loading rod for these pistols. Much like most of the pistols carried by troops in the Ottoman Empire. Combined with the use of pre-formed paper cartridges, re-loading is very quick. I can actually confirm this from a trial I did firing my pistol using this method. The separate rod around the neck is even more convenient than the later captured type ramrod. On the other hand, as mentioned above, all of these pistols aboard a ship may have been loaded at the same time and then fired once during a ship-to-ship battle, and then used as a club or parrying piece. The pistol is very robustly made. The front barrel wedge (versus a pin) is especially convenient. Just about every example I've seen is still, or can be easily returned to shooting condition today. Rick |
#65 |
Woops. Forgot the photos.....
#66 |
Is that some mark, Rick ?
#67 |
Hi Fernando
Yes, I seem to recall it is. But can't remember. Been a while since I've handled/fired it. I'll check it out when I get home tonight. Rick |
#68 |
Hi Rick,
Any chance of dismounting the barrel on your pistol and photographing any marks in closeup plus of course the marks Fernando has already mentioned. My Regards, Norman. |
#69 |
and here is one with some marks
#70 |
another one with a tugra on its barrel
#71 |
and the next one with the mark of the Isfahan arsenal on its lockplate
#72 |
and last a same pistol with an unknown signature at its lockplate - could eventually be a year?
#73 | |
#74 |
So Udo was faster ... but i've got the ACHERON
#75 |
Ahh, the Achercon! If only it were not spurious!
I finally took the barrel off of mine, but the only marking on it was 'HK'... |
#76 | |
You are right, such correct information is not always easy to find, given the scope and complexity of the subject. It has been five months since i took office and i still 'often swim'. Having said that, i highly recommend a very reliable and well done site where you should find everything you need. They have also just published an encyclopedia in six volumes on the Liège armory that i have already ordered. This site is HERE. Hoping that this site will meet your expectations, please receive, Mr. Viana, the expression of my warmest regards. Löic Servais Conservator |
#77 | |
![]() https://en.wikipedia.org/wiki/HMS_Acheron |
#78 |
A bit of fantasy hurts no one. Here is the paddle sloop Archeron version, launched in 1838. Who knows the captain already had his Liege pistol and had its barrel engraved when he was assigned to this elegant vessel
#79 | |
#80 | |
Reason why i took a shot at the paddler (post #78 ). |
#81 | |
One never knows; eh? The first Acheron appears to have been a lowly Bomb Ketch according to the list I consulted. IIRC she was in the Royal Navy service from 1803 to 1805 when she was captured in the Med by the French. A short career and one that predates the pistol's production date. Still it would be a nice acquisition for a fan of the Movie. |
#82 | |
No, that's the threaded hole for the mainspring screw. It's been a while. So I took the barrel and lock off per Norman's request. I'll post what I found with photos below. Rick |
#83 |
OK. First the lock:
There are no markings on the outside of the lock. Here is what I found on the inside: In the center of the lock plate are the letters: FD FD gd L The front inside of the lock plate has four intentional hash marks. And a series of small, round punch marks on the inside of the hammer and pan, as well as the pan cover of the frizzen. Maybe just assembly matching. The first F could be something different as it's partially covered by the mainspring. (I guess I could take the mainspring off) Rick |
#84 |
And now the barrel:
On the bottom of the breech plug tang is the number 42. On the left, rear side of the barrel, at the breech are two stamped letters I can't make out. But the ELC over the star inside the oval is there. On the bottom of the barrel, about 2 inches from the breech is a similar mark posted by Corado above. Below that mark it looks like there are two stamped, separated letters I can't make out. Rick |
#85 |
Hi Rick,
Many thanks for dismounting your pistol, unfortunately I am still in the dark re the various and differing stamps on this type of pistol. I am corresponding with someone in Belgium to try and get some more definitive information on the marks and of course will post the results if and when. Thanks again. My Regards, Norman. |
#86 | |
#87 | |
Best Fernando |
#88 | |
Hi Fernando, Your link takes me to the same place as the link in my post no 35. I've been through the site and although it has good info it is not complete so I am still searching. Thanks anyway. My Regards, Norman. |
#89 |
So bad; no wonder the actual curator is new on the job and didn't properly deal with my specific question; marks and their support text
#90 |
Rick,
The mark in your last photo of the barrel is the Belgian Provincial proof mark. After 1968, this mark is for Optional Provincial proof. Of course your pistol pre-dates this! (EL in script.) This mark can be seen clearly in my post # 53 on previous page. |
