This is supposed to be a sperm whale tooth. Purchased from a seller who informed us that it came from tawi-tawi, from way way back. My plan, if indeed this is sperm whale tooth, is to use it as a pommel to an old barung or kris (which has no pommel). I've done some reading and this specimen conforms (in my unexpert opinion) to ivory. The ff are some things I have read on ivory's characteristics: a) ivory always has parallel grain, like rings on a tree or crosshatch pattern called Schreger lines. On closer inspection, this tooth has both parallel and crosshatch patters. b) in contrast to bone, ivory has a smooth feel. Thanks in advance for you inputs. Regards Yves |
Please show a pic of the root-hole. This will make it a little bit more clear.
Sperm whale real and fake/resin
Walrus real and fake/resin
Many thanks for the initial info. Here are some more pics. Thanks in advace. Yves |
Very difficult to judge from photos alone, but from what I see, it looks like resin.
You can easily test it ether trying to burn a tiny piece of it or by simply polishing it and you'll see how it behaves. If it melts and smells like plastic is resin, if it smells like "dentist" it is ivory. |
#7 | |
#8 | |
Can you expound on the statement 'how it behaves'? what would be best to use for polishing? Thanks Yves |
#9 | |
How it behaves: if it melts is plastic; if it smells like "dentist" is ivory.
For polishing you can use sandpaper, 600-800 grit and give it a few rapid rubs. If it is ivory will smell like "dentist." For final shiny polish you need to go to higher grit (3000-7000). Quote:
I do not advise polishing/fire testing any finished product. For a raw piece of material is another story. Last edited by mariusgmioc; 13th October 2020 at 08:49 PM. |
#10 | |
#11 | |
#12 | |
#13 | |
Did some 'polishing'- and it smells like burned 'enamel.' must be the 'dentist' smell. I did contact an expert on this things. Sent her some pictures. Initially, there's the presence of Schreger lines + crosshatch pattern on the tooth. And I was advised to bring the item to her for a visual verification. Thanks and regards, Yves |
Hi again,
forgot to include another test which I did (upon the instruction of the jeweller). I got a needle, had it red hot on the fire and tried to pierce the tooth. - and voila, it did not went into the tooth. Best Yves |
The geometry of the cracks is consistent with ivory.
From all I know there are some ivorine resins that crack, but without round/circular cracks. Round/circular cracks are specific to ivory as they follow the growth rings. |
#16 | |
#17 | |
Disagree again with you, soory! The sperm whale tooth look real to my eyes but agree with you that's difficult to judge from a picture alone.Regards, Detlef |
#18 | |
Sperm whale tooth shows no Schreger lines so far I know, only elephant ivory shows this lines. Regards, Detlef |
#19 | |
#20 | |
#21 | |
Thanks very much for the assessment! |
#22 |
Here are other samples, from another friend's collection. The one with the reddish hilt intrigues me, as it's a standout from the other ivory-looking samples. One of the hilts is also unique, having a string of hawk bells tied from the base of the pommel up to the gangya as a makeshift guard.
TIA for anyone who'll assess! Much appreciated. |
#23 |
Xasterix, the Maguindanao pommel looks like aged Mother-of-Pearl in silver frames to me. I have seen it darken like this.
The other pommels are ivory. The red coloration is the result of the presence of sulfur which oxidizes the ivory from red to a dark reddish brown or a honey-is brown. I find the T'boli bells interesting. |
#24 | |
#25 |
A non-destructive test is to use an ultra-violet light (I bought one of these fairly cheaply at a local shop that sells electronics). Ivory has a distinctive blue sheen, which resin does not have: I recommend a bit of practice, shining the lamp on plastic, bone, etc. so you can see the effect.
Incidentally, horn shines light brown when lit by ultra-violet light. Which is a useful test if you can't decide whether something is made from horn or wood. |
#26 |
You should definitely take Sajen's word over mine on everything!
#27 | |
That is a really interesting piece. I don't think I've ever seen anything like it. |
#28 |
This again proves a lot of trade between Philippine groups. Fascinating isn't it?
#29 |
Hello everyone...would like to ask your opinions on this pommel. I'm still in the process of restoring the rest of the kris, but I suspect this is ivory. Would appreciate your inputs, thanks!
#30 |
It's clearly Elephant ivory. Very nice patina.
