Sharing some of my grails. I'm into collecting moro swords.
If anyone could share more regarding these grails will be much appreciated. |
#2 | |
Gavin |
I didn't noticed that images where not uploaded due to its size.. Will repost soon..
Here it is... Probably the photos weren't been uploaded in the original post due to size issues.
Hello Hefezola:
Thanks for sharing your kris and barung. The kris appears to be a broad-bladed example from the Sulu Archipelago, dating from mid-20th C I would think. It is missing its other stirrup, or it is a very unusual single stirrup example with the stirrup on the back side of the blade (I have never seen that before, so I think it is probably missing the other one). The hilt is a horse hoof style commonly found on mid-20th C examples. The barung are all Sulu as well (probably Tausug) and likely date from the 20th C. One is missing part of its kakatua pommel, but it is 20th C too. Each of your swords has been cleaned very well and I like the subtle etching that you have given them--the patterns are clear. Did you use nitrol or acetic acid? Ian |
Very pretty pieces, and as Ian says, showing a lot of lovely patterning.
I'm particularly fond of the half-waved kris form (rantai I believe it's called), so I'm envious. |
#7 | |
Thank you for your inputs... Is there in any way I could do for etchibg where patterns and lines come out boldly? |
#8 | |
I think they are fine as they are.
#10 | |
Yep. Just fine etching for me too.
Here are some of my Philippine holy grails:
