Old 1st August 2018, 02:59 PM   #1
Gustav
Default Sikin Panjang - a translation request
Dear All,
if possible I would like to ask some knowledgeable person to translate the cartouche on this one, please.
And a question - the blade of this specimen is becoming slightly broader towards the tip, for about 3,5 mm. I suppose, it isn't much reshaped or resharpened. Have somebody of you noticed something similar on your Sikin?
Many Pamor layers on this one.
Old 1st August 2018, 07:00 PM   #2
Verrrrry!!! nice.
Old 2nd August 2018, 09:42 AM   #3
Gustav
Ariel, thank you very much!
The cartouche once more, in correct orientation.
Old 3rd August 2018, 03:51 AM   #4
Gustav:
Lovely sikin! The folding of the blade is well shown and I like the pattern. As far as widening of the blade towards the tip, I have not seen this before. In my experience, the edge and spine are remarkably parallel until the edge curves to the tip. Others with more experience may have seen a similar blade.
Ian.
Old 4th August 2018, 03:51 AM   #5
Hello Gustav,
The script is unusually long!
I also can't remember having seen these lines to be written on...
I've seen this with some sekin. This blade is fairly broad to begin with...
I'd need to closely study the blade to possibly narrow down on any possible reason.
Typical neat Aceh craftsmanship.
A very nice, complete example with extensively decorated scabbard and gold crowns/inlays, congrats!
Old 4th August 2018, 08:56 AM   #6
Hello Gustav,
very nice sikin panjang! Now I know who bid me out by the auction, it's much nicer as seen on the poor auction picture!
Hopefully someone will be able to translate the script!
Old 4th August 2018, 12:56 PM   #7
Gustav
Ian, Kai, Detlef - thank you very much!
Yes, I had luck this time - blade came out very well, without deep scars (there were two bigger rusted areas where you could expect everything, one on each side). Three members of the upper crown are a bit battered, but there still is the typical red staining.
The blade is 53,2 cm long, 3,7cm broad at handle, 4 cm before it curves to tip. You cannot see it well in pictures (it is almost impossible to take adequate pictures of a longer blade without professional equipment), but in hand I immediately noticed the broadening. The blade looks less stiff.
Actually the broadening towards the tip occurs quite naturally forging out the blade. I also think to have noticed this feature in some pictures of other SP now, but that's mostly a guess work. I suppose, the state of my blade is quite close to original without much reshaping - Kuro is well defined, with clear, crisp borders.
Regarding Pamor, at the moment it seems to me there could be a deliberate difference between common and status SP in number of layers. A good comparison are the blades of ex-Gavin and ex-P.Dekker (and mine).
http://www.swordsantiqueweapons.com/s174_full.html
http://www.mandarinmansion.com/very-...e-tiered-crown
Old 4th August 2018, 02:37 PM   #8
Enlighten me: AFAIK, Indonesian Pamor is just a variety of laminated materiel, not different in principle from a mechanical damascus. However, bright streaks of pamor are formed by nickel, whereas outside of Indonesia the pattern was formed by combining low,- and high-carbon steels.
I have a visual impression of the latter, rather than former.
Old 4th August 2018, 05:41 PM   #9
What I love about this:
1. the tight laminations in the blade
2. the enamel is almost complete
3. the scabbard is present and complete
Old 4th August 2018, 10:04 PM   #10
asomotif
asomotif's Avatar
Same for me. splendid piece.
As for the widening blade.
Same as Kai, I would have to study the blade for a long time to get a grip on this unusual widening pattern.
I will be happy to make some space in my home to study it
Please check other threads about translation to see who was assisting there. some PM may help
Wonderful piece, once more
Old 4th August 2018, 10:54 PM   #11
Email sent already...
Old 4th August 2018, 11:01 PM   #12
Post
Hello Ariel,
Any laminated construction could be legitimately referred to as pamor in Indonesia: It doesn't have to exhibit strong contrast nor is it limited to nickel - iron alloys of different origins tend to be different enough to result in some contrast (the cause could be nickel, carbon, phosphorous, etc. or any number of combinations...).
Old 5th August 2018, 12:52 PM   #13
I've just controlled the two Sikins in my collection, one shows the same feature, at the base it's 38 mm broad, the tip is nearly 40 mm.
Old 5th August 2018, 02:21 PM   #14
Gustav
Willem, thank you!
Detlef, thank you very much for checking your Sikin Panjang!
Very close indeed.
Old 5th August 2018, 03:57 PM   #15
Gustav
Better pictures of the inscription:
Old 5th August 2018, 04:29 PM   #16
Jentayu
Hi Guztav,
While some of the words are quite clear to read, others are hard to decipher. Nevertheless, below are the translation of what was written on your sikin sheath. Hope this helps.
"Ini lah peninggalan (?) Teuku Kalit Mat Said dan yang empunya sikin panjang ini ....dan pada..."
"This is heirloom? of Teuku Kalit (or probably kaluet a province in Aceh?) Mat Said and whom this sikin panjang belongs to ....and on ...(the rest I cant decipher)"
Jentayu is offline   Reply With Quote
Old 5th August 2018, 04:43 PM   #17
CharlesS
CharlesS's Avatar
Exactly as Battara has said! This is one of the most lovely sikins I have seen in some time. Congrats!
Old 5th August 2018, 06:22 PM   #18
Gustav
Jentayu, thank you very much for translation, it's a great help!
A question - could Teuku Kalit be a title, the Dutch spelling being (Teuku) Kali?
"For the administration of justice the Uleebalang avails himself of the sevices of Kali (kadhi - a judge in Islamic law), whom he himself nominates." (Snouck Hurgronje, "The Achechnese")
Like there was Panglima of a Sagi (confederation of districts), a nominal chief of Uleebalangs of these districts, there was also a Kali, which was then the chief Kali of a Sagi. His title was Kali Rabon Jale and he was appointed directly by Sultan.
Above the Kali of Uleebalalang and Kali of Panglima Sagi there was a supreme hereditary judge with a title of Kali Malikon Ade. He initially possibly could apply Hukom as well as Adat law and ideally would be a president of a royal court of justice.
It seems this system certainly wasn't working anymore in 19th cent. (or even earlier) because of great independency of (three) Sagi's and Uleebalangs.
So Kali Malikon Ade was later in fact just a title, which indicated the origin of the position, "Judge of the righteous King"; a master of court ceremonies, to whom a fixed portion of harbour dues was assigned. He became what was called Uleebalang Poteu (Uleebalang of our Lord), equal in rank to the almost independent provincial chiefs, but without territory. The official title of Teuku which he bore points to the complete secularisation of his office.
Finally one of the holders of the title used a weakness of a Panglima Meuseugit Raya (the head of around 24 Kampongs on either side of Aceh river in neighbourhood of the court and principal mosque) and succeeded in gaining control of over half of latter's jurisdiction. Sicnce then Teuku Kali was a chief (Uleebalang) of small (12 Kampongs) but important territory and at the same time, as court dignitary, not without influence in the choice of a successor to the throne.
Charles, thank you very much!
