This one is a bit of a mystery.
A short sword with a blade that seems to have some age--pre-WWII I think--and appears to have been sharpened and used quite a bit. The blade is spear-shaped, with some gradual widening from hilt to tip before tapering to a central point. The back edge is sharpened along its distal half. Both the regular edge and the sharpened part of the back edge have a V-grind. The hilt has a nicely carved pommel that I am having trouble identifying (hopefully someone here will recognize it). There are actually two ferrules on the hilt, a large brass one that partially overlies a smaller one. The sword came with a nondescript wooden sheath in two pieces held together at the moment with elastic bands. Thanks for your thoughts on this one, I would appreciate some help in identifying it. Ian. Dimensions of sword OAL = 23 inches. Last edited by Ian; 5th January 2018 at 05:25 AM. Reason: Added dimensions |
My first thought is a european blade. Maybe broken and reworked into a klewang or pedang.
Nice find. |
For me it's possibly an old klewang blade that has been resized (to change the shape).
The handle is also very old and very worn, but it was modified at its base (because broken?) At the time the sword was mounted in its current state. I have the impression that it is an old klewang that has been restored and modified in a more European way in the first half of the 20th century. |
I agree with Henk, as it appears to be a European blade reworked, or at least made from European monosteel.
Regards, Marius |
For me
it's a Mandau dayak with Pedang hilt
#6 | |
Hi Ian,
I am with Séverin (Athanase) on this one. But it could be that the blade shape is original. This you can proof by a polish and etch since I think as well that the blade is laminated (sorry Marius), I've seen many unusual blade shapes by pedangs. It's for sure not a mandau blade (not concave/convex). Pommel is most probably carved from horn and can be called makara, maybe a little bit reshaped at the top. Regards, Detlef |
Gents,
Thank you one and all! All of your suggestions are most welcome and helpful. It is presently too cold in Minnesota (-20ºC on my patio deck) for me to etch the blade--my wife has banished all etching to be done outside since I inadvertently etched the sink in her laundry. However, I can confirm that close inspection shows a laminated blade.To my eyes this could well be a 19th C. blade originally, but I was being cautious earlier in saying pre-WWII. As far as being European-influenced, that was my thought also given the substantial bite out of the spine of the blade to create a very useful, and sharp, back edge. I think it's possible that this was made for, or used by, a European living in SE Asia. Detlef, thanks for the suggestion that the hilt is a version of a makara. I had not thought of that. The hilt is made from horn and well rubbed over the years of use. None of you esteemed gentleman has suggested an origin different from my "Indonesian (?)" suggestion, so I am assuming that you all agree with that attribution for my sword. Thanks again for all the comments so far. Further suggestions are most welcome. Ian. P.S. I picked this one up about 10-15 years on an online site that is now defunct. It was labeled a Thai dha.
#9 | |||
thank you for confirming. Can you give the thickness of the blade near the handle? Quote:
And here a handle from my own collection.
Thanks for all that information Detlef. Much appreciated!
The width of the blade at the hilt is 3/16 inch or about 0.5 cm. Attached are close up pictures of the carved area. There is definite evidence of a piece missing at the end of the hilt and the defective area has been carved smooth with a small knife that has left tiny "chip" marks. Ian |
#12 | |||
Makara handles are a most interesting study area which normally would require an own thread. I've attached the other makara pommels from my klewangs I've taken already some time ago. The one in up I've shown is from Lombok I think. Here the others like follow: 1. brown horn, pedang from Lombok 2. wood, pedang from Lombok 3. wood, pedang from Sunda 4. black horn, pedang from Sumbawa 5. black horn, pedang from Lombok Regards, Detlef |
