Acquired this recently, appears to be an late 18c-early 19c shell guard hanger/hunting sword, with a double edged 53cm. blade, complete with scabbard. should be with me tomorrow. is it possible it's a naval officers fighting hanger? vendor did not note any markings. it looks remarkably similar to capt. cook's sword listed HERE
Good catch, Wayne. Don't feel jealous of Cook's piece; his is more the swagger type, while yours looks like the real thing
.Just a pity if the scabbard is from a different sword; it looks like having a different curvature, or is it my short sight . You will check if it fits correctly .
hopefully it's just the bendy leather. does appear to be a bit longer than the sword blade tho
. i too hope it fits if not, i have a couple of swords that need scabbards it may fit. might be the sword used to be a bit longer...we all get shorter as we age.anyhow, capt. cook's sword (if he carried one like this) didn't do him much good against a hawaiian. size did matter there. |
#4 | |
always use a scabbard, for safety.
well, it fits
![]() blade is a couple inches into the chape & tight at the top, still a couple inches short if i lay the blade on top. blade is single edged, flat spine,except the last 5 inches, which Are sharp top & bottom. bottom edge is sharp all the way to the guard. no markings. the chape is actually loose (staple is missing) i'll see if i can move it up a bit to better fit the blade. leather needs a bit of softening. |
So you face two versions for future record; either the scabbard belonged in another sword or this very one was shortened ... for whatever reason. One staple missing; easier to dismount the chape and trim a portion of the leather. You just have to check if the 'new' scabbard width fits well into the tappering chape; correct ?
#8 | |
it is a 19. ct. European, probably German, Hunting dagger (deer catcher). If you follow this link, you will see more examples of the same type. https://www.google.de/search?q=hirsc...w=1670&bih=921 If you find something of interest, I will translate it for you. Sometimes they had been used as a side weapon for upper class on the battlefield. Maybe the extremely long bayonets of late 19.ct. are copies of the deer catcher worn in battles. Roland |
#10 | ||
. Quote:
