I've had this about a year, and still don't know for sure if it represents a known style/form of knife. I learned that the script is Arabic, in the Moroccan or Algerian dialect, and approximately reads, "be merciful to the ones around you [neighbors]".
Both sides of the hilt are adorned with metal. The back of the sheath is simple leather. On the reverse from the script is a depiction of an elephant. This is the strongest indication to me it is for a tourist that would view an elephant as exotic. For scale, the squares on the chessboard are 2"x2" So, any feedback on the form, and is it one that represents a legitimate knife style from a particular region? As always, thank you for your insights
Hi Shayde,
I do not recognise the particular type of knife, but the silverwork looks to be Yemeni or South Western Arabian. Nice piece......I like it very much. Others no doubt will comment in due course. Stu |
#3 | |
Can I assume it is actual silver, then? |
#4 | |
Stu |
Yemen was my first guess. I've seen silver work from Afghanistan and regions north of there that seemed similar, to my eye. Generally the stone most often seen from those northern regions is carnelian, though.
The elephant looks to be Indian, but who knows? |
Thank you Bob and Stu.
The elephant does look more Indian than African, but making that distinction presumes a level of artistic accuracy that may not be warranted. I am wondering if the 6-pointed star could provide some clues. I know there is some debate as to why this image appears on blades across cultures. The consensus seems to be it was used as a proofing mark in Europe, and was subsequently copied elsewhere to make lesser blades seem of higher quality. However, it seems to me that any Arabic blade after the 1940s would be unlikely to have this image. Do you think that is a fair claim? Although, the inscription (if my translation is accurate) suggests peaceful coexistence, so that could undermine my own assertion. One more thing, I am attaching an image of what appears to be a coin on the sheath. It is 5-sided, but it may have been cut into that shape. Does this coin help with identifying? |
I'm very much with Stu on this, and this seems to be likely something innovatively fashioned in Yemeni or Hadhramati regions. I would 'guess' low grade silver fabricating this pastiche, recalling other silver repousse hilts from many remounted sayf.
The demonstrably crude inscribed Arabic type script and the six point stars (star of Solomon, an Islamic symbol as well as other) seem intended to intimate a better quality blade. The elephant probably loosely intended to suggest Indian source for blade, as these were highly regarded in Arabia. Most interesting piece from dynamic and intriguing regional circumstances of perhaps 60 or more years ago. The star (of David, or Solomon) was used on British blades as a surround for a proof slug, begun by Wilkinson late 1850s, but contrary to suggestions never had Jewish nor Masonic connotation. It represents varied interpretation of transposed triangles, and was well known in very early Islamic contexts and often to signify quality and or other significant symbolism. Coins are not a good indicator of date nor provenance on swords' elements or mounts as these were often used as decorative and talismanic devices regardless of their monetary value. Many coins such as thalers, pesos, and others were used on hilts as pommel cap decorations etc. |
#8 | |
As always, thank you for your informed feedback I appreciate your (and Stu and Bob's) willingness to take the time to share your thoughts. I collect so that I may learn, and the members of this forum have proven to be great teachers. Best, -Rob Ps- I'm still curious to hear more opinions and learn more about this piece....any pictures of something similar being worn? |
You're most welcome Shayde, and I thank you for the opportunity to see this piece and offer my thoughts, which are of course only my opinion based on many previous experiences with similar items. As you note, the membership here are indeed great teachers, and we always learn together.
I look forward to hearing more from others who are interested and experienced in this field on this interesting item. |
It occurs to me that the leather backing of the scabbard is rather reminiscent of the jambiyyas from Yemen and Oman, which may be another pointer toward origin.
I speak from the very depths of lack of knowledge, of course. |
I think the "coin" is dated " .368", if my eyes are still what they used to be ???? years ago:-)
If so, - 1948-1949. I think it fits well with the crispiness of incisions on the blade. But Jim is correct: the "coin" could have been attached to older knife or might be older than the knife itself. |
#12 | |
Agreed. I am attaching a picture of the original lot, of which this item was a part. It may help suggest an origin if the other pieces are easier to identify. There are three pieces; a Moroccan Koummya, a Jambiya, and this knife. The leather on the back of the piece in question does resemble the jambiya, but I was told the inscription is in a Moroccan/Algerian dialect...so somewhere in between?? Or not related at all, and the estate seller just lumped the 'pointy things' all in one lot. |
I'm inclined to believe your pointy-thing conglomeration.
The ring attachment method on the koumaya would seem to indicate a mid-20th century date, from what I've seen, but again, I'm no expert. |
There are two Yemeni coins. A 1/8 Riyal and 1/10 Riyal. I would bet this is newer than the coins. Could have been made in Ethiopia or Eritrea but I'm more inclined to think this is more recently put together in Yemen since the 1970's.
I believe the hilt and scabbard work is done in nickle-silver. True silver tends to tarnish with a much wider range of hues (dependent on chemical exposure over time and alloying). Whereas this only seems to have a black tarnish (suggests high nickle content). This also presents in sheen as mild yellow-green (that's your copper and tin displaying a bit).
To be clear Nickle-silver contains no actual silver (usually). It is a white brass that mimics the appearance of silver to some degree. It's actually a superior and very common material worldwide for this sort of highly detailed work. Question: Does the metal have an acrid/sour/spicy odor? |
Here's a coin I found similar~ 1372 AH, Yemen Arab Republic, 1/8 Rial, Islamic Arabic Silver Coin. Denomination : 1/8 Rial. Dated : 1372 AH (1952 AD). Calendar : Islamic. Shape : Hexagonal With 5 Sided. Composition : Silver.
like this below
#17 | |
#18 | |
#19 | |
#20 |
I've just remembered...I never received feedback regarding the inscription:
Does it indeed read "Be merciful to those around you"? And, is it in the Algerian/Moroccan dialect? |
#21 | |
#22 |
My guess the silver is from salvaged coins, a common practice by silversmiths. The Maria Theresa thaler, common in Arabia in 19th & early 20 c., was .833 silver & .166 copper. The silver sheath and the Omani coin have a similar patina. Also, I tested the silver on my better kaskara sword grips and they indicated color (brown) about 80%. You can order a inexpensive silver testing solution on-line. Not all that precise, but will give you a ballpark.
Ed Last edited by Edster; 21st March 2020 at 06:38 PM. |
#23 | |
Thanks! |
#24 |
Well what ever it says, I will agree on the Yemen (Oman?) attribution with the Seal of Solomon. This style of silver filigree work is indeed what you find in Yemen with that type of leather work on back.
A possibility is that the blade might be a trade blade from elsewhere from Africa (Sudan?) or maybe India. In both places the elephant is a good omen and the script and Seal of Solomon may have been inscribed later. Unfortunately I don't read Arabic, but I would move away from Morocco or Algeria with that form of silver filigree. Certainly a unique and wonderful piece - thanks for posting this. Again zukran! |
#25 |
Hi Shayde,
I didn't see your thread. I think you got a lot of feedback, if you want a good translation you should ask directly to Kiwatek. As Jim, Michael and Ibrahim said, it is a Yemeni knife, no mystery about that. The date on the coin is consistant with the knife, around 1950. Some jambiya have Arabic inscriptions, with surats or poetry, little stars, people and animals. The elephant is not a mystery either it is related to the surat of the elephant, either it is just an African elephant, Sudan / Erythrea are just near Yemen. http://www.vikingsword.com/vb/showth...=jambiya+stars http://www.vikingsword.com/vb/showth...=jambiya+stars The only mystery to me is the blade, looks like African, maybe from Sudan. It make sense, many Ethiopian blades were reused in Yemen. Best, Kubur |
#26 |
Thank you, Battara and Kabur! Ill be sure to reach out to Kiwatek.
Thanks again, -Rob |
#27 |
I am far from sure, but I think this is, slightly misspelled,
ارجع لحولك irja' li-hawlaka This is the name of a popular song in the Yemen. These pieces seem to be mostly inscribed with the texts of poetry and songs. Please ask Ibrahim if he agreees and how he would translate it |
