Just received these two nice pieces. I suspect they are North African.
The flask measures 13cm across the U. The bullet box is 6cm wide, 7.5cm tall and 2.5cm thick. The lid is NOT hinged but slides to the side for opening. Unfortunately one of the "tassles" is missing but other than that both items are in great condition with no enamel missing or cracked. The base metal of both items appears to be silver, as neither are magnetic. Comments welcome. Stu |
Hi Stu,
Very nice objects. The chain is old and IMHO they are from 1890-1920. I think the box demonstrates clearly that most of the so-called Koran boxes are in fact bullet boxes. The enamel work and the powder horn are probably Moroccans. Now the welded suspension rings of the powder horn make me think that both were sold as companions and they are decorative objects. Best, Kubur |
That makes little sense. Workshops made different items with various applications. They make what sells. I have a Koran box with similar work
This is a good question which is half answered as one is the gunpowder flask and the almost square item is ?
Certainly North Africa either Morocco and or Algeria. Note that clossone was more common in in Algeria and also applied to the Hilt of the Algerian Nimcha. I will stick up some other examples in a moment... ![]() There are examples at Library and the web illustrates many at https://images.search.yahoo.com/sear...e&fr=chr-yo_gc The question is more interesting because some countries have Quran Holders...and some look like they could be for bullets or oil... but that the two ought not to be mixed up. It should be understood that what is meant as a Quran holder means a small Quran is meant to be contained inside...in miniature. On the other hand some boxes are for a note either from the Quran or a note of some important issue ...e.g. water rights / building rights/ or something to be kept safe ...most of the time they may be empty. This is called a Hirz...and can be seen in the group photo below (Omani) They are usually sealed with pitch. A decorated Quran box holder can be decorated in a number of ways including geometrical art or inscribed with words from the Quran and in Morocco or Algeria some are covered in Clossonne..Other examples include those with magic squares. Quran holders are not usually sealed. I would expect to see other decoration on a bullet container or grease box. Not withstanding this it is possible that boxes for the tourist market could appear with no rhyme or reason to what they are decorated with...although even that seems doubtful to me.... Last edited by Ibrahiim al Balooshi; 14th August 2016 at 10:38 PM. |
Hi Stu.
Very nice matched pieces. And appear in good condition. Interesting the sliding cover. Rick |
Hi Rick,
Both in excellent condition apart from one "tassle" missing from the box. I should add that both came together from the same source. As far as the box is concerned it could be either a bullet box or Quran holder. Appears from above comments that there is a differing opinion on this, but that is what the Forum discussions are about....... Stu |
With a slide off lid you would lose the top pretty quickly if it was a bullet box. Also can you imagine having this box half full with round lead balls on a horse or camel at full gallup. I would think that pieces of the decoration would be all over the place.
#8 | |
#9 | |
Do you have some photos of this Algerian nimcha with cloisonne? I'm curious to see that. Thanks Kubur |
Here is a similar one.
#11 | |
The Nimcha. The Italian and/or Venetian sword appears as the origin of species and can be seen transmitted along the North African Mediterranean Coast in particular cloisonne versions in Algeria and other examples of a similar theme as far west as Morocco in the Mediterranean. It seems to have been a preferred weapon of the Barbary Coast ~ Pirates. A few swords somehow arrived in England early in the 16thC though on long English blades etc etc I place plate 32 by Buttin for interest. The write up on the gilded sword below indicates Moroccan although I suggest it is Algerian as they were very fond of Cloisonne which you can see at the scabbard..and may also have been also on the hilt but degraded...I will search for a fully cloisonne hilt.. Meanwhile a few other boxes... are these Quran or bullet boxes...? The Islamic geometry indicates Quranic rather than for bullets. Excellent picture above by Ward and the logical conclusion that the long sliding lid is for a miniature Quran not for bullets...and illustrates a miniature Quran carried as a Talisman. (From an Arabic word EXPANDED UPON AS ~ Origin Mid 17th century: based on Arabic ṭilsam, apparently from an alteration of late Greek telesma 'completion, religious rite', from telein 'complete, perform a rite', from telos 'result, end'.). I added a few Algerian Flyssa which although often adorned with red floor wax as a cheap way of lookalike Cloisonne ...added for interest.
#12 | |
This is not cloisonne. Most of your examples are inlay technic. The cloisonne is done with glaze/ ennamel. Not engraved or inserted but added. The two first swords and your last sword are from Morocco by the way. Look on the forum we have few examples of nice cloisonne. Best, |
#13 | |
See also http://www.vikingsword.com/vb/showthread.php?t=4782 which may also be Algerian... Your point is interesting since after hours of searching I cannot separate the two... that may well be because they are inseparable in that Berber Moroccan and Berber Algerian may have the same sword; The Clossonne hilt Nimcha. Last edited by Ibrahiim al Balooshi; 17th August 2016 at 12:02 AM. |
HEREIN IS PART OF THE GEOGRAPHICAL CONUNDRUM WITH SWORDS OF THIS TYPE...SEE http://www.vikingsword.com/vb/showthread.php?t=128
#15 | |
Yes, I have to agree with Ward. The sliding cover would be too impractical to retrieve bullets from. However, the typical hinged boxes work very well. I've actually tried this (although not from horse or camel LOL) with pre-formed cartidges (paper wrapped powder and ball) with the containers mounted on a waist belt. It works very well and is quick to reload a pistol. So I can see why these bullet containers were so popular. Anyway, I still like your set. Very attracive looking. Rick |
#16 | |
I think that's more complicated than black or white. Some Koran boxes are Koran boxes even the locals call them like that. However some Koran boxes are very small and exactly the size of the palaskas. The ones who have this kind of bullet boxes will understand what I mean... For the use from a running horse or camel lol like in cowboy movies... best |
I believe we were discussing a specific box with a specific construction and decoration. If we were going to branch out to other constructions and decorations than the use of an item may change. I actually like the work done on these items I suspect it is later 1945-1970 but that is just speculation from jewelry that has a known age of that.
#18 |
The designation Quran holder is interesting because it has not so much to do with the sliding lid...although this is in fact true ...and is an excellent bit of logical detective work...but that it is the decoration on the box and its shape which signifies its use....Artwork has to be geometrical as this was the form of art linked to the religious form...There is no way a box of this definition could be used as a bullet container...What I find odd is that these two items are part of a set...perhaps the item that looks like a powder flask is only a decorative item?...or talismanic...
#19 | |
Also the flask contained a small amount of darkish grey residue which I suspect would be powder..... Stu |
#20 |
From the rather low quality of workmanship, I would say these are quite recent bazaar or decorative pieces made for sale. Coincidentally, I bought a "Hand of Fatima" pendant, as a gift, in Portobello Market just a couple of weeks ago, of very similar work...
#21 | |
#22 | |
I've noticed the Koran holders all seem to have a similar squarish construction, and rings for attaching a throng or cord. Which could be carried around the neck, waistbelt, or most anything. This seems logical to me. The Palaskas, wheather Ottoman, Greek, etc. all seem to have the construction/shape as per my pic above. With an intentional cast-in or soldered loop on the back side for a snug fit on a waist belt. And they all seem to be about the same size. Beyond tradition, I've often wondered why this specific shape was used. I'm still not sure. But, as mentioned above, I do not believe these were designed to carry loose lead balls. Instead, I believe they were used to carry pre-made paper cartridges for use with the pistols on horseback. While I guess both containers could be used for cross purposes, it seems each was generally designed for their seperate purposes. Rick |
#23 | |
#24 | |||
I' doing my best to collect some guns that you don't have but it's difficult... Quote:
Now the Greek and Turkish are not the Africans / Berbers. I think they had different fashions and uses. About the Moroccan rings of the so called Koran boxes, they are very similar to the rings that you can find on Moroccan powder flask and koummiya. Quote:
#25 |
The only similarities are that they all are containers.
#26 | |
Kubur: Yes, I agree with what you are saying ref different styles for different Regions. We do have historical evidence that many of these small containers were in fact utilized to carry a Koran. But I've never seen any real evidence that the Ottoman/Greek style of Palaska, as shown above, was actually used to carry pre-formed cartridges for the pistols. But most of the reference material I have read refer to this paticular style as bullet containers. Maybe one of our Forum members as seen more conclusive evidence ? One day a while back, curiosity had me try an experiment. I went to the shooting range to test my theory. I made up 10 pre-formed paper cartidges. 5 will fit inside each container very neatly in a vertical fashion. I fastened the belt around my waist and a Suma Rod suspended around my neck, and holding the pistol in my left hand. Using my right hand thumb, it was very quick and easy to open the lid of the container, grab a cartridge, and close the lid. Then tear off the powder end of the cartridge, prime the pan, then use the rest of the powder, ball and paper (as wadding) in the barrel with one push of the Suma Rod. (Today you would want to prime the pan last for safety reasons. But that was the procedure back in the period to increase the speed of loading). It was actually much faster retrieving the cartridge from these little containers than a leather pouch with a flap. I can't seem to envision priming the pan of a flintlock pistol while the horse is at a gallop. LOL But once the horse is still, I can see this would be a quick and convenient way to reload. At least from a shooter's perspective, the theory seems to hold up. But again, it is still just my theory. I still have no historical evidence. It just may be a coincidence. Anyway, it was a fun experiment. Rick |
#27 |
In deciding what the box may be used for my advice is to look at the decoration; In some Quran holders the work is geometrical in accordance with a general rule although not right across the geographical area of the religion from the Atlantic to the far flung reaches of China...because of regional variation...taste and localized tradition ~ On some Quran holders other religious scenes may be worked...for example a Mosque. (as seen above) Other boxes appear however they are the Palaskas of Greek form...some are boxes for grease whilst others carried bullets. The Quran holder was not used for bullets...
#28 |
Sold recently
Described as "powder flask and bullet container", I think it's clear now... Changing his mind is never bad. Look at Darwin and the theory of the evolution...
#29 | |
Stu |
