Hi all
I recently picked up a few swords, I like how they look and decided they would look well on the wall,Neither however had a scabbard so I decided to fashion a means of displaying Swords in question are a khanda and a tulwar, not same shape of style but look well together Method is quiet simple and the picture should explain the process Basically I got some 4 inch copper tubing, friendly plumber was doing some work in my workplace and I scrounged some off him Cut a inch and a half section, with a jig saw and then used a power sander to make cut parallel Then put swords in x shape I wanted and marked where they would go Then I files out the grooves and all came together reasonably nice once I rounded the edges with some sand paper blocks Overall took around one hour and I am quiet happy with the job My wife is in Berlin for the week so that probably be the full extent of their duration on the sitting room wall If anyone has another method they would like to share I would appreciate it
Hi Ken,
Looks like a nice solution, the copper obviously being soft enough not to cause any harm to the blades. I guess the same could be done with clear acrylic as well. |
HER E IS THE WAY I DISPLAY MY INDIAN,SRI LANKAN AND AFGHAN SWORDS,JUST USE LARGE PICTURE HOOKS AND SECURE THEM WITH BLUE TACK,SIMPLE WAY,SOLVED THE PROBLEM FOR ME
#4 | |
But I have a method for your wife. My method is simple, I add an object every two months. It's not too intrusive and let my wife the time to assimilate the new decoration. By this way, I invaded all the living room... Kubur
#5 | |
#6 | |
The swords are up on display but I reckon it will be short lived I love Bandooks display Some lovely items, I can only wish Regards Ken Last edited by Ken Maddock; 14th December 2015 at 10:09 AM. |
THANKS KEN,HAVE A ROOM PART OF MY LIBRARAY FOR DISPALYING SWORDS BUT MOST OF THE HOUSE WALLS ARE FULL OF MY GUNS ETC,WIFE IS NOT VERY HAPPY BUT SOMEHOW MANAGED TO CONVINCE HER,I GUESS EVERYONE OF US ARE IN THE SAME BOAT,CHEERS
Picture-hooks and brass wire loops. You can tell I live alone can't you.
#9 | |
Hi Ken,
Great idea! Question though.....how do you attach the swords to the copper "ring" to stop them falling out? Stu Quote:
#10 | |
Hi Stu
I just cut slots very precisely and a friction fit holds them in The khanda is not in too tight, but the tulwar is "on top" so that holds the khanda in As the tulwar is slightly wider as you go up the blade from the handle I could introduce it into the slot closer to the handle and draw back till wider section of the blade was in contact with the walls of the slot Bit hard to explain but I hope you get idea As the metal is soft copper there is no blade damage I would like to acquire a shield and mount over to finish off the display All the best Ken |
#12 | |
Stu Stu |
Definitely the basis for a good displaying method is when your wife doesn't exist or is tolerant enough to have you exhibiting all your stuff ... or she is under severe bribing.
I qualify for an intermediate position, having a wife that doesn't care much for house decoration, thus allowing me to fill up all spaces available with my things; tops and interior of cabinets ... you name it. For some swords i use the adjustable steel rack, screwed on the wall; rather practical for when you wish to add or reduce the quantity exhibited. By glueing pieces of square section wood on the hollow stands, you may leave a vent wide enough to keep the blades in facing position. You just have to use some 'hidden' nails when, centering the swords on the stand, the hilt end tends to drop down .. specially during your cats adventures. For some other swords, like cup hilted ones, i use 'technologic' stands made in acrylic, developed for such purpose, which i order from a spanish antique weapons website. . |
hi fernanado nice display,is you cannon a portugese one,please can you put up some good pictures
cheers rajesh |
Hi Fernando
A lovely display method using the acrylic and one I might use in the future Also you are very fortunate to have an understanding wife ;-) A more interesting thread might be family reactions to our hobby! My wife is understanding enough, and our children love the hobby and are always interested in what I have picked up. Wall displays in the sitting room are not going to be a permanent part of the house Décor though. Regards to all Ken |
