I baught this helmet when i was in Lhasa (Tibet) in 1987. I just wanted to know if it is an antique tibetan helmet (18e or 19e century), or if it is a fake ? Best regards |
Short answer endeavour192, it is a modern helmet, despite what some very reputable arms and armour auction houses and some of the big three international names write about the type.
Gavin |
Agree with Gavin, it is a modern copy.
Thank you both for your quick answer !
And what about this buthanese sword ? |
The sword looks much better but without full disclosure of the blade I could not confirm as the art of sword making is still carried through to today...it does however show nice age patina.
Regards Gavin |
#6 | |
bhutan swords are still part of the national dress, the king wears his frequently on state occasions. makes it harder to date them as they are actively being traditionally made as i type.
the king: |
also, the swords come in various lengths and grades. my 'villager' model:
I had one of those, many years ago. I greatly regret letting it go, a very well made blade, very simply mounted.
That's a baanmok, a Lepcha knife from Sikkim. There are similarities to the working knives of Bhutan.
I have often wondered if the baanmok blades of the fullered type were made by Nepalese smiths. |
#11 | |
you are correct,
found this: Quote:
Thank you. What about thoses helmets ? Is it real old (18-19e century) ?
It is isupposed to be tibetan and bhutanese helmet. Endeavour192, The posting of items currently at auction is strictly against forum rules. Robert Last edited by Robert; 26th October 2015 at 05:33 PM. |
All the genuine ones I've seen are a bowl, with lamellar or textile defences hanging from it. The ones like this, with solid back and sides extended well below the front (or you could say that the front is cut-out for the eyes) have been fake. So I'd assume the left-hand (Tibetan) one to be fake.
The Bhutanese helmet looks genuine, as far as I can tell from the photo. Plausibly 19th century. The bowl could be older, with newer cloth. |
#14 | |
Gavin |
OK i understand !
endeavour192,
If you want to view better Tibetan and Bhutan Helms, armour and arms, get yourself "Warriors of the Himalayas, rediscovering the arms and armor of Tibet" by Donald J LaRocca and "Bhutan, Mountain Fortress of the Gods", in particular the chapter within, "The Way to the Throne" by Francoise Pommaret. Attached is one of mine that you may have seen? Gavin |
Since one of these items are from a current auction, this thread is closed.
#18 |
Issues resolved. We can now continue.
If i understand right, true antique Tibetan helmets are insanely rare! |
#19 | |
#20 |
Yes thank you, i know "Warriors of the Himalayas, rediscovering the arms and armor of Tibet" by Donald J LaRocca and i met Françoise Pommaret this year during a trip in Bhutan.
Not easy to find real antiques helmets ! |
#21 |
While I live in complete ignorance of Tibetan helmets, I'd have to say that to my uneducated eye, there are anomalies that lead me to doubt that the helmet in question is of significant age.
The improper lacing of the plates is apparent, but could be excused as an inept reassembly after having dismantled the helmet for "restoration". The designs on the bowl of the helmet appear rather fresh, and the riveting seems modern. It seems to lack any sort of patina stemming from use. All that said, while it may not be new, it seems to be satisfactorily Tibetan, given the source. "Fake" is a term I'd only use if an object was deliberately misidentified for larcenous purpose; the artifact is what it is, and does not seem to lie, or to bear deliberate false witness about itself. That said, I have no knowledge about how it may have been represented at an auction site. |
#22 |
One might be tempted to attribute the mis-lacing to bad restoration, but it's the standard lacing on this type of helmet. It's how they make them in the first place.
Most of these helmets are sold as antiques. They appear to be made with that intent. I'm happy to call them fakes. |
#23 | |
I bow to your experience and expertise regarding seller's intent. Caveat emptor, as ever. |
#24 |
Having seen many of these offered for sale over the years, I've wondered the same thing. Doesn't seem like it would be too hard to lace them correctly. But every single one I've seen has been laced this way (the wrong way). I don't know whether they all come out of the same workshop, of whether they're copies of each other by different makers.
(I haven't been counting, but it's surely more than a dozen I've seen.) |
#25 |
tibetan cavalry -note lamellae are laced and overlapped to guard from strikes from below. as is the properly laced helmet posted earlier. infantry lamellar armour would be laced the other way, more like roof tiles, to protect from blows from above. lamella are overlapped to increase the metal and to support the lamella next to them - distributing the force from a blow, not side by side which only presents one thickness & has weak points (gaps) at the butted edges.
#26 |
However, in practice, lamellar worn by infantry is still laced the same way, with the same kind of overlap (lower lamellae on the outside of the upper lamellae). Scale armour, whether worn by cavalry or infantry, overlaps the other way. Which suggests that the direction of overlap isn't a big factor in the protection.
That there is overlap matters. An arrow coming in will have to get through, typically, 2 to 4 layers of iron/steel to get through the armour. |
#27 |
Here is the type of helmet worn by Tibetan warriors in the later periods, the type originally posted here for discussion would be from a much older period and would show its age.
