Old 7th April 2014, 10:57 AM   #1
cicak_cobing
cicak_cobing's Avatar
Default Pedang Suduk Maru: Help / Advise
hi guys..
here is a pedang suduk maru for your viewing pleasure, comments and criticism..
cicak_cobing is offline   Reply With Quote
Old 7th April 2014, 11:22 AM   #2
cicak_cobing
the condition of the blade is quite bad in my opinion.. i think partly it has got to do with the warangan that it had in the past..
recently i realized that the blade has gotten darker, some sort of blackish.. and that's making the pamor look more dimmed.. almost not visible..
any advise guys? should i sand it down? i do not wish to sand it down alot.. any advise on how should i get it started?
thanks..
zach
Old 7th April 2014, 11:59 AM   #3
russel
I can hardly imagine any criticisms: Simply stunning!
And great photography too. :-)
russel is online now   Reply With Quote
Old 7th April 2014, 01:31 PM   #4
Emanuel
Emanuel's Avatar
Nice pedang. Interesting that the scabbard chape has a drag in the style of long European sabres. Not necessary on a short sabre like this but maybe a feature borrowed from Dutch sabres?
Emanuel
Old 7th April 2014, 04:49 PM   #5
Hello Zach,
nice pedang lurus/suduk. Are the fittings old or more recent?
Old 7th April 2014, 07:46 PM   #6
thanks..
zach
Yes, you are correct, it has to do with past warangan. Personally I would do nothing. But maybe Alan has a better advice.
Old 8th April 2014, 03:31 AM   #7
cicak_cobing
thanks, russel!
Emanuel
i'm not quite sure by what you mean "has a drag" or maybe i'm just not very familiar with european sabres.. what i know is that european sabres are known for their up curve shape, but this pedang goes slightly opposite..
Originally Posted by Sajen
Hello Zach,
not quite sure, sajen.. it's not recent, but definitely not very, very, very old either.. maybe 50-70 years? just a guesstimation.. the blade looks way much older than the fittings tho..
i'll pm him.. thanks, sajen..
Old 8th April 2014, 03:45 AM   #8
should i sand it down? i do not wish to sand it down a lot.. any advise on how should i get it started?
I certainly wouldn't sand it down, not even a little.
I might try some WD-40 and a toothbrush or maybe hit it with very fine #0000 steel wool to see if it brightens up.
Old 8th April 2014, 04:13 AM   #9
Amuk Murugul
Amuk Murugul's Avatar
Hullo everybody!
.... Interesting that the scabbard chape has a drag in the style of long European sabres. Not necessary on a short sabre like this but maybe a feature borrowed from Dutch sabres?
Emanuel
..... Depends on culture. Certainly helps when kneeling, squatting or indeed, sitting cross-legged. You will find drags on all manner of edged-weapons, even on a short golok/hakmes.
Old 8th April 2014, 04:58 AM   #10
semar
semar's Avatar
Hello Cicak Cobing
leave the blad like it is juse onley WD 40 like David say and clean it with a brush to remove the old rust its one old blade more you can not do in my opinion
semar
Old 9th April 2014, 04:23 PM   #11
Emanuel
Emanuel's Avatar
Hello Zach,
By drag I mean the little U -shaped piece added to the tip of the scabbard. It can be seen in one of your first pics
On European sabres it was originally added as further protection to the tip of the scabbard from damage when the sabre dragged on the floor, hence "drag". I attach a European example.
It looks like a later addition to me as it doesn't seem to flow with the rest of the chape (the decorative tip of the scabbard).
Emanuel
Old 10th April 2014, 09:25 AM   #12
cicak_cobing
that's right, david.. i do not wish to "damage" the steel but at the same time i do not want it leave it to get damaged by itself..
Originally Posted by semar
Hello Cicak Cobing
semar
yea, semar.. will surely work on it with wd-40 as david suggest.. thanks
Originally Posted by Amuk Murugul
Hullo everybody!
Hello Zach,
Emanuel
i'm not sure about it on this particular piece that i have.. i think somebody earlier might have tried to repair it by re-attaching it with the original piece or with a new copper.. i can see some welding marks on it..
as to your question, maybe there is some european/dutch influence in it.. i can't say for sure tho.. just as amuk murugul mentioned, this design also appears on other swords in indonesia too.. some of them have got strong european influence, probably it's made for dutch customers..
drag on pedang suduk:
drag on golok tjikeroeh:
this piece is interesting as there is no metal works on it but yet the drag design is there.. other styles will have a wooden or horn cover at the butt of the wooden sheath called "tutup handap" (bottom cover) or "kasut" (shoe), depending on the area..
attached is a golok bengkulu and parang nabur with the drag..
