Here's a kindjal coming out of an attic
the blade is rusty, could someone give me a tip to clean the blade without damaging the kofgari.. I think it is ottoman any idea, provenance, dating is welcome |
There is no short-cut to remove the rust around the gold work, just a steady hand, and small pieces of wire wool or emery paper with a lubricant wd40 etc.
Perhaps even cover over the gold-work with some sticky tape cut to shape. A desktop magnifier with a light may help to get in close to the gold-work. Hope that helps, Runjeet |
Regarding the copper fittings - I would just polish with renaissance wax, but others would use Brasso to bring it up bright. It's personal choice.
Regards. |
Bamboo skewers and a little machine oil, and a lot of patience will help as well. good luck!
#5 | |
#6 | |
Nice tip Alex, I'll remember that one.
Regards, R. |
Here's the cleaned kindjal
and the restored scabbard |
That was very fast work!! Well done, some very accurate work around the gold-work!
Very nice work!
WOW, fast and good!
Great job and a nice kindjal !
Great cleaning job, especially around koftgari! How did you do it? What kind of materials did you use?
Excellent work, very well done.
Best, Robert |
#15 | |
wow.. i'm digging the gold work..
outstanding! |
Congratulations - very well done !
I am comming a little bit late, nevertheless: also fine pemza powder applied with oil (and soft cloth) is very useful. Gold coftgari could be covered temporarily with wax or lacquer (especially if one is using chemistry, like chelaton III). regards, Martin |
