Hello everybody,
This is most probably a composite keris with a very nice hippo handle of Malay origin ( ? ), indicator: the high crest. The wavy blade Bugis / Sumatran. But no clue about the selut and moreover the sarong. It is an old piece with a flashy wood pattern but the shape is odd. Bought as a Palembang keris but the features do not match. |
since nobody else have comment until now I will try it. Blade is Bugis style but also found in Malaysia. Hilt and pendokok is like you write already also from Malaysia and when I am not mistaken is the form of sheath also a Malay form, very similar to the Madura ladrang form. Can you show a picture how the blade fit inside the sheath? Will do some research if I can find a similar sheath. Regards, Detlef |
Hello again,
I am nearly sure that you have there a very nice and rare keris Bugis Terengganu or Kelantan, the sheath form is called kusiwo or pucuk kacang. Sadly our Malay members are not anymore very active here in the forum but maybe one of them will jump in and will be able to tell you more. Attached is a picture of a Terrengganu keris in a similar sheath taken from Malay-art-gallery (sold one). The form is not direct the same but like said similar. The wood from your sheath is made from kemuning IMHO. When you not happy with this keris I would be happy to take it from your hands!! Regards, Detlef Last edited by Sajen; 25th February 2014 at 09:53 PM. |
I am inclined to agree with Detlef that this may not be a composite piece, but fully Malay in origin. I'm not sure that you nailed the sheath ID however, since there are some more than subtle differences with the one you posted. I am a bit confused by the way the stem terminates as most that i see from the Malay side tend to have flat bottom, not this rounded end.
It would be nice to see Kai Wee or Shahrial comment here as these types of keris are really their area of study.
#5 | |
Regards, Detlef |
Thanks for the comments and hope the additional pics will be helpful and an invitation for more background information.....
My observations: The ganja is peeping out slightly but not uncommon. The tip end of both warangka wings are missing a small chip and the back of the sampir showing very fine haircracks indicating age, so does the dark dusty slot opening imo. |
Wrongko looks like a Madura kacir to me --- at least that's what this form is called in Solo. Don't know what it might be called in Madura.
The pendongkok/mendak looks like Surabaya work. I'll reserve comment on what I think the origin of the complete piece might be. |
Hi there,
The hilt was bona fide Peninsula Malay, called Pekaka hilt locally, and famously attributed to the state of Kelantan & Pattani. Usually a decent, old specimen would be in dark-yellowish tone, ageing naturally. Yours is a bit whitish, perhaps being polished with autosol or something - which is kinda degrading it's authenticity of ageing over here. Blade could be Terengganu, but I think if you can post some pictures of the blade portion itself (base, mid and tip), maybe some other member can put more words into it... This type of sheath was really a puzzling debate before. Pardon my experience and knowledge, but I can not confirm it was of Peninsula origin; I did not see much of this type around here but definitely there were a few, and it is always on blades which would be spotted with Coteng hilts - and usually attributed to Singgora (Songhkla) of Thailand. NEVER on a Bugis blade. |
A curious piece. Looks all Peninsular to me but with a sheath modelled after a Javanese Pasisir type. Others have already mentioned Madura but you also see similar sheaths all along the North coast. Its clearly well made and had seen some wear and tear it so its not just a made up or souvenier piece. Who knows what the real story behind it is but its certainly very rare. Good find!
Thanks for chiming in Dave. I was hoping to hear from someone with a better grasp of the peninsula perspective. I also got the feeling it was all peninsula, but it's only a guess for me.
Thanks gentlemen for your comments and I will keep it as a rare find in my collection.
Hello! Long time no see!
I'm leaning towards Sumatra for this. The wood used for the batang looks like trembalao. Something we dont see in the Peninsula. The blade looks like Straits Bigis/Riau-ish. Pendoko looks Sumatran-like. |
Hey Kai Wee! Nice to read you. I trust life is treating you well.
Thanks for adding your ideas on this one. Seems we have some fairly diverse ideas working here. Is it just the wood choice that has you leaning towards Sumatra, or is there something about the sheath form itself? And where would you place this hilt? |
Yes Klungkung, it is certainly a very rare piece, in fact, it may be the only one of its kind.
Thanks David. I got a bit rounder, so I guess life shouldn't be that bad
![]() Yes, my view was largely based on the wood. It would have to be imported into the Peninsula, and I haven't seen this sort of wood on the batang of a peninsular keris. The closest wood is bongor, which looks like this: |
Alan, this looks like an 'interpretation' of a foreign keris sheath style, so it could indeed be the only one of its kind.
Yes, possibly an interpretation, but I was thinking in terms of mating.
If it is mated, its a professional job, and a few years back there were a lot of mendak/pendogkok exactly like this one coming out of Pasar Turi, Surabaya, usually silver plated brass or copper, but there were a few genuine silver ones too. A mating job such as this one might be was pretty common in that place around 20 years ago. |
#18 | |
