Old 17th February 2014, 03:55 AM   #1
DaveS
Default Sulu twistcore
Here is a twist-core that I think is from Sulu. 23 1/2 inch blade. On the end of the horse-hoof pommel is a small carved rosette. Kris should date from the early 1900s. No scabbard........Dave.
Old 17th February 2014, 05:38 AM   #2
Nice… Love to see a vinegar etch on this blade, but maybe that's just me.
Old 17th February 2014, 06:42 AM   #3
DaveS
David: 98% of the etches that I do are done with phosphoric acid. I only use ferric chloride if the metal doesn't respond to the phosphoric. The few times that I have tried vinegar, it didn't really do much, at least not to my liking anyway............Dave.
Old 18th February 2014, 12:53 AM   #4
I have seen a number of this style of twist core and it is looking to me like this is a form of twist core done more toward the end of the 19th century.
Nice and love the pommel carving. And yes it is a Sulu blade.
Old 18th February 2014, 01:31 AM   #5
My point was a light etch to add a touch of contrast Dave. Any way that suits you i guess.
Old 18th February 2014, 03:37 AM   #6
DaveS
Sorry David, it sounded like you were wanting a lot more contrast......Dave
Old 18th February 2014, 03:43 AM   #7
Sorry David, it sounded like you were wanting a lot more contrast……Dave
Nope. I never thought vinegar was the way to go for heavy contrast. It's such a mild acid.
Old 19th February 2014, 10:40 PM   #8
archer
Default Etching
Hi David S, You mentioned you preferred using Phosphoric acid to etch. Would you tell us what grade, strength% you use and if diluted the ratio.
My first etching was with some used in wine testing worked great now not available. Thanks, Steve
Old 20th February 2014, 07:32 AM   #9
DaveS
Steve: you don't need to dilute it at all. Use it right out of the bottle. I know some people might be a little afraid of using it at its full strength, but don't worry, I have used it for many years this way with very good results. Unlike ferric chloride it will not darken any silver. For a darker etch you can very carefully heat the blade with a propane torch, two or three QUICK passes on each side. Of course before you do this you will want to degrease the blade with acetone, lacquer thinner or whatever.The acid on a heated blade will have a tendency to fizz up, but don't worry, this is normal. If the blade is heated up a little too much it will come out too dark and you will have to repolish and start over again. No harm done, just a little extra time lost. Home Depot carries it in gallon jugs. It is used as either concrete or metal etch. Hopes this helps..........Dave.
