I casually threw out a bid on this keris simply because i liked the hilt. Kind of a bet an forget thing. The blade is nothing exciting and the sheath needs a little re-furbishing. But it was this hilt that caught my attention. And the price was right. Any thoughts?
http://cgi.ebay.com/ws/eBayISAPI.dll...E:L:OC:US:3160 |
Interesting hilt - not seen this type of carving on this kind of hilt before.
(Then again there are a lot of things I haven't seen before.....) |
#3 | |
Very nice hilt with the kandit, I think this style is from the late 19th century. The price was indeed a very good one. I want to go for the other "keris" from the same seller, only for the hilt, but it went to much up. Please post pictures after your maintain.
Regards, Detlef |
So does anyone know the area this hilt comes from? East Jawa maybe?
#6 | |
Sheath and blade as well.
David,
Good buy for a casual thought, the price was certainly right. It was a give away congratulations! Since Battara and perhaps others are unfamiliar with this type carving I am attaching a similar type hilt (sorry about the photos, the piece is in the vault at the moment and I can't get to it easily for new photos) Erik |
Thanks Erik....would you concur with the East Jawa/Madura origin. I do see elements in the blade, such as the inward slant on the gandik, that might indicate Madura, but then, it can be seen that this blade was adapted to this sheath...
You are very welcome David.
I do concur with the East Jawa/Madura origin at this time, this may however change once the blade is restored. As for the recycled wrangka I would not worry about that, I have several wrangka that has been fitted to a different blade over time, not a problem... |
#10 | |
Very, very good David.
Very good indeed. On the fill of the mouth in a wrongko. There are a number of reasons for this:- 1) a wrongko can be original, but worn, and no longer provides a good fit or protection for the blade, so the over-size mouth is filled, usually by an inlay of wood, sometimes done in a contrasting colour. 2) a wrongko might be of particularly good wood, and is intentionally used instead of new wood; the thought behind this is a little bit like marrying a woman who is of exceptional quality, rather than a virgin:- a virgin has her own virtue, but a beautiful or intelligent woman with several previous husbands can more than compensate for the limited virtues of a virgin. 3) economy:- re-use of old can be a lot more economical than creation of new. In view of the quality of the wood in this wrongko I'm inclined to think that reason #2 is the applicable one. In accordance with what I believe to be true, this keris is East Jawa, meaning that it could be found in Madura, as Madura is a part of East Jawa, but it is not necessarily identifiable as of specifically Madura origin. |
#12 | |
David, has the fill been done with wood or with shellac?
In the photo it looks like shellac. |
Actually not in my hands yet Alan. I will let you all know next week when i get back into town.
OK David, thanks.
This keris arrived today and is proving quite interesting to me.
Alan, it looks to me that the wrongko refitting was done with wood. I think what looks like shellac to you is just the finish they put on the top part to help match it to the sheath. I will see if i can get some good shots of this tomorrow if the weather is good. The hilt is really nicely carved and i'm fairly certain the kendit is true as well as the pelet wood of the sheath. The interesting surprise i am having is that it would appear that the pesi might have been expertly replaced with an insert. It's a really nice, clean and tight job of i style i have seen done on Moro kris before, but not Indo. The blade is of better quality than the eBay photos show and it has some interesting pamor material. I will try to provide some close-ups of this when i get a moment and some good light.
I would have very surprised if the kendit was other than natural and if the wrongko was not from naturally marked wood. This particular type of hilt is quite scarce, I cannot recall ever seeing a bad one. You really did well with this keris, David.
I know of several ways in which a pesi can be repaired, I'll be interested to see what has been done with this one. |
#18 |
Here are some shots of the pesi repair as well as the old re-fitting of the blade to the wrongko. Alan, it looks like a wooden piece to me that was then possibly received shellac on top to help match the wood.
I find the pesi repair very interesting. The blade has obviously had a hard life, but it has some features i quite like. I have only given it a preliminary cleaning to remove the active rust. Some of the pamor material is very bright and silvery and has some interesting characteristics. I think i will have to wait for warmer weather to stain this blade, but i think this is worth working on further.
#19 |
Yeah, the wrongko fill is self explanatory.
I've seen that pesi job a few times, and frankly, I cannot make up my mind if its a repair or an alternative original method. A couple I've had have been a perfect match for iron, which makes me feel its original. If a bakalan was undersize, fitting an add-on pesi like this would save a lot of material. When you forge the pesi into a bakalan you either forge down , and then you lose a lot through flaking, or you cut the pesi out of a bakalan that has not been forged down, and again you lose material. A pesi needs a lot more material to start with than you'd think. |
#20 |
Nice keris ... with a very similar hilt I have into my collection .
#21 |
After seeing three of these hilts in this thread that have a kendit ring in almost exactly the same place I'm coming to the conclusion that it is a staining rather than natural .
#22 |
The possible pesi repair reminds me to a philippine kris in my possession.
BTW, you have done very well to buy this keris!
#23 | |
#24 | |
#25 | |
#26 |
This one once was mine (stolen from my home).
This is only to complete the range of this kind of hilts. |
#27 |
Please apologize. I forgot the pic
#28 |
Gio, I like your hilt, but i would say that while it is a relative it is not quite the same style.You have too much carved area in the middle of the hilt while this style leaves that section uncarved. And your photo may be deceptive, but your kendit looks to be an add-on to me...
#29 |
Hi David,
my intention was only to show the natural black stripe of the wood. I believe the hilt is Madurese. |
#30 | |
