Hello all,
I just show you one Kris that I bought last week end, for your opinion, I do not know anything about weapons in Southeast Asia, my passion is weapons of Africa. The handle is of horn, the ferrule is silver, the Beca Beca are Brass, and the blade is inlaid with brass square. I await your comments. |
It looks like a Moro kris from the Sulu region. The pommel is in a simple junggayan style and I suppose the brass squares are perhaps talismanic (brass warding off evil).
It is strange that the brass is in squares instead of the usual dots and the forte is not in the usual elephant figure but a little more simplified. Nice piece though and thanks for sharing. |
I agree that quite a bit of craftmanship and effort went into making this piece.
However, it just doesn't vibes with me: neither as a traditional Moro piece nor as Malay work. Apart from the weird gandik area, the flow of lines of the blade is as strange as the inlay and the engraved motif at the end of the fullers; the hilt seems to copy a Sulu junggayan but both the pommel as well as the stepped grip area seems kinda off to me; peened over tang or just holding the pommel onto the grip (another unconventional approach)? If I had to bet, I'd lay my 2 cents on it being a fairly recent reproduction, possibly by those busy Madurese artisans? Any signs of modern glue at the pommel/grip attachment or for setting the blade? Regards, Kai |
BTW, where did this sword come from?
(Not locally from Sao Vicente, I guess.) Regards, Kai |
#5 | |
I think it's maybe post 1950's Kembang Kacang is all wrong, way too diminuitive .
Yes although I stand by what I said, there are more than those things I mentioned that are strange about this.
Kai you have a point - it may have been made recently - hadn't thought of that. Would make more sense. |
Hi Kai,
It come from Nederland. |
#8 | |
Regards, Kai |
#9 | |
The seller in Rotterdam, told me that it was a Malay Kris, but I doubt he knows more than me.
I meant wether it came from a Dutch collection (which?), some auction (where?), or directly from Indonesia/Malaysia.
![]() Regards, Kai |
Could this be what the Malays call a sundang?
Yes, although there are some subtle differences between the Malay sundang and Moro krises.
#14 | |
Can you educate me (us)? |
That would take a while Ariel. However to mention a few things:
1. there are differences in okir - Malay is more "realistic" than the more stylized forms used by Moro groups, even more than that of the Sulu region. 2. the pommel is often tilted at close to a 45 degree angle and smaller. Moro older forms may be smaller but are not as angled in general, and later ones are larger and again not as angled. 3. the hilt section between the blade and the pommel has a more sculpted shape, often without a ferrule to speak of. This section where a ferrule would be is also often much smaller than the rest of the hilt in circumference. In Moro forms the same region under the pommel is not as sculpted and there is a large ferrule - sometimes as large as half the hilt. 4. the clamps between the hilt and the blade on Malay pieces are very thin and plain, but Moro clamps are often wider, and can be plain or have Moro okir. 5. the scabbards of good Malay examples have very long band sections of Malay okir. Moro bands are not as long down the length but have thinner bands of plain or okir work. These are just some of the things that come quickly to mind at the moment. |
Thread is closed on this piece.
