Just picked this tulwar sword up, don't know much about them,
any opinions on this one would be helpful. Erich Last edited by eric45; 6th July 2012 at 02:50 AM. |
The blade is pattern welded and it has armory markings a fine example in my opinion. As far as age goes 1800-1850.
Thanks, boy if this sword could talk the storys it could tell.
Erich |
Hi Erich,
I like your sword. Can you confirm or not whether the hilt has a pin through it and the blade, it looks like it has but I cannot see whether it is an indent in the hilt or a pin. I have attached a photo of one of mine and you can see the similarities in the crossguard finials and between them a floriate silver 'washer' this is where the pin is located. Again nice blade with a subtle yelman. My Regards, Norman. |
Nice sword, actualy a very nice sword, and what looks like a good "watered steel" blade, mechanical damaske (laminated steel) rather than "wootz",....both are good, but according to H.R.Robinson mechanical tends to be older than wootz. If there is a pin through the hilt that is usualy a sign of Afghan origin and so a "Puhlwar" rather than a "Tulwar". (spells it how you want, it is a phonetic transliteration of a dialect word in a foreign language).
It looks like an indent on one side and a hole on the other, but the hole has dirt in it, can't make out if it has a pin, what would be the purpose of the hole?
For a pin i imagine to hold the blade? Erich |
David, I am glad that you write 'If there is a pin through the hilt that is usualy a sign of Afghan origin', especially the word 'usually' as the pin thing was used all over.
Jens |
The pin mostly does not go through to the other side, and the hole is often hidden by a flower like on Norman's sword.
Hi, the segmented disc is typical to Lahore (Sind) swords.
Regards, Timo |
#10 | |
Hi Jens, The one I have is an oddity in that the pin goes all the way through and has the floriate 'washer' on both sides. My Regards, Norman. |
Hi Norman,
You can't be sure till you have removed both flowers - can you? However I would not do so - I would leave it an be happy with it as it is :-). |
Hi Jens,
I seem to have an odd one, the pin does go all the way through (see photos), but it also has this floriate/vegetal decoration in the small fuller and on the spine which also seems rather unusual. My Regards, Norman. |
Hi Norman,
Sometimes the pin goes the whole way through the hilt, and sometimes not. The floral scroll looks nice, and is sometimes seen on blades. Jens |
