Still in the process of digging out the accumulations of of lifetime of random collecting and trying to make sense of it all. As each box is opened I am amazed what is there ... cant even remember buying many of them . Anyhow would really appreciate help with the ID of these 2 daggers please . They are both around 40 cm long with max blade widths of 5 cm . The grips are horn and brass. There were no scabbards with them.
Those two are from Somalia. If you type in "billao" in the search function of the forum, you should be able to find a lot of info on this type of daggers from more knowledgeable forumites than me.
Regards, Teodor |
VVV is right. I believe they are also from Somalia.
Thanks both of you ... any idea of age ?
These are circa 1900-1920.
#6 | |
