Old 10th October 2010, 05:45 PM   #1
celtan
celtan's Avatar
Default Brake fluid?
Hi Guys,
I was in the process of cleaning the interior of a very gunky metallic bayonet scabbard, and remembered some advice about using brake fluid. Which I did, and it worked rather well. Then, I began thinking about any unintended deleterious effects.
Any thoughts on the matter?
Manolo
Old 10th October 2010, 08:04 PM   #2
Matchlock
Matchlock's Avatar
Hi Manolo,
Interesting idea.
I don't drive and consequently know nothing about brake fluids and their possible collateral damages, though.
Michael
Old 11th October 2010, 12:25 AM   #3
Brake fluid is well known for it's paint removal capabilities
Regards David
Old 11th October 2010, 04:04 PM   #4
celtan
celtan's Avatar
The most common effect is when you don't have any brake fluid while driving...and a rather common ploy to solve intramarital problems, often used by wiveys now-a-days.
Hi Manolo,
Interesting idea.
Michael
Old 11th October 2010, 04:06 PM   #5
Matchlock
Matchlock's Avatar
Thank you so much, guys, for enlightening me!
I supposed it had something to do with lubrication...
m
Old 11th October 2010, 04:08 PM   #6
celtan
celtan's Avatar
Probably the reason why, as a solvent, it can remove caked grease from within scabbards?
TG, this scabbard was already missing its bluing. I used a pistol's barrel copper-brush plus the fluid, and removed lots of crap from its innards. Then cleaned it all with penetrating oil.
Not bad...
Best
M
Regards David
Old 11th October 2010, 04:41 PM   #7
I recall people telling me to handle brake fluid with care, due to its corrosion capacity. I have also read that its composition includes corrosion inhibitors, which loose their property with time; i suppose this is one of the reasons for replacing brake fluid from braking pumps periodicaly.
I don't know if it is a good idea using this thing for purposes other than braking systems .
Old 11th October 2010, 05:53 PM   #8
Matchlock
Matchlock's Avatar
I definitely share your opinion, 'Nando,
And it should not be forgotten that any kind of lubricate will irreversibly soil leather and textiles.
Michael
Old 15th October 2010, 08:45 PM   #9
celtan
celtan's Avatar
And yet, we spend all sorts of money on lubricants such as Pecard and Leather care products, based on animal grease.
Or do you mean the seepage out of the cleaned scabbard? That is utterly true, it does become a rusty dye.
Michael
Old 16th October 2010, 03:53 AM   #10
Default I had the same questions
Originally Posted by celtan
Hi Guys,
Manolo
Manolo,
I had the same questions some time back, see here;
http://www.vikingsword.com/vb/showth...brake+scabbard
Gav
Old 16th October 2010, 06:48 AM   #11
G. McCormack
G. McCormack's Avatar
It is commonly used by AK-47 enthusiasts to clean their rifles. It does the trick, but I find it is really gross and will strip/stain white any wood and some synthetics. I'd minimize exposure to it. Good luck
Old 16th October 2010, 04:44 PM   #12
machinist
When I took an auto repair class the teacher said that brake fluid had the ability to absorb atmospheric moisture so I would be careful with it and not use any from an old dusty previously opened can.
Of course he did tell stories so I dunno if it is true.
machinist is offline   Reply With Quote
Old 16th October 2010, 08:04 PM   #13
celtan
celtan's Avatar
Thank you guys, I used WD40 after the BF, to flush it off. The subsequent air blast is an interesting addition. Any remaining WD40 will evaporate, and we then can spray inside some Ballistol
BTW, I could always use some fine-tip surgical aspirators to get to the depth of the scabbard. Alas, same thing cannot be done withs swords, too long!
BR
M
Old 16th October 2010, 08:23 PM   #14
Hi Machinist,
welcome to the forum....your teacher is correct. Brake fluid is hygroscopic....which means it will absorb water/moisture....this is one of the reasons that brake fluid (in a vehicle) should be changed every 2 years or so.
Regards David
Old 16th October 2010, 08:36 PM   #15
Welcome to the forum, Machinist
Old 16th October 2010, 11:28 PM   #16
Default Very true
Welcome Machinist,
This is of course very true if it is left to sit but even if it has been sitting on the shelf.
If I remember correctly from my tech classes as a teenager, the moisture absorbed accounts for rust found in some braking systems and also loss of some pedal as water compresses more under pressure?? It has been a long time since these classes.
You can use it though, it still will complete the task at hand and as suggested in the post, once part of the task is completed, move to part two, the WD wonderful application and disperse all of the concerns and of course then let it all dry.
After following suggestions in the thread provided, I have also gone through the scabbard again after this with a pull through and oiled flannel cloth to ensure all is ok.
Gav
Old 17th October 2010, 04:35 PM   #17
machinist
Thanks for the welcome guys.
I am often here but often quiet.
