After seeing the sellers pictures, I had assumed that the shaft had been 'cut down' (a common practice with 'bring backs' ) However, on receiving it ...I am almost certain that the shaft was originally this length and that it is possibly used as the Zulu's Iklwa.
The head is socketted and the blade is a very 'flattened' diamond (cross section) Spearhead 'blade' is 34cms long (5cms at the widest point)It is very well tempered and seems more like a sword blade in nature. The edges are sharp with a number of very old nicks. It seems to me that this spear other than the usual stabbing function also has some cutting abillity ....a 'cut and thrust' spear ????? It definately handles as a close quarter weapon....OAL 125cms Some of the engraved decoration seem Congolese, others seem Sudanese Please has anyone any ideas to origins ....and whether this spear is used as I am suggesting. thank you Regards David . |
Definately not Zulu. I would go with Sudanese or maybe Hausa tribe from Nigeria?
I think I would agree with Lew. The idiot I am, I lost these two spears in a bad swap.
http://www.vikingsword.com/vb/showth...ht=sahel+spear |
"The idiot I am, I lost these two spears in a bad swap."
Happens to all of us....
It's probably a Mandinka/Manding spear, I,ve had several similar with the leatherwork typical of the swords, this one probably also had leatherwork along the shaft. So Niger/Chad/Nigeria type area. I,ll post a picture if it would be of interest.
I saw similar spearheads like David´s one in North Cameroon and also North Nigeria.Not exactly the same, but very similar. Acc to some local people they vere from Sokoto, acc to another ones from Adamawa. Never with shaft. I will do my best to post photos during the weekend, but the spearheads will not be cleaned.
Martin |
I'm going to throw in a wild guess of Fuble jaral (stabbing spear), I'm afraid I don't have good documentation for the type (besides a mention in "Notes on the "Bororo Fulbe" or Nomad "Cattle Fulani". Part I, by E. A. Brackenbury © 1924 The Royal African Society."), but having seen the description of the type pop up occasionally, combined with the general Nigerian/Cameroon providence provided by other members I think it's a relatively good stab in the dark.
Wow ! thought there was only one reply and then found many
(its been a little quiet on the Forum lately )....thank you very much for all your replies ,I have had another look at the shaft, the last third (opposite to the 'head' end ) is slightly tapered .....again suggesting that this was originally designed to be 'short'. Had the shaft been longer and the taper continued down its length it would have been incredibly thin and 'weedy' at its 'butt' end. Hi Ashoka, I would like to see the pictures of the Mandinka/Manding versions of the spear, thank you. Hi Martin, look forward to the pictures, thanks. Hi Tim, I suspect nearly all of us have had regrets swopping/selling items ....I know I have ....and Battara has ... and.....Thanks Lew for your prompt reply and ISPN for the 'background' reference Kind Regards David |
Images of a related spear, less fullering but similar profile and decoration, length of the head on this one is 57 cms to the base of the socket. The shaft on this is pretty thin and light too.
Thanks Ashoka
,as you said very similar (very nice spear, by the way), Spearhead, on mine, is 47cms from point to base of socket. I cannot see evidence of any leather having been used to cover the shaft, but similar to yours.... it is both thin and light. However, there are a number of 'shrinkage' cracks that have a dried 'substance' within them ......to me (using a jeweller's loupe) it looks like 'old' dried out hide glue or a similar 'organic' adhesive ....perhaps evidence that there was a covering afterall Kind Regards David |
There is fabric/cotton under the leather as is usual for this kind of work, probably glued on, Maybe the reason why the shafts are so light/slender, if yours had had fabric and leather on it, it would have been a pretty regular thickness. It's Stefan not Ashoka btw
#12 | |
),my apologies ......the fabric 'under-covering' is a good point, the hardened 'hide' glue does seem to have fibres within it, and as you say the combined layers of fabric and leather would increase the diameter.....but would also have the benefit of strengthening the shaft also.Kind Regards David |
Enclosed please find some types of spearheads from Nigerian Sahel, also from neighbouring Cameroonian areas (and also from Chad). Following info was not verified - I just repeat what local vendors said:
The first three spearheads from the left side should be from Chad, the first one is very heavy. The fourth from the left should be from Nigerian Adamawa. 5th (slender one) was allegedly used by "Shewa Arabs", area between Maiduguri and Maroua (also Borno state, Kanuri people). 6th - nobody knows (local "mystery", could allegedly be from Burkina Faso ?) 7th - allegedly common shape in Nigerian Adamawa, Gombe, Bauchi, Taraba States, the shape should be typical form northern Nigeria, common. Engravings on the blade were done by Fulani people - who also used this shape. 8th - Very common shape in Sahel, this one allegedly from Kano - Sokoto (?) The last one - first from the right: Allegedly Tupuri people speaking Laka language, willages Durum, Durubai, Tereki (Nigerian-Cameroonian borderland). Regards, Martin |
Hi Martin,
nice collection of spearheads and thank you for posting them.Kind Regards David |
