Old 7th March 2010, 01:19 PM   #1
Default Advice wanted
I have this keris since years, the blade have been very rusty, the sheat is missing it buntut and it haven't had a handle when I get it and the sheat was painted brown. Now I started to restore it, first I have cleaned the blade because I want to see if a restoration is worthwhile. The iras blade look good after the cleaning and so I cleaned the sheat also.
I am unsure if it is a pure Bugis keris since the gandar is very flat oval and so I want to ask you if you think that this very old sumatran ivory Jawa Deman handle would be adequat for this keris.
Second question, what do you think have to look the buntut? I want to carve a new one from black horn.
Many thank's in advance,
Old 7th March 2010, 02:38 PM   #2
BluErf
BluErf's Avatar
I think this is a Straits Bugis keris. A regular Riau-style jawa demam would be perfect.
The sheath would probably liven up after some oiling and buffing with wax.
The buntut can just be a flat simple oval piece that is slightly larger than the batang. If the inward taper due to wear and tear at the end of the batang bothers you, maybe you can have a silver buntut made with an extension to cover that part.
Old 7th March 2010, 05:59 PM   #3
Hello Kai Wee,
thank you very much. What you think about the hilt in the picture? And what you think about the pendokok? The problem is that the pesi is very large and this is nearly the only hilt I have in my collection which I can attach.
A flat buntut would be possible, I can cut the batang/gandar a little bit that the wear isn't visible anymore, the blade have enough place.
Of course the sheat will get a covering with shellac to come back to old glory. And the blade will get a decent stain.
Old 8th March 2010, 03:19 PM   #4
GIO
GIO's Avatar
Unhappy
It is a pity the selut is too big . The hilt is wonderful
You can find an image of a kris from Minangkabau with the same hilt and wrangka in Jensen's Krisdisk. (cap. 9.2 page 20 fig. 161 a).
Old 8th March 2010, 03:23 PM   #5
BluErf
BluErf's Avatar
well, the problem is I have never really seen what sort of keris sheath and blade goes with the hilt you have posted. so I'm not sure about it. Also, based on my experience, the regular Riau jawa demam should be ok, but you probably have to find one of sufficient girth. A taller pendoko could be useful in fitting the hilt onto the long pesi.
Old 8th March 2010, 05:27 PM   #6
I would say that if you were to use this hilt you would want to find a different pendoko anyway because this one doesn't seem to fit the hilt properly.
Old 8th March 2010, 08:22 PM   #7
Hello Gio,
thank's for the compliment about the hilt. I found a other pendokok for this hilt, picture will follow. The sheat in Jensen's Krisdisk is different, it a pure Minangkabau sheat.
Old 8th March 2010, 08:25 PM   #8
Hello Kai Wee,
you can show me which type of hilt you exactly mean? Thank's in advance,
Old 8th March 2010, 08:50 PM   #9
Hello David,
what do you think about this pendokok? It's very similar but a little bit more small in diameter.
Old 8th March 2010, 11:46 PM   #10
BluErf
BluErf's Avatar
It's this type.
Old 9th March 2010, 08:34 PM   #11
It's this type.
Thank's, now I know what you mean!
Old 28th March 2010, 08:55 PM   #12
The restoration of the sheat is finished. The last picture shows the keris with hilt. Until I don't have found a hilt like Kai Wee have shown this one will be the placeholder.
Old 28th March 2010, 10:34 PM   #13
danny1976
Hi Detlef,
Nice restore.
What did u use on the wranka , oil or lacker ?
danny1976 is offline   Reply With Quote
Old 28th March 2010, 11:36 PM   #14
Hi Danny,
thank's! It's shellac.
Old 24th April 2010, 11:33 PM   #15
It seems that the picture in #12 is gone by what reason however. So here again!
Old 25th April 2010, 02:26 AM   #16
BluErf
BluErf's Avatar
Proportion-wise, the hilt is too tall and colunmnar for the keris.
Old 25th April 2010, 08:34 PM   #17
You're right by this, when I look at the picture it's the same impression in my mind. Will look for a other one, the problem is the big pesi.
Old 8th September 2010, 10:23 PM   #18
I think that this is the best hilt from my collection I can give the keris.
What do you think?
Old 8th September 2010, 11:02 PM   #19
BigG
BigG's Avatar
Sajen, well done! That a very good effort at restoring your sheath. Your cross piece is made from very good kemuning wood. The grains and chatoyance is wonderful. Your stem is sena and is good too. It is a pity that you do not have access to good craftsmen where you are... Very good effort indeed.
I would like to suggest that instead of the rounded shaped that you have used for the Buntut, you should instead used the one shown below. It should follow the shape of and slightly bigger then the stem.
To help you you can refer to the photos I have included below. The bottom view is on the left and the side view is on the right..
BigG is offline   Reply With Quote
Old 9th September 2010, 09:14 AM   #20
BigG
BigG's Avatar
What do you think?
Under the circmstances... its great... congrats again for a worthwhile effort...
Old 9th September 2010, 02:16 PM   #21
BluErf
BluErf's Avatar
What do you think?
This looks great! Yes, keep it this way, Sajen.
Old 9th September 2010, 03:33 PM   #22
BigG,
thank you for your kind words! The Buntut is worked a little bit higher because I want to cover the wear at the end of the stem, look the pics in up.
When you look from down the shape followed the shape of the stem.
Old 9th September 2010, 03:39 PM   #23
Thank you Kai Wee!
Old 9th September 2010, 04:31 PM   #24
BigG
BigG's Avatar
BigG,
Rite its mor clearer now... good job...
