Old 25th January 2010, 02:06 PM   #1
Default Short Stabbing Spear - Tourist ??
Bought this cheaply .....believing it to be a tourist piece and judging by the patina mid 20th C onwards. Now I'm not so certain.
The spearhead is forged and has shoulders common to Zulu heads. It is very sharp ...but relatively thin (flat diamond cross section)The brass ferrule could be a short piece of pipe or even a bullet cartridge (has been worked with a file so no markings to confirm.) The 'dot' pattern on either end of the shaft is created by burning and has some carved grooves at the handle end. There are 'handling' marks/wear in places you would expect ...if used.
I wondered whether this could be 'better' than a tourist offering....although functional, it is not 'robust' enough to rely on in 'battle conditions'.....perhaps ceremonial ??
All comments good or bad, gratefully received, thank you
Regards David
Old 26th January 2010, 09:28 AM   #2
colin henshaw
Hi David
Its difficult to say for sure from a photo, but the spear looks like a modern functional piece, made for use in Southern Africa somewhere...
Colin
Old 26th January 2010, 01:47 PM   #3
Lew
Lew's Avatar
Seems touristy to me or maybe a dance spear? Still cheap is good.
Old 26th January 2010, 04:10 PM   #4
BerberDagger
BerberDagger's Avatar
I agree , for me is tourist item or for modern tribal use
BerberDagger is offline   Reply With Quote
Old 30th January 2010, 06:06 PM   #5
Thank you for your input Gentlemen ....and sorry for the late reply
Kind Regards David
