Old 26th November 2009, 09:53 PM   #1
KuKulzA28
KuKulzA28's Avatar
Default Rattan Care...?
How do you guys care for the rattan wrapping on handles?
Would linseed oil be fine? Rattan wrapping isn't really like wood...
Thanks!
Old 27th November 2009, 02:41 PM   #2
Nathaniel
Nathaniel's Avatar
Good question...this is something I would like to know as well for my dha handles...otherwise with time they dry out and become brittle.
At home we have an beautiful old Malaysian rattan basket...my uncle said soaking it in warm water would help to prevent it from cracking/ drying out...havn't worked the nerve up to do that yet though.
Old 27th November 2009, 03:27 PM   #3
PUFF
They way people in southern Thailand do is soaking them in drying oil (linseed, tung) then wipe them off and let them dry. This is enough to keep bamboo/rattan work for 10-20 years. After the oil dried, you may also wax them to give an extra protection.
Old 27th November 2009, 03:59 PM   #4
KuKulzA28
KuKulzA28's Avatar
But there the problem i the rattan getting too moist... where I am the concern is that it'll dry out, crack, and fall apart...
Old 27th November 2009, 05:49 PM   #5
Dimasalang
Dimasalang's Avatar
I also use linseed on strips of rattan but not a lot. Rattan soaks up oil easier and faster then wood. Soaking a rattan stick for long periods of time will make the stick last longer but will make it a lot heavier...on top of that, take a long time to dry, will always leak at the ends, always feel oily, and can make the stick too soft. Id suggest using linseed liberally on the strips...rub it in, let it soak just a bit(you can see it soak in), then wipe it off.
I met some Kendo practitioners who use linseed on their Shinai swords(made of bamboo). They don't soak it too long as it will get to heavy the longer it soaks and can offset the balance of the bamboo sword.
Dimasalang is offline   Reply With Quote
