Yesterday, I went to Brussels and found this piece on the Fleamarket : a Moro kris.
Don't know a lot about these weapons and I'm open to any suggestions. Probably has been repaired in the past. It has an interesting looking belt hook. Has anyone seen one before ? The blade itself has 13 curves. total length : 54 cm ![]() ![]() ![]()
I think the sheath is original.
The top of the handle shows some damage. ![]() ![]() ![]()
A NICE KRIS PROBABLY MADE FROM WW1 TO WW2 AND USED THRU WW2, JUST A GUESS. THE HANDLE IS LIKELY THE ORIGINAL BUT HAS BEEN STRIPPED THE STRAPS AND METAL FITTINGS MAY HAVE BEEN SILVER AND SOLD OFF OR LEFT LAYING AROUND WHEN THE OWNER COULD NOT GET THE MOTHER OF PEARL POMMEL CAP OFF AND BROKE IT. YOU CAN SEE THE MARKS WHERE THE WOOD WAS CARVED AS WELL AS WHERE THE OLD WRAPPINGS WERE AND THE GROOVE AT THE TOP WAS LIKELY TO HAVE HAD A METAL BAND AND PROBABLY ALSO A METAL FERRULE AT THE FORTE TO HOLD THE BACA BACA STRAPS. THE GANJA IS SEPARATE ON THE BLADE AND THE BLADE MAY EVEN HAVE A PATTEREN IF ETCHED, NICE FIND!1
THE KRIS GUYS CAN PROBABLY GIVE YOU MORE AND BETTER INFO ON IT.JOSE WOULD PROBABLY LIKE TO FIX IT UP PROPER
Bumping this old thread.
Any comments on the scabbard fitting ? It seems rather crude to me, but what kind of fittings would this type of scabbard have ? Best regards, Willem |
One scabbard half has a carved protrusion at the top to hold it in the sash.
This metal clip is new school . Pardon the rushed picture .
Thanks Rick,
New school, as in "too new" ? Or maybe even original to this scabbard ? I found this example of a "clasp" by Federico. Best regards, Willem Last edited by asomotif; 30th October 2009 at 08:16 AM. |
#7 | |||
Hello Willem,
Regards, Kai |
Hello Freddy,
Sorry, must have overlooked your original posting last year! Looks like a fairly typical late but still genuine Maguindanao Lanti to me. The asang-asang made from copper wire and the grip binding may be replacements. It may be worth to replace both if you still need a winter project... As discussed, the belt hook is atypical. I'd have no qualms to replace it with a band of woven rattan (if you do, also replace the lower rattan binding). Regards, Kai |
#9 | |
Thanks Kai for the interesting info and comments.
Look good already!
WOnderful! any updates on this project?
#12 | |
#13 | |
I am up to the point where I should wrap the hilt with rope. I am mentally preparing for that job this might take some time.
Any more updates? I'd love to see the end product! Also, who did this? It's wonderful, but looks different than Jose's work (who seems to draw inspiration from historical use of okir designs embossed into his silver fittings rather than the simpler lines embossed on the silver fittings put on this one.)
I am used to seeing Jose's metalwork used for restorations like this (and have had him do wonderful silverwork on a punto for a Barung of mine. Great work!). I do know that Philip Tom does restorations on Moro pieces, but have only seen his carving work as opposed to any metal fittings done by him. Maybe it was done by someone else? I am very curious! I'm also resurrecting this thread in hopes of getting ideas for a similar hilt for a newly-made maguindanao blade I have and want rehilted. I'd like one of those flat-pommeled grips like these ones. Did these ever have Horn caps or were they mostly Ivory and Mother Of Pearl? Here's some pictures for inspiration/reference that I'm using Any suggestions? Last edited by ThePepperSkull; 1st August 2012 at 10:03 AM. |
