Old 7th October 2009, 05:25 PM   #1
Default Small Dha
Hello Members,
I get some years ago this Dha as present. Since this is not my area of collecting i wish to get some further informations about this dagger. All informations about origin, age and quality would be very appreciated. It is 44 cm complete with a blade from 25 cm. Thank you very much in advance.
sajen
Old 7th October 2009, 10:23 PM   #2
Henk
Henk's Avatar
The dafioso will share their knowledge with you.
Very nice dha with age. Thanks for sharing.
Old 8th October 2009, 01:09 AM   #3
Thank you Henk.
regards,
sajen
Old 8th October 2009, 04:17 AM   #4
Nathaniel
Nathaniel's Avatar
How thick is the blade?
I believe this is a Kachin style from northern Kachin state of Burma.
Old 8th October 2009, 11:11 AM   #5
Hello Nathaniel,
the blade is 7 mm thick at the handle. Thank's for answer.
sajen
Old 9th October 2009, 05:54 PM   #6
Mark
Mark's Avatar
Actually, this is a Shan dha hmyaung. We used to call the style "Metro Kachin," but subsequent research pointed toward Shan/Tai (Shan State in eastern Burma, or northern Thailand).
Age is very hard to estimate, but it likely is early 20th or later 19th century. The quality looks quite good.
Old 9th October 2009, 06:13 PM   #7
Thank you Mark for your precise completion.
sajen
Old 10th October 2009, 05:07 AM   #8
Nathaniel
Nathaniel's Avatar
I sit corrected Thanks Mark for the further clarification
Old 10th October 2009, 10:52 AM   #9
Thank you both!
Old 13th October 2009, 04:24 AM   #10
Andrew
Andrew's Avatar
I think you're missing a fair amount of silver from the fittings. The grip section of the handle probably had silver mesh or, perhaps, rattan rings.
Old 13th October 2009, 12:22 PM   #11
Good possible but then this is missing longer because the patination on the wood is old. Thank you for the hint.
sajen
