Old 10th September 2009, 01:06 AM   #1
Nathaniel
Nathaniel's Avatar
Default Burmese Dha/ Thai Daab...why Guardless????
Hello all,
I think this is kind of a basic question...but I was wondering if it has ever been questioned why Daab/dha do not have a guard to protect that hands?
Plus just the over all question of the functionality(I think I made my own word) of guards...some are very small...such as those on Chinese jian...others cover the whole hand.
I just thought I would pose this question to see what people think
Old 10th September 2009, 01:38 AM   #2
Atlantia
Atlantia's Avatar
Originally Posted by Nathaniel
Hello all,
Hi Nathaniel,
Very good question.
I'd always assumed that its because the 'fencing' style of these weapons doesn't call for blocking in the 'western' sense (I use inverted commas ther because I do realise how inapropriate the term is), but blocking by allowing the opponents blade to run up the length of your own until it hits the guard allows you to deflect their lunge while aiming your own counter-attack.
Its a really classic move in western fencing, the point of their blade goes past your shoulder while you (at the same time) step/lean into their attack and land the point of your sword square in their chest/throat.
I'm going to look a prize one if I've got this totally wrong but I'd always assumed the style for the weapons you mention is a 'closer' pull-cut form, so a guard could almost be a hinderance?
Old 10th September 2009, 02:03 AM   #3
aiontay
In some cases they were also used like machetes as much as fighting swords, and on utility blade a big guard isn't that useful. It might be a hinderance since it would catch on the vegetation. This would be especially true among many of the tribal groups. Among the Thais, Burmans, Shans etc you would have more blades functioning exclusively as weapons.
aiontay is offline   Reply With Quote
Old 10th September 2009, 02:43 AM   #4
Nathaniel
Nathaniel's Avatar
UK series called Mind, Body & Kick Ass Moves on Krabi Krabong
http://www.youtube.com/watch?v=XSpfAg0vajY
They talk about edge to edge blocking...
Old 10th September 2009, 03:08 AM   #5
fearn
Hi Aiontay,
I'm not sure about the bit about a guard. I've got a woodsman's pal with a D guard, and it's sure handy around blackberries.
That said, I think Atlantia got it right in part. The Thai style for fighting is much more like stick-fighting, and they parry with the blade.
That said, let's step back a sec. Not that many blades have guards, and not all guards are guarding the hand. If you think about it, the hand-shielding guards got best developed in post-Renaissance Europe, and on Chinese daos to a lesser extent. As for the second, guards can also serve to shield the blade from rain by sealing the top of the scabbard (as with the jian), serve as finger hooks (European and Indian swords, and the sai), or serve as secondary attacking points (the long cross-guards on knightly longswords and greatswords for example). It's worth remembering that European swords started with simple cross-guards (symbolic, and good for punching when you get caught inside), and many people actually looped their fingers over cross-guards, rendering the guard essentially useless. The crossbars of later guards were added to this basic design to protect that vulnerable finger.
So, why not more guards? Part of the reason is about tuning the sword. This is about hand-shock. Swords flex when they hit things, and like any bar (or string, for that matter) there are nodes (where the vibration is zero) and anti-nodes (where the vibration maximizes). One typical node is the end of the sword, and that's where most people hold most swords. Another node is in the middle. Antinodes tend to be around the 1/4 and 3/4 points.
Dhas solve the vibration problem another way, by lengthening the hilt so that you can hold it by the base of the blade and you will be holding it at a node. That's why, in many cases, the hilt is almost as long as the blade. The 1:1 ratio makes it easy to minimize vibration at the middle. The pommel also helps with this tuning process, and that's why (I think) many of the dhas with shorter hilts have bigger pommels. They're tuning the blade so that it's comfortable to chop or slice with.
Now, you introduce a cross-guard (or something more complex), and the vibrational situation gets that much messier, because the guard is vibrating too. It's possible to have a long hilt and a complex guard--Renaissance great swords do it--but it's not that easy. If you think about it, most European swords with complex guards have really short hilts, and part of that is to minimize the hand-shock while using the blade.
So it's a trade-off between two types of safety: guarding the hand against attacks, and guarding it across the shock (and pain) of blade vibration. AFAIK, the people who developed the dha thought it was simpler to train people to keep others' blades away from their wrists, whereas westerners learned to love punching with the hilt, and developed the guard around that function.
That's my story, and I'm sticking to it.
F
PS: I learned about hand-shock by reading, and also by trying to make a "Dha" out of a cut-down machete blade. From that experience, I can tell you that the length of the hilt does have a huge affect on how much shock your hand feels. Get that length wrong, and it hurts to cut with the blade.
Old 10th September 2009, 03:59 AM   #6
aiontay
Fearn,
I don't doubt you're right, but part of the problem is maybe we're trying to cover too much ground with the term. If, as I said, you're talking about the more overt weapons that would be owned by upper class Burmans, Mons, Shans, Thais etc that is one thing, but a Karen of Kachin blade, or even those owned some Northern Thai farmer called up to go fight Chiang Tung?
While guards on any knife are useful, many utility blades tend not to have substantial guards. Of course, there's always something like a Woodsman's Pal. On the other hand, guards can get in the way, and not just in bushes. I remember stopping in a Lahu village on a trip with some Lahu pastor friends on a trip along the Thai/Burmese border, and the village headman peeled us a cucumber using, not a dha/daab, but a big field knife about the size and shape of a Roman gladius, but single edged. He choked up on the back of the blade and held rest of the blade and handle up along his forearm. I'd have gotten a much smaller knife, but hey, they liked big blades up there. A guard would have probably complicated the peeling procedure. I doubt Naresuan or Alaungpaya did a lot of cumcumber peeling with their blades, but some of their soldiers probably did, and more of it than cutting down enemy soldiers.
One other consideration, at least further up in the hills is that in the past metal wasn't exactly plentiful so there is an economic trade off as well. It seem a lot of backwoods blades, wherever the backwoods are, lack guards, and I suspect that might be in part due to the relative scarcity of metal, and the lack of technical expertise to get the fine tuning you talk about Fearn. It would be easier and cheaper to forgo the guard and lengthen the handle.
Finally, based on the little Krabri Krabong I did, I didn't see a whole lot of pull and cut. Yes, it is there, and the style of blade certainly facilitates it, but there was also a whole lot of straight-ahead nasty full power swings and chops, stuff that looked like you'd cut through an elephant (which they had to do back in the old days). It could have just been my instructors, but I always found it a bit too open and straight ahead for my taste. One day one of my instructors, sort of on a lark, came at me unexpectedly. I hadn't told him of my FMA background, so I think he was rather shocked when I zoned to the side and ended up behind him. Even though we were using rattan practice swords I was in position to deliver a decisive blow, but he was my teacher, so I just stood there and we went back to what we were training. However, if I were outside the walls of Chiang Mai with a few thousand other guys fighting for our Thai or Burmese overlord (depending on the time period) against a few thousand invaders with hundreds of elephants, a style that pretty much cuts through anything in front of it would definitely be my choice.
Like I said, I didn't do that much training in Thai or Karen sword fighting, so someone with more experience would be great to hear from on how the blades should be used.
Old 10th September 2009, 04:19 AM   #7
fearn
Hi Aiontay,
We pretty much agree. I'd note that, for chopping, hand shock really, really matters, and it's easier to make a new wooden handle than a new metal blade. I'm guessing for the hill tribes (who like the long hilts), on a simple, wooden-hilt dha, they'd probably start with too long a hilt and cut it shorter until they got it right.
As you noted, a simple, guardless design is more versatile than (most) guarded blades.
Finally, it's not hard to tune a simple, straight blade. All you have to do is find the sweet spot and tap it on something, and move your hand up and down the hilt until you're comfortable.
With something that's curved or odd-shaped, it's going to take more work to get everything right.
F
Old 11th September 2009, 04:30 AM   #8
DhaDha
For reference, here are a few more videos showing some other techniques/styles from the region.
1.
http://www.youtube.com/watch?v=GVlV7Qnncmc
2.
http://www.youtube.com/watch?v=kKsuj...eature=channel
This whole video is great, but they start the sword techniques about half way through.
3.
http://www.youtube.com/watch?v=uV_w7...eature=related
Cheers
Last edited by DhaDha; 11th September 2009 at 04:43 AM. Reason: Finally made the links work.
Old 11th September 2009, 05:15 AM   #9
Nathaniel
Nathaniel's Avatar
Thanks for your comments guys....any others want to weight in???
How about the Dha Fathers...Ian...Andrew...Mark???
Old 11th September 2009, 05:36 AM   #10
Nathaniel
Nathaniel's Avatar
Nice video's Shawn,
Here are some Burmese ones to toss in too...one of my favorite:
http://www.youtube.com/watch?v=Anz3r...eature=related
http://www.youtube.com/watch?v=RlpamOnORoI
Burmese line dancing... :P
http://vids.myspace.com/index.cfm?fu...oID=2029653955
Old 14th September 2009, 05:03 AM   #11
Nathaniel
Nathaniel's Avatar
Any other thoughts anyone why the lack of guard with thai/ Burmese swords?
Old 14th September 2009, 11:22 AM   #12
Chris Evans
I don't know how relevant this is in the context of Thai/Burmese sword play, but Egerton Castle argued that European swords were originally thought of as weapons of offense and only during the renaissance did this attitude change. It follows that the complexity of the hilt was a good indicator of the degree of defence expected from the blade and furthermore the coverage afforded by the hilt also offered a clue to the "tightness" of the prevailing swordplay. According to this thesis, as fencing evolved, so did hilts.
I have seen Thai fencing and swords, but am totally unsure as to how the modern forms would compare against their classical era. I was told in Thailand by a professor of antiquities that their now traditional swords were modelled on the Japanese blade, but were furnished in accord with local tastes. My guess is, and that is all, that most of their old swordplay would have been in single time, relying on bodily evasion or armour for defence and the sword was used primarily for attacking.
Cheers
Chris
Old 18th September 2009, 03:33 PM   #13
Mark
Mark's Avatar
A very interesting question. One thought I had was that it could be an historical accident, a consequence of the evolution of the dha from a mixed utility tool to a pure weapon. As some have pointed out, a guard might get in the way on a blade that is primarily a tool (like a machete). The dha is not alone in being a sword evolved from a mixed-use tool, and lacking a guard (some parangs come to mind).
No one has mentioned the other protective function of a guard - to keep your hand from slipping down the blade in a thrust. In that context, the lack of a guard is not so surprising because a dha is/was used almost exclusively as a slashing weapon, like a shashka (which also lacks a real guard).
Old 15th February 2010, 12:54 PM   #14
PUFF
I do agree with Mark in many points.
The sword and fighting style might be co-evolved from machete origin. And, somehow, using of guard was discarded.
You may notice from many fighting demonstrations that Thai daabs are mainly for slashing. And they use more parrying techniques than just blocking.
http://www.youtube.com/watch?v=qkpz5jPLfe0
Old 24th February 2010, 02:09 AM   #15
Nathaniel
Nathaniel's Avatar
In the one BBC documentary, Mind, Body, Kickass moves, they have an episode on Krabi Krabong. In the part on Krabi (sword) part they talk about the thai style using the sharp edge of the blade to attack and block...see the video below at 2.19min
Old 24th February 2010, 05:50 AM   #16
Andrew
Andrew's Avatar
Cool
Great thread.
There can be no doubt that the swords (and therefore, the arts that used them) of mainland SEA were used primarily to chop and, especially, slash. They are those types of swords.
Additionally, I have handled perhaps 50 examples that clearly demonstrate edge-on-edge parry/bock damage. Many have been repeatedly repaired.
