Old 11th August 2009, 03:03 AM   #1
kahnjar1
kahnjar1's Avatar
Default Large Jambiya for comment
Just finished on epray and on its way to a new home down under. A large Western Arabian Jambiya from from Hijaz/Asir region and dating to the late 19th or early 20th century. Overall 560mm or 22'' depending on way of thinking. Pics from seller.
Regards Stuart
Old 11th August 2009, 05:17 AM   #2
Nathaniel
Nathaniel's Avatar
Nice new piece, Stu! Thanks for sharing!
Old 11th August 2009, 06:05 PM   #3
Michael Blalock
Michael Blalock's Avatar
Nice complete example.
Michael Blalock is offline   Reply With Quote
Old 11th August 2009, 06:52 PM   #4
colin henshaw
Very good example...
Old 12th August 2009, 06:07 PM   #5
Atlantia
Atlantia's Avatar
Hey Stu.
What a beast that is!
I'd love to get 'hands on' with it and feel what the weight and balance is like.
Congratulations. Hope you'll post some more pictures when it arrives.
Gene
Old 12th August 2009, 06:56 PM   #6
kahnjar1
kahnjar1's Avatar
Originally Posted by Atlantia
Hey Stu.
Gene
You will have to make a trip to the "colonies" at some stage. Will certainly post more pics when it arrives.
Stu
Old 12th August 2009, 10:47 PM   #7
graeme gt
Hi Stuart ,i think it is Wahabite i have one very similar will post pics tomorrow when battery is charged .
graeme gt is offline   Reply With Quote
Old 13th August 2009, 06:05 AM   #8
kahnjar1
kahnjar1's Avatar
Hi Graeme, Wahabite is only one of the tribes who use/used these big blades. There are many West Arabian tribes who used them I have always regarded the term Wahabite as one used by collectors to describe this type. They are more correctly called either Sabak or Sabiki. Refer Elgood Arabian Arms and Armor.
Regards Stuart
Old 13th August 2009, 07:51 PM   #9
graeme gt
Hi Stuart ,i bow to your superior knowledge here are my two hope you find them of intrest cheers G .
Old 13th August 2009, 07:55 PM   #10
TVV
TVV's Avatar
Very nice acquistion Stuart!
Graeme, the lower and smaller one of your jambiyas has been identified as coming from Asir, which prior to the Saudi conquest, was part of Yemen. So actually, this jambiya likely belonged to someone whow as resisting the wahabits. Assuming of course it dates back to the first half of the 20th century.
regards,
Teodor
Old 13th August 2009, 08:02 PM   #11
graeme gt
Big one is 26" long
Old 13th August 2009, 10:38 PM   #12
Atlantia
Atlantia's Avatar
Interesting contrast between these similar pieces.
I notice Stuarts does not have the central rib, and I've been trying to see if the blade has a thickened tip?
Also Graemes, whilst having the central rib, has incised decoration cut into it, similar to that on Stu's.
Are these two similar but distinct 'styles' indicative of specific respective areas, or timeframes, or are their differences purely 'coincidental' manufacturing choices of their makers?
Old 14th August 2009, 07:48 AM   #13
kahnjar1
kahnjar1's Avatar
Hi Graeme and Gene,
The lower one is very similar to one of mine, which according to Elgood is from the Asir/Hijaz region, and dating to the 20th century, Bani Malik and Bani Shahr Tribes.
The upper one appears to be from the Hijaz region, and my guess would be 20th century.
As far as the blades of these particular long bladed Jambiyas are concerned, I have always believed that the flat blades are of earlier vintage than the ribbed ones, but that is only my opinion based on the viewed age of the total piece. I have used as "rule of thumb" that flat blade is 19th or very early 20th century and ribbed a little later. I have nothing concrete to base this on other than gut instinct. Perhaps others here can elaborate.
Nice pieces Graeme.
Regards Stuart
Old 14th August 2009, 11:59 AM   #14
Michael Blalock
I have assumed the ribbed blade vs. flat blade is a regional issue, with the flat blades coming from the North and the ribbed blades coming from closer to the Yemen but that is just speculation too.
Old 14th August 2009, 12:13 PM   #15
kahnjar1
kahnjar1's Avatar
Quite possible I suppose, although Elgoods book shows both blade types as Asir/Hijaz regions, the overall area covering quite a large chunk of the Western Arabian coastline.
Thought the pic might be of interest. Its from Elgood book and shows these Jambiya worn by some of the "gentlemen"
Regards Stuart
Old 14th August 2009, 03:02 PM   #16
Oriental-Arms
Oriental-Arms's Avatar
Default Flat or ribbed blade
Originally Posted by kahnjar1
Hi Graeme and Gene,
Nice pieces Graeme.
Regards Stuart
I am afraid I have a slightly different opinion. From my experience, the ribbed blades are of better quality and earlier to the flat blade, but I also can not substantiate it.
Oriental-Arms is offline   Reply With Quote
Old 14th August 2009, 03:27 PM   #17
Lew
Lew's Avatar
I agree with Artzi on this forged ribbed blades need a high skill level to create the flat ones seem to appear after WW1 Stuart's piece seems to fit in between 1920-40. I have a similar one but a bit more worn. I included a pic of a large jamibiya with a 24" blade whick I am pretty sure is late 19th century?
Old 14th August 2009, 03:34 PM   #18
trajan
Default jambiyas
I agree with Oriental Arms.
I had 4 of these. The largest I have sold and is not pictured. It had a flat blade and no fullers. Exterior looked the same but blade was far inferior to the top 2 pictured.
The two larger pictured both have fullers/ribs and fine quality blades.
The bottom piece I believe would have been a boy's as its very small for these. It is flat with poorer decoration and weak fullers .
I've always enjoyed these big types too!
matt
trajan is offline   Reply With Quote
Old 14th August 2009, 03:45 PM   #19
Lew
Lew's Avatar
Some of these jambiya have a small zipper compartment on the inside of the belt mine has a YKK zipper.
In January 1946 the company registered the now famous YKK trademark. A major technological change came in 1950, when the company purchased a chain machine from the U.S. that allowed the automation of the zipper making process. Previously, YKK zippers were made by hand, and hence had an superior quality compared to zippers of water.
So it seems that a lot of these Asir jambiya we see today are from 1940s-60 with some older ones popping up now and then that are pre 1918.
Lew
Old 15th August 2009, 05:00 AM   #20
kahnjar1
kahnjar1's Avatar
Thanks Artzi for coming in on this discussion. I have no doubt that you have done more study than the rest of us as this is your business. We can only be guided by publications, such as they are, about these weapons. I can see that flat blades would be easier (and cheaper) to forge than ribbed ones. From that point of view, my train of thought was that the EARLIER ones would be flat as the forger would perhaps not been exposed to the technology required to make the ribbed version. I guess we will never know for certain but I am finding this discussion extremely interesting. As I have said before on this Forum, we are all still, and always will be, learning.
Just to add a little more, here are some pics of the rest of my long Jambiyas. The one with the "Sudanese type" hilt has been rehilted at some stage but the whole item shows good age, so it is not a recent happening.
Regards Stuart
Old 15th August 2009, 12:39 PM   #21
Lew
Lew's Avatar
Regards Stuart
Stuart
Sorry but I think you have this backwards? The forged rib has was developed to help pop open chainmail links (armor piercing) which makes the technique quite old. The flat blade was easier to make and required less skill to produce and many newer smiths post 1900 just did not the skill to produce the forged rib. Maybe the technique was just lost as the older smiths died off and they and for some reason did not have an apprentice to pass it on to. After oil was discovered I'm pretty sure that the old art of blade forging started to die out because the sons of these old smiths could make more money in the different areas of the oil business and related areas.
Lew
Old 15th August 2009, 10:10 PM   #22
kahnjar1
kahnjar1's Avatar
Thanks Lew, and I see your reasoning. My thinking has been based on the apparent older look to flat bladed items I have come across.
Some of the (particularly) Yemeni items around even have the blade made in two halves and spot welded together. YUK!! Potential buyer beware!
Old 16th August 2009, 02:05 PM   #23
Jeff Pringle
Jeff Pringle's Avatar
The forged-in ribs that Artzi is referring to should not be confused with the ground-in double fullers that are relatively common and very 20th century. The one jambiya of this type I’ve seen with a wootz blade was flat, neither ribbed nor fullered, and to confuse matters even more, was in a leather-covered scabbard with both authentic use-wear and bright plastic decorative trim. The Arabian peninsula is an unusual place, in that they had a very late surviving ethnographic weapons tradition and then a very rapid conversion to modern materials & decorative/tourist-grade blades - it makes for some interesting juxtapositions.
