Old 27th July 2009, 02:20 AM   #1
M ELEY
Default Hand cannon ended on eBay
http://cgi.ebay.com/ws/eBayISAPI.dll...m=290328487119
Well, after Fernando and Matchlock have been wetting my appetite for one of these, I finally found one I was considering on bidding on. Problem was, it was a priviate auction and I've heard others to stay clear of these, especially from over-seas. I passed, and I guess everyone else did as well. This seller had a ton of signal cannons for sale and not one was bought. Hmmm...
Anyway, seemed like a legit piece, if mismarked. This isn't a signaller, is it?
Old 27th July 2009, 04:17 PM   #2
Hi Mark,
You are most probably right in that it doesn't look like a signaller but, instead, a 'stockable' cannon, as shown by its shape. It looks like the real thing, and a nice one by the way but, no doubt Michael's opinnion is vital, as he has a clinic eye for these things .
BTW, how did the guy know this has an Austrian origin .
Fernando
Old 28th July 2009, 05:01 AM   #3
M ELEY
Perhaps the cannon spoke Duetche?
Thanks for responding, Fernando. I was going to bid on this item, but I'm told private auctions should be avoided, although I'm not quite sure why? He seemed to have positive feedback, but NONE of his cannons, swords, etc, sold. Very curious.
So those with this shape that are not signallers are mounted on a stock vs what type mounted on a solid base?
Old 28th July 2009, 02:15 PM   #4
Hi Mark,
Eventually i don't share eBay problematics, i am not even registered .
Well, you don't actually need to mount signallers; you just place them loose on a (reasonably) flat surface, and they stand upright by themselves. Having no projectile to be directed to a target, you convenientely fire the thing vertically, throwing the noise and flame up in the air. So they are either conical in profile, or (mostly) tend to have a widened (rimmed) base, to provide a certain stability. This is why often signallers (or noise makers) touch holes have a sort of lip or pan, where you deposit the priming gunpowder.
I hope i haven't spoken much nonsense, or Michael pops up and hits me .
Fernando
Old 28th July 2009, 03:11 PM   #5
Matchlock
Matchlock's Avatar
Hi Mark and Fernando,
First of all I guess that the seller thought that barrel was Austrian because unbelievably large numbers of these are still around in both Bavaria and Austria, where they are often employed as door stoppers in old houses. Forget about his tentative dating 'ca. 1750' though.
I attach the images for documentary purposes as they will not be around on Ebay for too long.
Secondly, Fernando is perfectly on the right track and made the final note by pointing out that the barrel was staged and the heavily swamped flat muzzle section would make an ideal land mark for the fore end of a stock.
Thirdly, before probably being around as a signaler and door stopper for two or three hundred years that barrel was definitely stocked and used for 'serious' purposes at the earlier stages of its working life which may have started as early as the 1440's!!! The small touch hole near the rear end and the large, flat muzzle head perfectly fit that Hussite Period.
Something very rarely found on early wrought iron barrels are the hammered longitudinal decorative grooves between the edges.
I include a scan of a similar barrel retaining its original stock and looped hook, now preserved at the Czech Military Museum in the Hradčany Castle Prague.
Michael
Old 28th July 2009, 04:05 PM   #6
Oh Mark, what you have missed .
Fernando
Old 28th July 2009, 04:25 PM   #7
Matchlock
Matchlock's Avatar
Slowly, Fernando,
All my judging was done on the basis of some very poor 10 kB images.
I just noted what seems to be a series of punched quite modern A's on the side towards the muzzle. We must not forget that all the early forms were repeated in the Historismus period of the second half of the 19th century - and what if this is not wrought iron but 19th c. cast iron?
Always be careful, especially with poor images.
Michael
Old 30th July 2009, 03:57 AM   #8
M ELEY
Ha ha! Right back at ya, Fernando!
As a novice in this area, I am learning much from both of you. I still wasn't sure it was a legitimate auction, even if the piece were from the proper period, so it is just as well that I passed it up. I'm still on the path to learning when it comes to these.
Michael, you mention that these were made in the 19th century to resemble the older pieces. Was this done as a sort of salute to the old (such as Victorian swords designed to look like the earlier 15th-16th c. pieces were) or as a total con (such as fake 19th c. Egyptian ashrubi handed out to infatuated collectors were)?? I'm interested to hear about this revival and how does one really differentiate between cast and wrought iron (other than obvious casting line and flaws)?
Old 30th July 2009, 12:27 PM   #9
Matchlock
Matchlock's Avatar
Hi Mark,
Yes, the German Historismus was just the same movement in literature, arts and crafts as the English Victorian age and the époque Viollet-le-Duc in France. All these 19th century art forms took up the pure styles of earlier ages, copied them and mixed them up - the outcome were 'fantasy' trends like the Neo-Gothic and Neo-Renaissance periods.
And: yes, I think you mentioned the only ways to tell cast from wrought iron.
Michael
Old 30th July 2009, 02:10 PM   #10
M ELEY
Thanks for the explanation, Michael. One final question on this piece. Do the series of punched letters automatically point to a more modern manufacture on these pieces, meaning earlier pieces will not be so marked? Or is it that the "A's" appear to be a more modern print of this type? Thanks,
Mark
Old 30th July 2009, 04:35 PM   #11
Matchlock
Matchlock's Avatar
You're welcome, Mark,
In my experience, this print pype of the letter A come only in use in the late 18th century. Using a series of it as a kind of deoration seems very awkward to me.
Michael
Old 30th July 2009, 05:59 PM   #12
Spiridonov
Spiridonov's Avatar
Do you have more information about this gun? I interesting in calibre and barrel length ont another photos.
Old 31st July 2009, 06:36 PM   #13
Matchlock
Matchlock's Avatar
O.k., here we go:
Photos I took of the Prague haquebut and the measurements:
Overall length 135 cm, barrel length 41 cm, cal. 36 mm.
Michael
Old 31st July 2009, 07:07 PM   #14
Spiridonov
Spiridonov's Avatar
Thanks. It is a very beutifull barrel Maby you had mean 26 mm?
Old 1st August 2009, 02:19 PM   #15
Matchlock
Matchlock's Avatar
Hi Spiridonov,
In his 1998 book Illustriertes Lexikon der Handfeuerwaffen, Vladímir Dolínek, the curator in charge of the military museum Prague, states on p. 22 that the caliber of this gun is 36 mm.
Looking at the general proportions, though, I must say you may be right as it seems rather like 26 mm.
Michael
Old 3rd August 2009, 09:24 PM   #16
Spiridonov
Spiridonov's Avatar
What is the nail behinde the touch hole of this barrel?
Old 4th August 2009, 05:02 PM   #17
Matchlock
Matchlock's Avatar
Honestly, I have no idea.
As it is nailed in too deeply no swiveling pan cover could have been possibly fixed there though.
Michael
