Old 24th June 2009, 08:42 PM   #1
Warren McQ
Default Pesh, Choora ???
Hi All,
Here's my latest find, I'm not sure if you'd call this a Pesh or A Choora.
I'm still learning. The blade seems to have some pattern but I haven't tried an etch yet as I wanted to ask you all the best way to do it.
I'm not sure of the handle material or even the age of the knife.
Any help would be appreciated,
Thanks Much,
Warren in Arizona
Warren McQ is offline   Reply With Quote
Old 24th June 2009, 09:04 PM   #2
Atlantia
Atlantia's Avatar
Hi Warren,
Looks Afghan a Choora. Doesn't look terribly old, but it is rather well made. Like the brass sheet scabbard as well!
Gene
Old 24th June 2009, 09:13 PM   #3
Warren McQ
Thanks, Yes, it does seem well made and I'm not surprised that it may be fairly young. It measures 7.25 inches for the blade and 11.5 inches overall.
I seem to remember reading that the smaller these knives are the more recent the manufacture.
Warren in Arizona
Old 24th June 2009, 09:21 PM   #4
Atlantia
Atlantia's Avatar
If it were me, I'd leave the scabbard as-is and then I'd polish up the metalwork/blade on the dagger with 1200 silicon carbide paper. Possibly try some lemon juice on it, then just let it dull down.
Love the T section armour piercing blade design on these, totally rigid, will split chainmail or pierce most clothing and light armour, force ribs apart etc. A real little killer!
Old 24th June 2009, 10:12 PM   #5
Hi Warren,
I would definately give the blade an etch, there does seem to be some 'patterning' in certain areas....could just be the photographs.....but then again, nothing ventured ..nothing gained. I'm beginning to wonder whether this is a re-hilted example with a older, 'cleaned' (read heavily scratched with grit that was too coarse ) blade.
fingers crossed
Regards David
Old 24th June 2009, 10:25 PM   #6
Atlantia
Atlantia's Avatar
Originally Posted by katana
Hi Warren,
fingers crossed
Regards David
Good point David,
Always hope, just look at that 'bowie' I etched! You never know....
And anyways, the proper finishing will definately improve the dagger
Old 25th June 2009, 08:10 AM   #7
Warren McQ
Thanks Guys,
Yes, I do see a pattern in the blade so I'm going to do an etch ASAP to bring out the , what I think is a Wootz pattern. I'll try to post some better pics in the morning.
I don't know how we could ascertain whether this is an old blade that's been re-handled,
Any Ideas ??
Warren in Arizona
Old 27th June 2009, 01:20 AM   #8
Sikh_soldier
Hi warren,
You have a very nice, clean example of a Choora, I had a similair one (now sold) and I too did not know what the handle was made out of, someone had suggested plastic, but there was areas near the pins that held the handle where the rust had bled into the handle and discoloured it, I did not think that this would happen with plastic but only bone.
if bone does any of the forum members know what type of bone?
Bally
Sikh_soldier is offline   Reply With Quote
Old 27th June 2009, 08:23 PM   #9
looks like a slightly less decorated version of this one. 13" overall in scabbard, out it's 12" overall (8" blade, 4" handle)
camel bone is a popular knife scale material, it can also be dyed to just about any color, stained heat treated (scorched) and carved to look like stag or impala horn, etc. giraffe bone is another, probably not found in afghan circles. maybe sheep, goat, camel, horse... and of course the 'I' word which i shall not apply to mine.
Old 28th June 2009, 04:30 AM   #10
Warren McQ
A little update on this knife,
I've tried etching the blade with warm vinegar without much luck.
there is a pattern visible under 10X so I'll have to try something more aggressive.
The grip material is definitely synthetic, it smells like celluloid when rubbed.
All in all I'm still very happy with this knife.
Thanks to all for your help and interest,
Warren in Arizona
Old 30th June 2009, 05:31 AM   #11
Andrew
Andrew's Avatar
Warren, you might try polishing out the grind marks in that surface before etching--until you do, I don't think you'll pull out any characteristics of the metal.
I'd try very, very fine grit wet sandpaper. You can pick up the kind I'm talking about at a hobby shop.
Go slow.
Old 30th June 2009, 03:43 PM   #12
Terms, it's always terms .
Are they one and the same; Pesh and Choora ?
Or are they different forms ?
Pesh or Choora ? :
http://www.vikingsword.com/vb/showth...ighlight=karud
Old 1st July 2009, 10:34 AM   #13
i've always thought the top straight style was 'choora' and the curved bottom as 'pesh', with the larger form of the upper one as 'karud'.
of course, it's be nice to know what the ones who actually made & used them called them. (it would probably meant 'knife' )
i did a google for 'choora' and ask.com came up with a definition of "A slur for dark skinned people in Pakistan". it is also a sikh wedding ceremony where decorative red (coral) & white (bone) bangles are tied to the bride. kinda like my iv..er bone and coral beaded 'choora'
is it possible the smaller decorated versions are thus ceremonial (tho deadly) wedding versions similar to wedding nimcha? the groom might want to carry around a smaller version on such a day rather than be encumbered with the full larger kit of karud and salawar, but being the khyber area, one would also always want to be armed.
Old 1st July 2009, 11:33 AM   #14
Sikh_soldier
Hi guys,
kronckew in regards to the Choora definition you found on Google, that is indeed a term for people belonging to the caste of choora, but that is pronounced differently from the dagger, that is pronounced Chooora where the dagger is Churra.
I showed a friend of mine my Choora dagger, he does not know anything about edged weapons but he is from the tribal regions of Afghanistan/Pakistan, and he told me that in the language they speak, Choora (pronounced Churra) means big knife, whereas if his mother asks him to pass a small kitchen knife she says pass the Churri (feminine).
And he told me there is no link to a caste, a derrogatory term or anything else it just means Knife.
Hope this helps
Bally
Old 1st July 2009, 12:18 PM   #15
as suspected, it's a 'knife'
we as collectors are a lot more anal about assigning labels, which tend to gather momentum as more people use them, gaining a life of their own to the point where if i were to call it a 'pisau' (also essentially means 'knife') i'd provoke a storm of comment. i imagine a 'normal' (non-collector) native from the area would if shown a 'choora' would still call it a 'pisau'.
Old 1st July 2009, 02:34 PM   #16
Smile Name Games
Okay , so this is a Choora also; not a Karud as I have assumed ?
If not, then what's the defining factor ?
So frustrating .......
Old 1st July 2009, 02:38 PM   #17
rick has culture shock.
a rose by any other name....
(i'd call yours a karud, but i'm not a pashtun - anyway it (karud) probably means 'bigger knife' )
no relation to a karuda bird either.
Old 1st July 2009, 02:47 PM   #18
Atlantia
Atlantia's Avatar
ooh, dont these threads bring out the pedant in us all?
I always (probobly wrongly) assumed that Kard is the route of Karud which is the T spined, but still straight bladed evolution of the route type, like the one Rick has shown a rather fine example of, while when that blade becomes wider and curved it becomes the Pesh kabz.
I always call the 'Karuds' which are the more 'jagged' Afghan type like Warrens 'Choora's'.
Hmmm, makes ya think it does....
Old 1st July 2009, 02:58 PM   #19
Cool
Okay ..... that's it !
My new list of Afghan choora/pesh/karud terms :
Small knife.
Medium knife.
large knife .
Old 1st July 2009, 03:16 PM   #20
and lest we forget, there is the
"extra large" knife
and is this 'small knife' a choori?
Old 1st July 2009, 10:16 PM   #21
Sikh_soldier
sorry everyone I tried to clear up the confusion but ended up making it worse, however atleast we know that the word is not from a derrogatory word for people from a low caste (which is sad in itself) but means knife in certain languages/dialects
Bally
it would be funny if this catches on though, imagine ambiguous auction descriptions
"here we have a beautiful big knife, from somewhere not here, size is bigger than usual, hilt wider than normal, and colour strange but not peculiar"
