Old 31st December 2008, 09:25 PM   #1
Dajak
Dajak's Avatar
Default Seadajak Parang with rare scabbard
Seadajak Sword with old type Handle and rare scabbard .
Brass inlay on the back and the side .
Ben
ps Michael did you see an scabbard with that rare end ???
Old 1st January 2009, 11:05 AM   #2
Maurice
Maurice's Avatar
Hi Ben,
Happy new year!!
Great looking parang.
It is nice to see the similarities in style with this handle of yours to the higher Coppenshandle Michael has!
How old it was estimated you told me these handles were in fashion? (I can,t quite remember). I believed you told me about 1875?
Also nice carved scabbard!!
Maurice
Old 1st January 2009, 03:29 PM   #3
VVV
VVV's Avatar
Congratulations!
The best one of your newly acquired parang I have seen so far in 2009!
It's very close to the Jimpul I traded with your for the LT in style.
Actually I think it's a Jimpul variation even if the tip isn't squarish.
On the scabbard end I have never seen it before on anything else than Pandat (enclosed an example).
So I assume that it's inspired from the Land Dayaks in style?
Michael
Old 1st January 2009, 04:03 PM   #4
Happy New Year, interesting handle, the forming of the gunge around the top and the silver coin. What is the metal on the grip?
Old 1st January 2009, 05:41 PM   #5
Dajak
Dajak's Avatar
Originally Posted by VVV
Congratulations!
Michael
Hi Maurice that is correct .
Hi Michael maybe it is the other way around that is the way I like to find out.
I think that there are 2 variations off pandats that one type did belong to the seadayaks but I never did found any proof that this right or wrong .
You are right whit thinking that there must be a few variations of the Jimpul
type we know from the shelford publication .
I see to much of this type very old ones .
You have also a few maybe you can post them also here to compare .
Compare your Oldman and your Coppens both maybe same age different area
different style .
The metal on the Handle is not silver Tim but could be an mix .
Ben
Old 1st January 2009, 05:44 PM   #6
It could be tin? but most likely a local silver. Tin lead and silver?
Old 1st January 2009, 05:51 PM   #7
Dajak
Dajak's Avatar
Hi Tim no not tin it is more metal mix whit maybe a little silver but it is to strong to be silver and I put an boiled eg against it and no reaction so no much silver in it anyway .
The coins are silver from the netherlands .
Ben
Old 1st January 2009, 06:39 PM   #8
Well if not alloyed with silver. It is most likey a tin solder wire. Or possibly Britannia metal which is not that far removed from tin solder.
Old 1st January 2009, 07:24 PM   #9
Paktong.
Old 1st January 2009, 07:39 PM   #10
Ben
Hi Ben,
I didn't know this....am I right that the 'white' of the boiled egg changes colour when in contact with silver ? Can you 'gauge' the silver content by the speed of the 'reaction'.... is the colour change 'darker'... the higher the silver content ? Could you explain..Thank you
Regards and Happy New Year
Old 1st January 2009, 07:55 PM   #11
Dajak
Dajak's Avatar
Hi David
I use the yellow after the white and my expiriance is the faster and darker the more silver is in it try to eath an boiled eg with an silver spoon .
Ben
Old 1st January 2009, 07:58 PM   #12
Hi David
Ben
Thank you Ben
Old 1st January 2009, 08:10 PM   #13
Dajak
Dajak's Avatar
Is that the same as berlin silver
Ben
Old 1st January 2009, 08:50 PM   #14
Do you mean German Silver?
Old 2nd January 2009, 05:31 AM   #15
Dajak
Dajak's Avatar
Hi Jose yes I mean German silver overhere in Netherlands/Germany they call it Berlin silver.
I think the English call it alpacca but not sure .
Ben
Old 2nd January 2009, 09:23 AM   #16
VVV
VVV's Avatar
Hi Ben,
There are two styles of pandat but they are Sidin and Bennah according to Shelford (see examples in order).
The ones with the resembling scabbard end as your parang are Sidin.
So I assume that you suspect that it's the Sidin version that somehow is connected to Iban?
On jimpul variations I consider the following two jimpul too even if they don't have the squarish end of the blade.
Michael
Old 2nd January 2009, 11:23 AM   #17
asomotif
asomotif's Avatar
Found the following :
Alpaca / Berlin silver :
copper: 64 à 65 %
zinc: 23 à 24%
nickel: 12%
But I can imagine if it is locally made any combination of materials could be used.
best regards,
Willem
Old 3rd January 2009, 07:37 AM   #18
Dajak
Dajak's Avatar
My second Seadajak parang did get it yesterday.
It does have an heavy blade and little heads on the handle .
And very long hair from the handle .
Ben
Old 3rd January 2009, 12:24 PM   #19
Maurice
Maurice's Avatar
Hi Ben,
Nice example....
I have not often seen these kind of little faces on the handles. Also the carvings on the scabbard I do like.
Are those metal bands on the scabbard?
Maurice
Old 3rd January 2009, 03:33 PM   #20
Dajak
Dajak's Avatar
Hi Maurice yes metal bands .
Ben
Old 3rd January 2009, 04:42 PM   #21
VVV
VVV's Avatar
Another beauty!
Somehow this one doesn't look as much as a jimpul as your first.
Could be because of the krowit and that the fuller ends before it?
Maybe it's more related to the Gayang of W Sabah and NW Sarawak?
Ben, what's your instinctive feeling when holding it IRL?
Michael
Old 3rd January 2009, 05:17 PM   #22
Ben, you need to get that white metal tested properly. I have been thinking about your test, I could eat a boiled egg every day for a month and a silver spoon may still not tarnish. It does already look tarnished.
Old 3rd January 2009, 05:36 PM   #23
Dajak
Dajak's Avatar
Another beauty!
Michael
Hi Michael it is smaller but it is an heavy one .
In real it looks much better.
But first one is the best these 2 comes from the same collector has the best Parang Ilang collection that I know with the rarest piece s.
Ben
Old 3rd January 2009, 06:54 PM   #24
Mytribalworld
Mytribalworld's Avatar
Ben
Hi Ben,
here the pic I promised ( the one in the middle)
Arjan
Old 4th January 2009, 06:47 AM   #25
Dajak
Dajak's Avatar
Hi Arjan can you also show us what type off blade it is ?
that one down below is that also an seadajak parang ???
Thanks Ben
Old 4th January 2009, 01:53 PM   #26
Mytribalworld
Thanks Ben
Hi Ben,
No In my opinion the lower is a Dusun mandau from Kinabatingan area.
Arjan.
Old 4th January 2009, 03:01 PM   #27
Although this is not as curved and I know little about these really. I can see some similarities to the blade and the scabbard. Any more information would be very nice to know. This is my a favourite.
Old 4th January 2009, 06:01 PM   #28
Dajak
Dajak's Avatar
Originally Posted by mandaukudi
Hi Ben,
Arjan.
Nice blade that lower one I did ask because I see same style scabbard but with an
LT style blade in the scabbard after I left your nice shop .
Ben
Old 6th January 2009, 11:17 PM   #29
VVV
VVV's Avatar
Arjan, I am a bit puzzled with the hilt on the middle one?
Please let me know why it's Iban?
Is the lower one a Parang Gayang?
Tim, yours is nice too but I think you should post it in a separate thread as it's not related to the ones discussed in this thread. It's to confusing otherwise to comment it in relation to the other ones.
Michael
Old 7th January 2009, 08:46 AM   #30
Micheal I do not mean to confuse anybody, I am a bit confused that might be why I post it here. I like many others probably just see mandau. I just noted some similarity in the scabbard colour and binding also the blade. You guys seem to have all the answers?
