Old 3rd July 2008, 01:32 AM   #1
Bill M
Bill M's Avatar
Default Older Ivory Junggayan Kalis
Have provenance going back to acquisition by an American Brigadier General in 1898. He said it was "quite old" when he collected it. Note the diminutive ivory pommel about 5" long.
21 3/8" blade
9 shallow (siko) waves
Old 3rd July 2008, 03:23 AM   #2
Bill I was hoping you would share this with the forum. I like this one a lot with the ivory and the silver inlay. Provenance is so helpful thank you.
The silver near the top is embossed - something you don't see all that much on Moro pieces, never mind on Sulu pieces. Looks like the scabbard had a band near the top at some time.
A lovely piece - again thanks.
Old 9th July 2008, 08:14 AM   #3
VVV
VVV's Avatar
Fantastic Kris (as usual when you find something)!
Where was it collected?
Now and then I hear/read that brass or silver dots, like on this kris, indicates Borneo (probably based on the similar motif on the mandau blades).
I doubt this myself and think it's a multi-cultural motif.
So far I haven't seen it on any kris that has proven Borneo origin but...
Michael
Old 9th July 2008, 10:51 AM   #4
Ferguson
Ferguson's Avatar
Beautiful.
Steve
Old 9th July 2008, 07:32 PM   #5
Dajak
Dajak's Avatar
Could it be that the scabbard is put later on .
Ben
Old 9th July 2008, 09:34 PM   #6
The scabbard may be later, but the dot inlay are not just Borneo, but are on other PI/Moro pieces. I have seen these on barong, kris, and kampilan. It may be a regional thing, especially since there was lots of contact between Borneo and the Philippines for millenia.
Old 9th July 2008, 09:54 PM   #7
Bill M
Bill M's Avatar
Ben
Quite possible that it is not original for the kris, but my documentation shows this scabbard has been with this kris for over 100 years.
Old 10th July 2008, 12:39 AM   #8
I do think it is an old scabbard if it is not original - look at the place where a metal band was near the top.....Also the patina on the wood looks old as well as the style of carving is right.....
Old 13th July 2008, 04:07 PM   #9
Dajak
Dajak's Avatar
I see more use on the kris than on the scabbard that is why I ask .
And the rattan on the scabbard defnetily don't look 100 years old .
Bill can you make an pic off the kris in the scabbard from above.
Thanks Ben
Old 13th July 2008, 04:41 PM   #10
I don't know if this sheath is original to the kris, but it might have more age than first appears. It looks to me as if this sheath has been aggressively refurbished. So Ben, the rattan on the stem probably is not all that old, but the sheath itself might well be. I can see where Jose sees evidence of a missing band and i think the wood has been refinished.
Old 13th July 2008, 06:13 PM   #11
Dajak
Dajak's Avatar
Hi David the best off this can be see with an pic off the kris in the scabbard
and an close up from above .
It is an shame to refurbished an old scabbard I see this also a lot with very old javanese krissen with scabbards that are at least 300 years old .
Ben
Old 13th July 2008, 06:45 PM   #12
Ben, i am not necessarily arguing with your viewpoint, but if taken from the perspective i believe you might find from within the culture itself, it would be a great disrespect to the keris to allow it to live in an old beat-up wrongko. So if you are a Javanese man without the means to afford to commission a brand new wrongko, refurbishing the old one might be your best move. From the collector viewpoint we might like to see the wrongko in it's untouched condition, but as an owner from within the culture might have a different view. Of course we no doubt see many pieces refurbished strictly for sale to the collector community as well. That might well be the case with Bill's Moro kris here. Hard to say.
Old 13th July 2008, 07:28 PM   #13
Dajak
Dajak's Avatar
I look it at this way the kris that we are looking at is not from an person that has no money .
So the scabbard rebefurbished but was no need because he did have money,
the only thing I can come up with that it has loose his scabbard and an new one has been made for it . (nothing wrong with it )
An Javanese kris with gold on it did not belong to the common people some
javanese krissen had more than one scabbard .
Ben
Old 13th July 2008, 08:56 PM   #14
Ben
Ben, i don't think that we can necessarily assume that the owner of a keris or kris in their own cultural setting is well off simply because they own a weapon that has ivory of gold on it. As you know, these weapons are often passed down through generations. Just because someone's great, great grandpa was a member of court does not necessarily translate to present day wealth. That, unfortunately, is part of the reason why we see some of these very high end kris on the market now. They are being sold off by families that are in need of money more than their heritage.
Old 13th July 2008, 09:02 PM   #15
from what little reading i've found, moro kris and barong were meant to be used in battle, and the scabbards were generally discarded before or during battle and maybe picked up later, maybe not. they also tended to be held together by a few rattan bands such that the whole scabbarded sword could be swung at an enemy and on hitting, cutting thru the simple rattan bands, which caught many american and spanish by surprise just before they were cut in half. upshot is moro pieces might have many scabbards over a lifetime, with higher class pieces like this less likely to have their scabbard discarded and not picked up, so more likely to be repaired rather than replaced, but still more likely to be replaced than the original it was made with.
Old 13th July 2008, 09:22 PM   #16
The other problem is that some of these scabbards did not survive the tropical environment there or even the many changes in environment once they were brought over here to the United States.
Old 13th July 2008, 09:47 PM   #17
Dajak
Dajak's Avatar
Yes this happens but not the way you discribe if we speak about javanese
ones .
The most nice ones that are in europe are taken away by the soldiers long time ago .
Or they take a loan on the kris that they never could pay back and then it did get sold by the loanbank .
There was also in the Netherlands in 1981 an big action these krissen where bring in by An Javanese prins to sell overhere and where sold for big pices
but it was not that they where without money .
Auction april 27th - may 4th 1981 Paul Brandt in Amsterdam
name off cataloque the fascinating world of oriental art .
But the story did go that some these where not old or disputable so they where brought back to the auction house Paul Brandt .
Most off the common people did not have the money to get an kris and are not allowed to carry an high rank weapon this can be read in the historian books about Indonesia
The are even Batiks motifs that only can be carried by high rank persons .
So you are wrong if you say
that these weapons are often passed down through generations. Just because someone's great, great grandpa was a member of court does not necessarily translate to present day wealth and than sell it because they poor .
that this is the reason that they come on the market now .
Some old time kris collectors overhere passed away and the collction did get split up I have see that happend the last few years .
I have an friend that have some famous krissen in his collection that goes back to famous people of high rank and weddings gifts long time ago proven and a few out off this catalogue but the real old ones .
Ben
Old 13th July 2008, 10:23 PM   #18
ones .
I am not really talking about the nice ones that are in Europe. I am talking about keris that get sold in Jawa today.
Why would a Javanese prince bring a bunch of keris to the Netherlands to sell if it was not for the money?
Yes, the "common people" were not allowed to carry keris with certain high ranking features. But many people who were of a courtly status in old Jawa or Bali (and elsewhere i am sure) do not necessarily have high status positions in modern Indonesia. Just because your great grandfather was a courtesan does not ensure current financial stability. Yet you may well still have wealth in your family pusaka. It is not usually the first course of action, but i have heard of people giving up their family keris to make ends meet. It does happen.
"THE" reason...not necessarily...."A" reason...i stand by that.
Not every keris of worth that ends up on the market is already in some Dutch collection. There is quite a bit of dealings that take place in Jawa, between pusaka owners and Javanese collectors that we Westerners are never a part of.
Old 14th July 2008, 01:12 AM   #19
Bill M
Bill M's Avatar
David, It could have been that the Javanese prince got offended by someone Dutch and sold them poor keris as a joke on them.
Possibly he was mad at the auction house and was getting some kind of twisted revenge.
You know that Javanese nobility can be easily offended and have their own methods of "getting even."
But, maybe he did need money. Who knows?
But as David also said, it would be highly disprectful to a Javanese kris NOT to have new dress. But sometimes very high quality Javanese keris are in very plain, but well-made new dress. Like a beautiful woman in a simple black dress. But old-looking, patinated, dress to a Javanese old-school collector would be like having your wife in rags -- dirty rags.
Some of my best pieces, indeed my favorite, a Mataram Senopaten from the time of Sultan Agung (early 1600s) has very simple and plain recent dress.
Often fine Nihonto have a plain scabbard that holds the resting blade.
It is possible that the original scabbard got separated from this kris and this was made for a "resting place."
I have read that when a Moro commissioned a smith to make him a kris, he might ask for different things at the expense of others, ie, a very fine blade and a lesser hilt. One of the many things I like about PI Kris is the incredible diversity of these pieces.
I have some pictures for Ben, and though I did not exactly understand what he wants to see, I have made a couple of pictures.
It is unquestionable that this scabbard did have something just under the wrongko, but it looks more like it was rattan or possibly wire?
I used clamps to hold the scabbard halves together, perhaps I'll make a silver band.
Old 14th July 2008, 04:19 AM   #20
nacho
Default brother sword
This kris in my collection looks nearly identical to yours.
nacho is offline   Reply With Quote
Old 14th July 2008, 04:22 AM   #21
Dajak
Dajak's Avatar
Thanks Bill this looks like an nice old scabbard it is a shame that there is lak on it .
This would be for the krissen that stays overthere but don't forget that the Dutch people take krissen from there 300 years or more ago and they did not get an new dress overhere ,also other europian country's did get their museums loaded with a lot off these items .
Also the most knowledge about krissen was in europe by that time .
The most and the best krissen I bilieve are outside Indonesia . and an lot off fake are made by them now . (fake is new made kris sold for old)
I used to have an nice kris collection before I started my Borneo collection .
Rich Indonesian people are buying back their own stuff at the moment on important auctions in Europe
Ben
Old 14th July 2008, 04:48 AM   #22
Also the most knowledge about krissen was in europe by that time .The most and the best krissen I bilieve are outside Indonesia . and an lot off fake are made by them now . (fake is new made kris sold for old)
hmmm....i would still like to think that in spite of the fact that many Indonesians have turned away from keris due to the Westernization of their cullture, that the most knowledge about keris always was and is still does reside in Indonesia.
I also would not assume that the best keris are outside of Indonesia. While there is no doubt that many excellent keris were removed from the area years ago i am still fairly certain that a great many superb examples are kept as never-to-be-seen family pusaka or in the hands of Indonesian collectors that don't share their collections with the world at large.
Old 14th July 2008, 01:07 PM   #23
Bill M
Bill M's Avatar
But as David also said, it would be highly disrespectful to a Javanese kris NOT to have new dress. But sometimes very high quality Javanese keris are in very plain, but well-made new dress. Like a beautiful woman in a simple black dress. But old-looking, patinated, dress to a Javanese old-school collector would be like having your wife in rags -- dirty rags.
Ben
Hi Ben,
I would submit there is a big difference in a connoisseur Javanese collector and a Dutch or other kind of collector.
Most cultures like fine old dress.
Though we can't prove it, I agree with David that there are still a lot of great Javanese keris in Java. To a Javanese collector, keris are very private and not shared except one on one with a few close friends.
I still have a Javanese and Balinese collection, nearly as many as my Philippine collection but I don't post pictures.
I would imagine that there are a few really good Balinese keris being held by the Dutch that were picked up after the pupitan in Klungkung.
Old 14th July 2008, 03:04 PM   #24
Dajak
Dajak's Avatar
David tell me one old book Indonesian that make study about the kris
Something like J.E. Jasper en Mas pirngadie
Ben
Old 14th July 2008, 03:07 PM   #25
Dajak
Dajak's Avatar
[QUOTE=Bill Marsh]Hi Ben,
I don t say that there are not nice javanese kris in Indonesia only the most off them are spread about europe .
Old 14th July 2008, 03:55 PM   #26
Ben
Not all great knowledge is accumulated in books....not all knowledge in old books is correct....
Old 14th July 2008, 04:01 PM   #27
I think that you really have just no way of knowing what is held in private Javanese collections.
Now this might be more true about Bali, given the pupatans as Bill mentions. There the dutch got a hold of a good deal of the regalia keris, keris they promised to give back at one time, but then changed their minds and never did. Many of the keris that were scooped up after the pupatans where very high quality court keris given the very nature of what the pupatans were and who laid down their lives (and keris) in them.
Old 14th July 2008, 05:29 PM   #28
Dajak
Dajak's Avatar
David you don't now much about the Indonesian history how things did go 100 year s and more ago at Java otherwise you would not write this .
Ben
Old 14th July 2008, 07:04 PM   #29
Ben
Ben, i think you and i have side tracked this discussion on Bill's Moro keris much too much with talk of keris and Jawa. I would highly suggest that you start a thread on this in the keris forum where i will be more than willing to allow you to educate myself and others on how things went 100 years ago in Jawa.
Sorry Bill.
Let's talk more about this wonderful kris.
Old 14th July 2008, 09:10 PM   #30
Dajak
Dajak's Avatar
I agree
Ben
