Closed Thread
Old 1st July 2008, 07:31 AM   #181
baganing_balyan
Originally Posted by Nonoy Tan
Baganing Balyan, I wish that you will be able to conduct more research and then share with us linguistic evidence supported by historical, archaeological (I hope you did not forget this one) and DNA findings.
on yataghan:
the two sides of the handle's pommel are not just ears. They are actually heads of the turkish mythical bird, anka-- Turkish for phoenix-- this is also known as simurgh or senmurv, a persian (iranian) word. Turkey and Iran, genetically, share the same haplogroup, G.
The philippine's version of anka is sarimanok. In malay, angka means figure. In short, the pommel of yataghan is anka among the turks and angka among the malays.
Yataghan is from yate (gate) and gan (beginning). Yataghan is "beginning of the gate." This is not only about the duty of a warrior to guard a leader but also a folklore known in Islam.
The story goes that Sarimanok or anka was found by Muhammad in the seventh heaven. It is said to be the guard of heaven when the day of judgment comes.
In Roman Catholicism, the guard of heaven is St. peter who is depicted with a key and a rooster. I am still researching which influenced which.
Yataghan is also a symbolic sword in Islam. Suleiman the magnificent had a yataghan inlaid with jewels and gold. Ahmed Tekelu made it for him "as a weapon for the defender of the faith." (Our Sacred Signs by Ori Z. Soltes)
Even the use of kakataw from cockatoo is not really correct. I have no idea how kakataw and cockatoo as a word and an image became related to kris or kalis when the tausugs, maguindanaos, maranaos, etc. know that muhammad's phoenix (or rooster) is definitely bigger and holier.
Sarimanok would have been saribon in the philippines if its a tiny bird.
baganing_balyan is offline
Old 1st July 2008, 08:02 AM   #182
baganing_balyan
Ms. Baganing, I suggest you read my post, #24.
Herewith a quote from that post:-
The principal literary works in which we find these words are the Nagarakertagama (approx. 1360), the Nawatnatya(14th century), the Pararaton (approx. 16th century), then there are minor references in the Rajapatigundala, and the Sarwardharma.
In the Nawanatya there is frequent reference to the keris, and the words used to refer to it are "twek" and "curiga". Taking all the 14th century literary references, we find three words are used most frequently to refer to the keris:- curiga, which is purely a literary usage, and is used in reference to the keris when associated with royalty; twek, which seems to be the usage when applied to a military context, and kris (or keris) which is the most common usage and is applied to the keris when associated with the common man, or when the keris is used in a hunt.
In Pigeaud, Java in the Fourteenth Century, you will find the original texts, romanised, and a translation into English.
In Nawanatya, twek from tuwek, sanskrit for the sword's point, was used as a metaphor for men's masculinity. Twek is not a sword. It is where the filipino's tusok (thrust) from tuwok, a variation, came from.
There is no 'Keris" "kris" or "Kalis" in Nagarakertagama (1365). kuriga was used in that time period. It is from the sanskrit khadga that became kharga, then kuriga-- a C or a K is a matter of choice.
the word "keris" is in Pararaton. I don't wonder because the book was written in 16th century-- it is within my timeline.
When I am done, I will post about naga and kuriga as the father and the mother of keris, kris, or kalis.
Old 1st July 2008, 08:14 AM   #183
baganing_balyan
correction on my one blog post that keras was the source of keris. it is actually the opposite.
I just got hold of the genetic map this week; hence, i am pretty sure now that keris is from the turkish word kilich which in malay is kilis because ch is pronounced as s in malay languages. L and R are also interchangeably used such as arak and alak (wine).
Old 1st July 2008, 09:45 AM   #184
Alam Shah
Alam Shah's Avatar
Ms Baganing,
Regarding the DNA testing, how many people had been tested? From which ethnic groups? Would you share more details?
With migration of people since the 1600 and later... I'm just curious what can the DNA test prove? Let's take myself as an example, I'm a malay by birth, speak malay and brought up as one... but if a DNA test is done... What would be the result? My ancestors includes, from my father side, pakistan/indian influence, from my mother's side, malay, chinese, dutch influence. What will be the outcome and what will it prove?
Alam Shah is offline
Old 1st July 2008, 11:34 AM   #185
baganing_balyan
Originally Posted by Alam Shah
Ms Baganing,
They will find out your haplotype and the haplogroup where you belong. I am not a geneticist, but I can analyze the genetic data in relation to geographical peopling.
It's very technical and confusing to explain Y-DNA and mtDNA tests. I leave that to the geneticists to explain.
Y-DNA will tell you about the ancestor of your father. mtDNA will tell you where the ancestor of your mother came from. Now since you are multi-cultural, it would be a long work before you'll get the full picture.
it's like building a family tree but instead of names, you use haplotypes and haplogroups.
when it comes to research, I am not interested of a person's haplotype but his haplogroup.
For Instance I am interested to find out how many haplogroups present in sulu and compare if the same haplogroups are present in borneo and sumatra. If they are the same, it means, the migration pattern and the peopling are the same.
for example, philippines has rxr1, a haplogroup not seen in sumatra and borneo. Upon checking rxr1, the haplogroup that can be traced back to the cameroons of africa, I can then assume that indeed the theory about the early migration of the negritos (dark-skinned proto-filipinos) is indeed correct. As a matter of fact, we have african-looking ethno-linguistic groups in the philippines.
After knowing that rxr1 is non-existent in borneo and sumatra, you can infer a lot of things:
1) by using a world map, you can see that cameroon, southern India (dravidians), and Philippines are geogrpahically parallel to each other and they all have rxr1. The early migration must have missed sumatra and borneo. This also proves that dark-skined dravidians or tamils did reach the philippines in ancient times.
2) since australian aborigines have rxr1, where did it come from. It can't be from India since it had to pass sumatra and borneo. There are two possibilities: it must be direct from cameroon or from the philippines-- Southern Mindanao (davao Region) in particular. I won't wonder. there are aetas, dark-skinned groups, in the region.
So many possibilities. So many historical conventions to prove and disprove using the genetic map before 1500.
Old 1st July 2008, 12:17 PM   #186
Spunjer
Spunjer's Avatar
Originally Posted by Andrew
How've you been Ron? Have you got wet this summer? The swell off Hutchinson has been small, but consistent all month.
hehe, haven't really hit the water much this year, save for the artificial Flowrider. hopefully this winter. hawaii should be crankin' hard...
Spunjer is offline
Old 1st July 2008, 12:17 PM   #187
Ms. Baganing, may I most humbly suggest that you further your studies just a little in the Old Javanese language, and it usages.
It is true, the word "kris" does not occur in the Nag., however, the word "kinris" does occur, 54.2/4:-
tinumbak iniras kinris pjah tanpagap
"kinris" means "to stab with a keris"
the word "kinris" cannot exist in the absence of the word "kris", and the implement to which it refers.
There is no Old Javanese word "kuriga"; unfortunately you are thinking in English and attempting to understand Old Javanese.The word you are attempting to render is "curiga", for an English speaker, this would be pronounced "chewreegah", but to an English speaker the Javanese pronunciation would sound like "chewreegoh" .The word "kuriga", if it did exist, which it does not, would sound like "kooreegoh". The "c" and the "k" is most definitely not a matter of choice; these two letters represent quite different symbols in the original Javanese text.
I do understand your confusion in respect of "twek" and "tewek". This is hardly the place to educate you on your lack of understanding of the nature of the keris within the early and middle Javanese context, but you really do need to educate yourself.
In Old Jawa the keris was a symbol of the male, however, the word "twek" referred to a stabbing weapon, or more precisely when coupled with the name of a weapon it referred to that weapon as a stabbing implement. Tewek is also found associated with the word "lingis"---a crowbar.
Your interpretation of twek or tewek is incorrect.May I suggest that you spend a little time with Pigeaud and Zoetmulder?
Professor Zoetmulder seemed to hold the opinion that the word kris could be found in written works as far back as the tenth century.
I do find your ideas about middle eastern influence in the early Philippines to be interesting. You may have the germ of an idea here that when fully developed could provide us with new insights, however, when you stray into ideas and language associated with the early development of the keris, and the culture from which it came, you do impair your credibility.
I once again encourage you to continue your studies, but I equally encourage you to refrain from comment in respect of those things which you do not understand, or only partially understand. In time to come your errors could return to haunt you. Restrict your comments to those things of which you have a firm grasp.
A. G. Maisey is offline
Old 1st July 2008, 02:26 PM   #188
baganing_balyan
I suggest that you read the lines before and after "tinumbak iniras kinris pjah tanpagap" then translate them to English. Then understand the essence of the lines. "aris" is a malay word too for edge, so kinaris or kinris would also mean "put to edge or turn to edge." There is also a sanskrit word karis (to do). tamil also has kari or karis for sauce or soup. I am interested to know if the line you cut is actually about food.
I don't think the curiga with C that sounds like ch is correct.
That javanese word is obviously from the sanskrit khadga (sword) with an aspirated K. I have a hunch that the linguist who studied the old javanese could not pronounce the aspirated kh sound since it was/is a rare one, if he/she was european or american, so he/she used the ch sound which was/is linguistically common.
I stand by my analysis of twek-- in analyzing a word, to truly understand it, trace its origin and how it evolved into a new word. In this case, include sanskrit and malay languages in dealing with twek.
twek is not a sword. Its use is metaphorical for masculinity.
I am really interested of a native javanese studying her or his own language. French and German, if those were their linguistic nationalities, are just not equipped to mimic the sounds of sanskrit and old javanese.
I would love to read that tenth century text.
Thanks. I don't waste my time on something I don't know. when i say something, it's because i have a basis.
I will never refrain from rethinking and reconsidering the old works of the colonialists and orientalists.
ask an american or european if he can say an aspirated K with H. I bet either one will end up producing the ch sound. That my friend is the linguistic subtlety only native speakers can detect.
I am more confident of kuriga than curiga with ch sound because kuriga entered in the filipino languages as kuliga (poke or stick in).
Old 1st July 2008, 02:43 PM   #189
baganing_balyan
besides, if kuriga was curiga with ch sound, churiga would have evolved into suriga since ch in malay is turned into s. unfortunately there is no suriga in malay languages.
Old 1st July 2008, 02:49 PM   #190
RhysMichael
Originally Posted by baganing_balyan
The Philippine history says that the Islamization of Mindanao happened in late 1300's. I am really doubtful of that date. 14th century Moroccan traveler Ibn Batuta, a Islamic scholar, reported that he was attack by the Hindus along the coasts on his way to China from India. He indicated that he reached Sumatra. It is obvious that those Hindus who attacked him were from Java, Borneo, Sulawesi, and Mindanao. Those four places were within his route to China but he never stopped and visited those places.
I am not denying that there were already Arab traders and Missionaries in Majapahit empire, but their numbers were negligible. The sunni Islam of Sultanate of Demak that toppled the Majapahit empire in mid 16th century was actually from Southern India-- Kerala and Tamil Nadu-- established by the seljuk turks of the Ottoman empire who reached India in 14th century. There are Turkish Anatolian and Turkish Safavid inscriptions found in Tanjore (Tamil Nadu) and Thiruvarur (Kerala). (J. P. Mulliner. Rise of Islam in India. University of Leeds)
I believe the Sultanate of Demak, which was in the north coast of Java, was actually a Turkish state. Even the word "demak" came from "demek," the turkish word for "force." I think the use of 'Kilis" (from the Turkish kilich for sword) and later, "keris" started in north Java in the sixteenth century. This timeline fits within the date the word creese or kris entered the English vocabulary.
Nicholas Turling wrote about the Turks in Java and Aceh in his book, The Cambridge History of Southeast Asia. Yataghan as a 16th century Turkish weapon also fits within the time line-- middle of 1500's.
Another proof of the Turkish influence reaching as far as Mindanao is the word "arak" or "alak"--meaning, wine or liquor. It is not of sanskrit or tamil origin. araq is arabic for Juice and arak is turkish for wine or liquor. Using such etymologies, it is safe to say that the influence of the turks was more direct than the arabs.
So as I see it, yatagan indeed reached the malay archipelago in the middle of 16th century during the time of suleiman the magnificent of the ottoman empire that spearheaded the spread of Islam to the balkans, mediterranean, europe, and asia.
OK you have brought Aceh into the mix now, so I can speak on the timeline there a bit from and I hope it will help
Hindu and Buddist influence from India may have reached Aceh as early as the first century. sixth century A.D. Chinese chronicles. spoke of a kingdom on the northern tip of Sumatra named Po-Li. It is believed that Islam likely first entered the Indonesian archipelago through Aceh sometime between the 8th and 12th century. In 1292, Marco Polo, on his epic voyage from China visited Sumatra on his way to Persia and reported that in the northern part of the island there were at least six busy trading ports including Perlak, Samudera and lambri. In the middle of the 14th century, Pasai was invaded by Majapahit soldiers from Java
If you are interested there was an excellent conference on Aceh history inlcuding a paper on archeological sites of ancient trade cities that I can send you a link on
RhysMichael is offline
Old 1st July 2008, 03:31 PM   #191
Ms. Baganing, for somebody whose initial posts seemed to promise so much, I find it a great shame that you have reached this point.
You are well and truly out of your depth.
Nagarakertagama , canto 54 , stanza 2 reads:-
1. Staying behind were the wild boars, the black antelopes, the deer, the chevrotains, were the most excellent of them, continuously in fear.
2. The Illustrious Prince's proceeding was , having for consequence a horse, to follow them, noisily running.
3. Mandarins, headmen, clerical officers equally , the honoured ones who had their places with the horses, took part in the hunt.
4. Exterminated were the animals, thrusted , lanced, cut, krissed, dying without a gasp.(---tinumbak iniras kinris pjah tanpagap)
The line I quoted is in a part of the Nag. to do with a hunt. The translation is Pigeaud's, not mine.
Your knowledge of Javanese is non-existent. You tell us that you do not think that the romanised sound represented by "c" in Javanese is pronounced in a way that would approximate "ch" in the English language. You obviously have never heard Javanese spoken, and cannot read it.
Please spare us any more of your linguistic analyses. Indonesian is my second language, and in my home I use English, Javanese and Indonesian every day. If you wish to pass comment upon a language, please do yourself a favour, and learn that language first.
As to tewek.
I apologise for not providing you with complete information on this word. Had I done so you might have not made yourself appear so ridiculous.
In Old Javanese there are two meanings for the word tewek.
The first is to do with weapons, and I will return to that in a moment.
The second is a word that has an association with time, cause and origin; this meaning does not concern us here, so I will return to the first meaning.
The word tewek, also given as twek, and with tuhuk as a synonym, refers to a pointed weapon. Actually, it is sometimes difficult to determine exactly what weapon it does refer to, but when it is used, it is found in the context where it could be substituted with either keris or pedang, however, on other occasions it is found coupled with pedang or keris, indicating a way in which the pedang or keris is being used.When it is used alone, but it is followed by a verb indicating use of a keris, then clearly it refers to a keris in that context also.
The word atewek can mean to use a keris, or to stab oneself with a keris, or to have or use a stabbing weapon.
A panewek is a stabbing tool.
Atewek-tewekan means to stab repeatedly.
Your understanding of the word tewek is absolutely and utterly incorrect. You are wrong.
When you fail to take note of the work of Pigeaud and Zoetmulder, you make yourself appear to be an unlettered oaf, which I am quite certain you are not, but it does surprise, no, not surprise, amaze me, that any serious anthropologist working in a South East Asian culture could fail to be aware of the stature of these two giants.
Ms. Baganing, please do restrict yourself to comment on those things you may know something about.
It is clear that you know less than nothing about the Javanese culture, the Javanese language, and the Javanese keris.
Old 1st July 2008, 04:18 PM   #192
RhysMichael
on yataghan:
Interesting on the bird association with the yatagan, thank you for sharing that . Still I find the theory that the hilt on the Kris evolved from the yatagan tenuous at best (I find the hilt on a Nias Gari closer in profile than the yatagan to the the kris hilt you talk of, though I am in no way saying one of those evolved from the other just making note of a similarity in profile; the hilt on the Garis is a lasara head ) . If they did take the shape of the hilt from the yatagan why did they not incoporate any of the aspects of the blade ? I would find a more likely explanation that the bird motif is tied to Islamic docterine and symbology (or perhaps even earlier Judeo-Christian symbology) and both hilts evolved separately because of that. Birds are common in Aceh motifs. ( in fact I have often wondered if the hulu meucangge is supposed to symbolize a stork just as the hulu Gonjo does but thats way off the subject and just random thoughts) and the sumatran word for parrot I believe is kakaktua. The etymology is certainly interesting and deserves further study. Again I do not know that it ties the yatagan to the kris or if it just shows an influence on the language by the Otoman. Further study and proof would be needed. I can completely buy into the concept that the Ottoman had an influence on the culture and language I just need stronger proof before I would say the Kris hilt was derived from the yatagan
If you are looking for The Ottomans in Aceh a path towards the the Philippines the link below is a paper you may find interesting entitled
"Ottoman-Aceh Relations Accordingto the Turkish Sources"
Ismail Hakkı GÖKSOY
Suleyman Demirel University, Faculty of Theology,
Isparta, Turkey
Presented at First International Conference of Aceh and Indian Ocean Studies
24 – 27 February 2007
Here is the link http://www.ari.nus.edu.sg/docs/Aceh-...akkigoksoy.pdf
I hope it proves helpful
Old 1st July 2008, 05:46 PM   #193
I would just like to add a word about similarity of form. In the world there are just so many shapes. Every culture has a fascination and deep seated mythologies about birds. They are often used as motifs in all of these cultures and when stylized the similarities become even stronger. As a trained percussionist i have often marveled at the similarities between the ritual rhythms of various cultures spread all across the globe. I was recently noting a rhythm in some Indonesian music that sounds very much like one i know that originated in the Congo. There are, infact, root rhythms that transcend all cultures. This is not because these cultures have had contact with each other. It is merely the nature of things.
Someone just recently pointed out the pyamid at Candi Sukuh in Jawa to me. Let us compare it to the Mayan temple of Chichen Izza. So what do you think Baganing. Did the Mayans make their way to Jawa in the 15th century and influence the temple form at Candi Sukuh.
....of course, there is always my old favorite, the aliens from space theory...
David is offline
Old 1st July 2008, 07:04 PM   #194
Bill
Originally Posted by David
Someone just recently pointed out the at Candi Sukuh in Jawa to me. Let us compare it to the Mayan temple of Chichen Izza. So what do you think Baganing. Did the Mayans make their way to Jawa in the 15th century and influence the temple form at Candi Sukuh.
can't say I'm following this thread all that closely & it certainly has many directions but pyramids are interesting & if one wishes to spend some time with google, the Inca pyramids are the one you should start with. Then do some searches for Inca bronze weapons & compare the ax heads & spears with other artifacts in the world. interesting the Egyptians & the Inca both made the same mistake with the calender (no leap year) while it seems, with that exception, others were on the same page. It also appears a link of Inca DNA to some Pacific Islands but doesn't match current SE Asians although the pigs they brought with them link to Vietnamese pigs. I'd sure be interested if someone had some thoughts about the Inca & bronze.
Bill is offline
Old 1st July 2008, 07:52 PM   #195
baganing_balyan
Count the number of words in "tinumbak iniras kinris pjah tanpagap" and in "Exterminated were the animals, thrusted , lanced, cut, krissed, dying without a gasp." Isn't the latter too much? I know Nagarakertagama is a kakawin (epic poetry)-- maybe that's the reason why the translator was pretty lax in his translation. As i said there is a malay word aris, meaning edge. Since it is a hunting expedition, kinris or kinaris would also mean put or push to the edge.
If you read the four lines you posted, why would those hunters use krises while hunting when they were on horses. Tumbak (spear) is mentioned. Malay archipelago has a tradition of spear-hunting. Kris-hunting? mmmmm I don't think so. keris was and is not a hunting weapon.
Since your knowledge of javanese is existent, can you properly translate the four lines you posted? As i said, curiga came from khadga. Granting there is no research lapse in phonology, it is possible that aspirated Kh could evolve to ch sound or they were used interchangeably. we see such occurrence in chi and ki.
Since you know Bahasa Indonesia, is there a traditional word with ch sound? does ch become s in your second language? Is their churiga or even suriga? You check. I will listen.
As to tewek.
the javanese tewek is from sanskrit tuwek, meaning sword's point. Javanese is mostly Sanskrit and malay. Any weapon with sharp endpoint has a tuwek or twek. In current malay languages, there are words such as tuhuk, tuwuk, tuk, and the filipino tusok-- all are related to sharp point or stabbing. A tusok of a barbecue stick has no relation to kris. twek is part of the sword not a sword. it can also be a part of an arrow or spear.
It can also be used with spear, sharpened pencil, and yes, barbecue stick.
so is the pantusok. A ballpen can be a pantusok (for stabbing).
Tusuk-tusukan is the same thing.
mmmmm check the sanskrit tuwek and the other malay words with the same meaning-- sharp point.
Tell that to the postcolonial researchers.
You can attak me with ad hominems i will stick to the bigger picture of my research not to the tiny track where i see a crack. Now, that's a rhyme.
Old 1st July 2008, 08:05 PM   #196
baganing_balyan
In addition, y-chromosome haplogroup P is found in Java, south america, carribean, egypt, and other places where there are pyramids. It has been a well-established theory that pyramid builders in the ancient times were also sea-faring people.
Old 1st July 2008, 09:14 PM   #197
baganing_balyan
Ismail Hakkı GÖKSOY
Isparta, Turkey
Thanks for the link. I am primarily interested in the relationship between the turks and aceh in sixteenth century. Turling wrote about such relationship.
I have no doubt that Islamic arabs from middle east reached the malay archipelago, but dna mapping suggests that they did not last long for their haplogroups did not take root in the malay archipelago.
Maybe they are just traders or traveling missionaries or even ancient tourists like ibn batuta.
Early yatagans have no anka pommels, but the blades were inlaid with gold and jewels using anka motif. Later when the yatagans got anka pommels, the inlaid bird motifs, generally, could no longer be found on the blade.
the yatagan of suleiman the magnificent is the good example.
Old 1st July 2008, 09:53 PM   #198
Bill M
Bill M's Avatar
First, let me say that Alan Maisey has an incredible knowledge of Java. There is no doubt in my mind that his opinion and ideas regarding Java are correct! He has a depth of understanding that comes from over 40 years of in-depth research and understanding of this culture and their history. If he says it is so, then it is so.
Anyone who took the time to get to know him would understand this.
But in regard to the overall thread, PLEASE! There is enough acrimony in the world. Could we discuss the validity, or invalidity of these concepts and ideas, without personal attacks?
If a person makes a dumb statement, that is merely a dumb, or incorrect, statement. It does not necessarily mean the person is dumb, or incorrect all the way through.
So, could we just attack or defend the statements before the principal of this school closes the classroom? There are some good ideas here.
Bill M is offline
Old 1st July 2008, 10:08 PM   #199
hmmm....here's a definition of ad hominem:
An ad hominem argument, also known as argumentum ad hominem (Latin: "argument to the man", "argument against the man") consists of replying to an argument or factual claim by attacking or appealing to a characteristic or belief of the person making the argument or claim, rather than by addressing the substance of the argument or producing evidence against the claim.
Mr. Maisey both address the substance of your agrument (in great detail) and produces evidence. If you don't choose to agree with the argument that is one thing. But perhaps you should learn the meaning of ad hominem before you use it incorrectly again.
Sorry that you feel attacked by Mr. Maisey (and probably others including myself), but i believe you have brought this upon yourself. Personally i'm getting just a little bit frustrated with you myself. Constantly repeating your theories without providing any substance and refusing to address the numerous questions that have been asked of you will not gain you any points or friends around here. What is your agenda exactly? Obviously your theories are not being well received here. Do you intend to brow beat us into submission? I would think that any reasonable researcher would come to a forum like this looking for ideas to help in their research. Obviously you do not care for any of ours. You just want to preach your own. Their is literally hundreds of years of experience here. Mine is the very least of it. I admittedly no very little and am here to learn. Why are you here? Do realize that Mr. Maisey's experience alone with the keris spans more than 50 years....that he was also trained in the art of keris making by a well known and respected kraton empu who he apprenticed with for over 10 years. He has been emmersed in the culture of the keris and Jawa and Bali far longer than your existence on this Earth. What is your experience with the keris the or Moro kris or anything for that matter? Where and what have you studied? Who were your teachers? Why should i take your word for anything to do with the keris or Javanese language? Tell me and i will listen and consider. But you only continue to put forth a rambling and disjointed lecture with nothing more than the weakest of circumstantial evidence and ask us to buy into you theories without support or argument. Good luck with that!
David is offline
Old 1st July 2008, 10:08 PM   #200
baganing_balyan
I hope mr. maisey won't think that i am discrediting him. I am just offering alternative ideas.
for instance spear-hunting on a horse is pretty obvious that kris cannot be used. That's a valid idea.
I just don't think people in java long ago ran with the antelopes, deers, and wild boars wielding krises or kerises.
It is also possible that they speared them first then used the krises or kerises-- only if the animals were slaughtered in temples as sacrifices since temple swords are used even today in India for that purpose-- I just don't think keris or kris is a hunting sword.
spearing, cutting, stabbing an animal is so not an Indo-budhhist thing-- it is so anti-karma and dharma. that kind of hunting would be overkill.
I hear and read a lot about spear-hunting in malay archipelago but not kris-hunting.
Old 1st July 2008, 10:12 PM   #201
Looks like we were posting at the same time Bill. I'm just a little more long winded.
Actually, i would recommend to the "principal" that it is indeed time to close this particular classroom. I am afraid that this discussion is going no where good.
David is offline
Old 1st July 2008, 10:17 PM   #202
baganing_balyan
ask a philosopher or philologist if this is not an argumentum ad hominem:
"You are well and truly out of your depth."
to make that a statement about an idea not a person, he could have used "your ideas" not the personal "You".
don't tell me we have to spend time on argumentum ad hominem. I don't utter anything I don't know, or ain't interested to know.
Old 1st July 2008, 10:32 PM   #203
Andrew
Andrew's Avatar
Not going to happen.
Thread closed.
Andrew is offline
Closed Thread
