Old 5th April 2008, 02:57 AM   #31
I find this interesting too Jose. I can only see what looks like a plant in a vase, describing the kundalini or tree of life as Jens has described, however I know that the Moro keris focuses primarily on nagan symbolism. I was amazed to discover that while the serpentine blades represents the naga in motion...the straight blade also represents it...at rest.
Decorative motif, symbols, markings and stylized elements are very confusing in weapons and it truly is hard to determine where symbolism ends and pure motif begins. It seems that certain devices or stylized symbols, such as the squiggle 'S' on the dha, are often placed in repitition as motif that will imbue auspicious meaning in the weapon. Often we have seen ultra simple symbolism such as the three dots applied often only at key locations on a blade, sometimes at a fuller, sometimes separating certain features or other markings on the blade.
The talismanic properties with this application seem very much like those found often on European blades, with certain religious and occult symbols applied near blade elements, inscriptions and marks seemingly to accent or emphasize the potency intended in them.
All very complex, but this is what makes the weapons so incredibly fascinating!
Old 5th April 2008, 08:47 PM   #32
Yes Jim you are correct. Cato in Moro Swords mentions that the naga is a common motif used in especially kris. In fact the blade is the naga. The tree of life motif does not occur deliberately in Moro art. In Maranao Art you do not see this motif, but snakes (nagas) and other animals like crocodiles and birds are used, but only done using okir so that the image is not clear and traditionally conform to the edict in Islam not to make graven images. In the Philippines, Indonesia, and other parts of SE Asia the naga is a power symbol that is used. That is the purpose of a talisman - to empower the user/owner, and in the Philippines the naga and crocodile are such symbols and used on weaponry and cloth all over the southern Philippines (also see Textiles of the Southern Philippines). In the north on Luzon the imagery changes with the frog and lizard being talismans along with the naga (again a power symbol). I would have too look at my library to get the exact pages and other texts I am basing this on.
Old 5th April 2008, 11:38 PM   #33
Hi Jose,
Thank you so much for responding to my comments. These weapons are outside my regular fields of study, so I appreciate your explanation and detail on the symbolism and motif. The concepts seem very similar to those on the talismanic blades of Europe, at least in degree. I know your knowledge on these weapons is extensive, and while references are always nice for the general reading on the thread, they are not necessary for me to know your comments are right on target.
All very best regards,
Old 6th April 2008, 08:47 PM   #34
Jim you have a good point (like the one on my head ) and that is that talismans and talismanic marks are architypal (to use a Jungian term) and therefore many cultures across the planet use or have used them in some form or fashion. Often they are used to ward off not just misfortune or empower the ower, but for some (Indonesia/Malaysia/Philippines) the image, even symbolic, is enough to scare off (hopefully) evil spirits, etc. Another good example is in Bali the use of demon hilt figures to scare off other demons.
Old 7th April 2008, 06:28 AM   #35
Default Wagner
I just received a 1st copy of Eduard Wagner's book Cut and Thrust Weapons. What a huge volume, I didn't think I'd get it home on the tank of the bike. Whilst I am sitting here looking through it, I came across a chapter on this very subject. I don't think I will be able to manipulate my scanner to fit these pages but for those who have a copy on the shelf pages 67-77 are very interesting.
regards
Gav
Old 8th April 2008, 02:01 PM   #36
VVV
VVV's Avatar
Originally Posted by VVV
....Both the eyelash, crescent and dots are talismanic symbols to protect from the evil eye.
BUT usually there are either 5 (=fingers of the hand to blind the eye), a pair (=2 eyes) or one (a counter eye) dots?
Michael
Jens,
Having studied the evil eye some more I have found that the "male" triangle is a widespread symbol of an averting eye.
The crescent often represents either an eyebrow or an eyelid.
On you sword with 5 dots this could both represent 2 triangular eyes as well as the number 5 (fingers to blind the evil eye).
Your double crescent motif could be 4 eyes, at the corners, and one, non-visible, eye in the center.
Michael
Old 8th April 2008, 03:11 PM   #37
Jose, that point just means you're sharp! You're right on the talismanic images, and there are so many applications. One I distinctly remember many years ago was the rabbits foot. It was really popular to wear one of these, until one pillar of wisdom noted, " if thats for good luck, I guess it didnt work too good for the rabbit!".
Still, one cannot diminish the power of positive thinking, belief and faith. In the many forms applied, these markings represent these profoundly, and often help us not only understand, but to identify the provenances of many weapons.
It seems that the triangular geometric applied device is primarily found in the folk religions of North Africa that are nominally Muslim, though it also occurs in Afghan and Central Asian regions, and is known as the 'fibula'. This is indeed to ward off the 'evil eye'. These triangular devices are found as described in a book titled "The Afghan Amulet" (I think by Sheila Payne) and appear worn on clothing and textiles. In North Africa the best example is the triangular linear motif on the flyssa blade.
I am not aware of the triangle used in this sense in Indian weapons, particularly the Hindu forms. In checking Elgood's "Hindu Arms and Ritual" I did not find specific reference to the 'evil eye' ...perhaps I missed it somewhere?
Gav, excellent! You found a copy of Wagner.....extremely important reference, and yes it is huge!! When I loaded my copy into our RV my wife really groaned as I brought it in I had to convince her that I had left behind nearly a shelf of other books in its place.
Wagner is one of the few, actually probably the only, arms writer who has approached this very important esoterica in weapons, until Elgood that is!
Interesting observations Michael, the expression 'five in the eye' refers to the upheld hand with fingers splayed shielding from the evil eye, and as noted is termed 'fibula' (seems odd as one thinks of one of the two forearm bones).
Old 8th April 2008, 04:40 PM   #38
VVV
VVV's Avatar
...It seems that the triangular geometric applied device is primarily found in the folk religions of North Africa that are nominally Muslim, though it also occurs in Afghan and Central Asian regions, and is known as the 'fibula'. This is indeed to ward off the 'evil eye'. These triangular devices are found as described in a book titled "The Afghan Amulet" (I think by Sheila Payne) and appear worn on clothing and textiles. In North Africa the best example is the triangular linear motif on the flyssa blade. I am not aware of the triangle used in this sense in Indian weapons, particularly the Hindu forms. In checking Elgood's "Hindu Arms and Ritual" I did not find specific reference to the 'evil eye' ...perhaps I missed it somewhere?...
Jim,
Here is a quote from Westermarck 1933, Pagan Survivals in Mohammedan Civilisation, page 50 in the chapter The Evil Eye:
"The triangle, again, is used as an amulet in Mediterranean countries, Arabia and India."
Maybe someone else can find more info about it somewhere else?
Michael
Old 8th April 2008, 04:44 PM   #39
Jens Nordlunde
Jens Nordlunde's Avatar
Thank you Michael, it is very interesting, but also complicated.
A friend sent me the following link http://www.bhagavadgitausa.com/TILAKAM.htm which is huge, and so far I have not read it all, but it gives some interesting explanations. One of the problems is, that some of the symbols may have meant something if you believed in one religion, and something else if you believed in another religion, but many of the symbols on the blades were only used by one religion. But if captured, a good blade was still a good blade, and was used by the capturer.
Jens
Old 17th April 2008, 11:54 AM   #40
Royston
Question SYMBOLS ON A PARANG NABUR
This thread got me thinking about a Parang Nabur which has been hiding in a chest of drawers for the last 20 years ( Who has a house large enough to display everything ? ). I have just dug it out and photographed the symbols. Anyone seen these before ?
Old 17th April 2008, 04:19 PM   #41
VVV
VVV's Avatar
These are quite common on Malay weapons from south Borneo.
Yours is related to the Islamic magic square, wafq, where the numeric value of the arabic letters in all directions are the same.
This value represents a "hidden" name. Like the most common one is the Buduh (3 x 3) also known as Adam's seal.
The 4 x 4 is Plato's seal etc...
There is a lot of symbolism within the squares and by itself it also has baraka, "the Force".
Old 17th April 2008, 08:39 PM   #42
Nicely worded and concise comments on this Teodor. While I had known of the buduh, its concept was a bit unclear. Thank you for the info.
All the best,
Old 18th April 2008, 12:31 PM   #43
Royston
Default Symbols
Thanks for the information VVV. I now have some more reaserch to do.
Royston
