Old 14th March 2008, 05:18 PM   #1
eftihis
eftihis's Avatar
Default Shamshir with tugra or makers mark?
Hi, this an ordinary shamshir, with this sign on the blade. It looks like an ottoman tugra, but i have never seen a tugra before stamped on a blade. Could it be a makers mark? Has anyone seen something similar?
Old 14th March 2008, 06:00 PM   #2
ALEX
ALEX's Avatar
It does look like tughra (in my opinion it is of too cruel and rough quality to be a Sultan tughra). You're right, tughras usually stamped on silver fittings, not on blades. Blades can have chiselled or engraved tughras, but not stamped, so I think it is unusual to have stamped tughra on the blade. Of course, it can be a makers mark (It is propably Turkish or Egyptian). Another option is that someone just used tughra stamp/tool on the blade. I actually have a stamp of Sultan Mahmud II, and can stamp anything with it, not that I'd do such a thing:-)
Old 16th March 2008, 03:15 PM   #3
eftihis
eftihis's Avatar
Hallo Alex,
It is not easy to stamp a blade unless is red hot, so i guess this stamp was made at the time of manufacture. If it was to heat the blade in a latter period only at a specific area, i think it it would lose its temper. This one looks ok and the steel makes a nice clear sound.
I have seen in the past on ebay a seller from Bulgaria selling a tugra stamp!
Old 16th March 2008, 04:15 PM   #4
ALEX
ALEX's Avatar
Yes, it would be impossible to stamp heat treated blade without re-heating the metal. I think it's technically possible to apply / direct heat to a small local area of the blade and stamp it without affecting the structure of the blade as a whole. It'd be a delicate procedure (and the stamp tool itself had to be hardened !!!), so I agree - it had been likely done when the blade was made.
