Old 19th December 2007, 12:48 AM   #1
Default New Tulwar
Just arrived. I bought it on a "gut feeling" because it was covered with superficial rust. Gently cleaned, it revealed a very powerful mechanical damascus pattern. There is a stamp. What do you think? How much effort should I exert to polish and etch it?
Any idea about the stamp?
Old 19th December 2007, 02:41 AM   #2
Lew
Lew's Avatar
Ariel
600 grit wet dry paper and etch. You know it's not really a new tulwar
Lew
Old 20th December 2007, 06:21 PM   #3
Hi Ariel,
A pitty the stamp picture is not so accurate; not that i could decipher it ... by no means. But maybe others could ... while i could apreciate it and learn with it .
I notice the hilt is brass. Do you have the age of this piece estimated ... both hilt and blade ?
Thanks
Fernando
Old 22nd December 2007, 09:55 PM   #4
BBJW
BBJW's Avatar
The brass hilt is much newer. Beware of brass, but the blade I believe is old. There are so many fakes out there now that I prefer to see them in person.
bbjw
Old 23rd December 2007, 12:24 AM   #5
ALEX
ALEX's Avatar
Ariel, here is the picture of similarly shaped brass hilt of late 19th Cent.
Also, it is very nice of you, as an expert, to be asking us for advice on how to clean and etch the blade:-) It makes us feel a bit superior:-)
Old 23rd December 2007, 03:08 AM   #6
RSWORD
RSWORD's Avatar
Ariel,
Good snag. I noticed that one also and could see even from the poor pictures provided that the blade had a nice pattern welded blade. Also, I do not believe the hilt to be brass. Look closely. It appears to be an old gold leaf on a steel or iron hilt. I can see a bit of the leaf wearing out in spots. 19th century is the safest estimation of age but I wouldn't be surprised if it was late 18th century. Just a gut thing though.
Old 23rd December 2007, 03:45 AM   #7
I'm with you Rick on this tulwar, that hilt does look like gilt metal, which would likely correspond to this apparantly higher end blade. The stamp in the area seen here seems to be the location preferred for what appear to be these markings which I believe may be in Urdu. At least some of the tulwars I have seen with heavy blades were stamped in the same location which proved to be Urdu, and the blades were of late 18th century.
I think you're right on the blade BJ, and it would seem quite likely that a blade of this quality might be a heirloom and mounted with what appears a 19th century gilt metal hilt.
All best regards,
Old 23rd December 2007, 04:07 PM   #8
Thanks for the responses.
I was remiss in not mentioning that the hilt is NOT brass: it is iron with rather crudish gold paint. There are some traces of "gold" on the adhesive under the langets.
But the handle is iron, no argument here. The blade is superb: massive, no nicks, no damage at all and still fully sharp. I suspect it must be pretty old and not a regulation weapon :-)
Any more precise ideas about the mark?
