Old 10th November 2007, 08:22 PM   #1
Default Is this actually a Kindjal ?
I am not sure if this is an actual Kindjal .
To my limited knowledge, some usual characteristics are missing, though the general idea seems to be there.
The blade, not offset, is only 23 cms (9") long. The small grip looks horn, with some incisions. The buttons are iron.
Could it be this is a boy's piece ?
The gold inlay ( koftgari ?) in both sides is all practilally there.
The scabbard could be a replacement. I say this because i have never seen a kindjal with this type of scabbard, but i can see it is an old work, probably from the period. It is made of wood, covered with textile fabric and gold threaded yarn. The mouth in moulded brass tin, looks not so perfect. The tip is solid brass.
The whole set looks quite aged to me ... i wonder if XIX century or earlier.
Coments would be so much apreciated.
Thanks a lot in advance.
Fernando
Old 10th November 2007, 10:17 PM   #2
rand
rand's Avatar
Default Kindjal
Fernando
Looks very much like a kindjal to me and the designs looks Georgian. Am guessing this dagger late 19th or early 20th century and the decoration an embellishment later in this daggers use....
rand
Old 10th November 2007, 11:16 PM   #3
ward
with those rivets amd koftkagari 1920-1930 Northarn Iran
Old 11th November 2007, 04:16 PM   #4
Thank you Rand, for your coments.
Thank you Ward.
The way you put it, i take it that you have precise data on this type of specimens. I am completely blind about them, miself. Could you kindly indicate any material you have or i can spot, to follow the track you give ?
Thanks
Fernando
Old 11th November 2007, 04:45 PM   #5
ward
The style of the koftkagari along with the way the poor cross hatching is indicative of the late dating. regarding rivets I have handeled a number of these identical rivet types and they have also had iranian coins on them. Not a definate identification but seems right
Old 11th November 2007, 05:09 PM   #6
Allright Ward, i follow you.
Thanks a lot.
