Old 26th June 2007, 05:18 PM   #1
Oriental-Arms
Oriental-Arms's Avatar
Default The earliest sabers
The appearance date of the earliest sabers is vague and so far not finally fixed. It was common to think that the first sabers appeared on the 11 or 12 C. With time, more discoveries moves this date backward and today it is dated to the 9 or 10th C. and may be even earlier.
The saber shown below was excavated in Central Asia, together with a group of several others. As it was not a formal archeological excavation (very unfortunately) any dating or provenance is very speculative, but several experts that examined this blade tends to think it is 9th C. :
Blade length 42 inches, slightly curved, quite heavy and thick, about 10 mm at its base. The tip is double edged for 11 inches with a diamond cross section.
At the base of the blade there is a steel collar used to hold the blade well in the scabbard. The tang has three holes for the grip rivets.
I was lucky to acquire several blades of this lot, and I am glad to share this one with you.
Oriental-Arms is offline   Reply With Quote
Old 26th June 2007, 05:31 PM   #2
This is an outstanding blade!!! and if memory serves it would seem to correspond to Altaic sabres of the period you suggest. The angled tang (which becomes consistant in some Tatar sabres and the 'Mingrelian' shashkas among others) is seen on these 'Altaic' examples. I think there are good drawings of these in David Nicolle's work on the Mongols. The remains of the 'tunkou' at the blade root also seem consistant with these.
What an incredible find, and as noted, how unfortunate that more exacting provenance was lost,
It seems the remains of swords of this form were discussed a number of times over many years on these forums...can anybody help with the references in Nicolle (I think it is "the Mongol Warlords" that the drawings are in). I think the heading for the discussions here were 'Siberian sabre' ?
Very much looking forward to input on this as it appears an extremely important blade, and fascinating as the long standing and ever developing debates and discussions on the sabre form evolve.
Thank you again for sharing this blade!!!
All the best,
Old 26th June 2007, 06:29 PM   #3
very interesting, reminds me of my repro 9c magyar sabre:
similar shape, angled hilt and a semi-sharp upper edge at the tip for the 1st 10 in. this one is only 29in. blade, bronze guard and heavy bronze pommel tho. may help envision what yours looked like when it was new.....
Old 27th June 2007, 03:54 AM   #4
TVV
TVV's Avatar
An interesting hypothesis about the purpose of the collar is that it was used to accomodate for the grip in case an archer's finger was worn. Such rings were worn on the right hand's thumb and in a hurry, when taking the ring off was impossible, a normal grip would be quite uncomfortable, at least according to reenactors who have tried it in practice. To get a good grip in such a case, the easiest thing to put one's forefinger over the guard and in front of the so-called collar, the thumb with the ring lying on the guard. The collar serves to protect the forefinger from the edge. I do not know if this is true, but if you examine sabres with collars you will note that the collar is extended much further along the edge of the blade than on the spine, which seems to support this hypothesis.
As for the dating of sabres, there was a long thread in the forum a while ago. There are plenty of finds from the 9th century as deep into Europe as the Balkans and nowadays Hungary, which means they must have developped in Central Asia at least a century or two earlier.
Old 27th June 2007, 01:33 PM   #5
Jens Nordlunde
Jens Nordlunde's Avatar
Thank you for showing this rare blade. This made me remember another rare blade I have seen in Persian Steel by J. Allan and B. Gilmour, page 55. It is a slightly curved, single edged blade, 71.5 cm long, found in 9th century archaeological levels at Nishapur. Now at the MET. Here is a map – click to make it bigger http://www.metmuseum.org/TOAH/HD/nish/hd_nish.htm
At an excavation at Merv, where Ann Feuerbach participated, they excavated ingots, although they did not have any iron, it had to be imported, but Merv had at least two big plusses, it had a key position on the Silk Road, and it was an Arabian headquarters at the time. Have a look at the map showing some of the key towns on the Silk Road at the time, Herat, Nishapur, Merv, Bukhara and Samarqand.
Old 27th June 2007, 06:26 PM   #6
HorseNomad
Greetings Members,
I am new to the Forum but have been a student of early sabres for many years.
These blades have been found over a very large geographical area. I would say from the Danube to the Kirghiz region. If the blade in the photo has some hilt elements it will be possible to say more about dating and place of origin.
The collar at the blade base was probably there to keep the blade tight in the scabbard like a habaki on a Japanese blade. They appear on Chinese sabres also. It could be for resting the index finger but the weight of these blades, usually very heavy, doesn't imply that.
If anyone wants to see other types of steppe swords let me know, I can try to put up some photos.
Tim
HorseNomad is offline   Reply With Quote
Old 27th June 2007, 10:09 PM   #7
ham
Welcome to the Forum, Tim.
I, for one, would be interested in knowing more about early sabres, please do post some photos with descriptions.
Ham
Old 28th June 2007, 04:19 AM   #8
TVV
TVV's Avatar
Hello Tim,
I am glad you joined us, as I have always wanted to learn more about early sabres, because they are the weapon that has always fascinated me the most. No irony intended, I am serious. I like your suggestion that sabres should be classified according to hilt and blade characteristics, rather than the surrounding objects in the burial, because this latter approach does not take into account heirloom blades, that survived for centuries and trophies, which could have been taken from neighboring peoples.
The picture I have attached is from Varna's Archaeological Museum and the display features sabres and palashes found in nowadays North-Eastern Bulgaria. They are dated VIII-X centuries, which was South-Eastern Bulgaria back then, if the dating is correct. What would your comments on them be, with regards to dating, origin, etc.?
Thanks,
Teodor
Old 28th June 2007, 07:36 PM   #9
HorseNomad
Hello Teodor,
OK, let's see-- well, the first on the left is about right for 8 or 9 century, but not exclusively Bulgar. Second one can't say because of the flash. 3rd one crossguard and blade both look Bulgar 10 century give or take 100 yrs, 4th one is definitely later, probably 13 century and kind of an international form from the Caspian all the way to the Balkans. The last sword is definitely Golden Horde so 13-14 century.
The thing with these ancient sabres is condition. I personally avoid the really corroded or incomplete ones. If there's enough material intact to show details like the form of the guard and the cross-x of the blade, you can pretty well date them but that's kind of rare. And if you find ones that still have the pommel, that's just plain luck.
Tim
Old 29th June 2007, 01:27 AM   #10
Lee
Lee's Avatar
Lightbulb The Old Sword From Siberia Thread
Here is a link to the very first forum topic on this site, done even before forums software (we are now on the 3rd system)...
Old 29th June 2007, 06:21 AM   #11
TVV
TVV's Avatar
Originally Posted by HorseNomad
Hello Teodor,
Tim
Thanks Tim,
I appreciate your comments. According to an archaeologist, who published a catalogue of finds from the VII-Xth centuries in the territory of nowadays Bulgaria, the first three are palashes and the 2nd and 3rd he claims belong to a group associated with Bulgars and Khazars. The 4th one, he claims is Magyar, as it is similar to finds associated with the Magyars. I have to admit, to me it looks similar to the well known Charlemagne sabre, which is considered Magyar. For the last sword, I completely agree that it looks like a Golden Horde one.
I will try to post pictures of more finds from nowadays Bulgaria over the weekend. I am also looking forward to seeing as many other examples in this thread, because as I wrote, these early medieval sabres are my favorites, even if I know too little about them.
Teodor
Dr. Lee's example strikes me as amazingly well preserved.
Old 29th June 2007, 02:51 PM   #12
Thank you Lee for posting the 'Siberian sabre' which is exactly the one I was referring to!!!! What a great sword ... there were some excellent discussions back in those early days (seems so long ago!) and we've come a long way.
While there has ever been various levels of discussion and research on the development of the sabre, the theories remain of course inconclusive and some interesting ideas have been presented over the years.
I agree with Ham, I would like to see more on early sabres, such as those posted by Teodor!
I have always been under the impression that the curved sabre developed progressively from the standard straight swords as the dynamics of the slashing cut from horseback was better served by such the curving edge.It would be interesting to know of such 'proto-sabres' actually existed, possibly the idea began in the fashion of blade sharpening of straight swords on the earliest . It seems generally held that the sabre probably evolved with the movement of nomadic tribes westward from China, possibly in Turkistan.
It would be interesting to have this better explained and know more on the probable course of development of the curved sabre, and to see some examples (such as this excellent blade posted by Oriental Arms).
All best regards,
Old 29th June 2007, 04:50 PM   #13
Oriental-Arms
Default Another example from the same lot
Another one from the same lot:
Shorter blade 28 inches long 7 mm thick, quite heavy, with a clear thrusting spear shaped tip of diamond cross section and raised yelmen 6 inches long:
Tang with two holes and a short blade "colar" (Tunkou):
Old 29th June 2007, 09:36 PM   #14
HorseNomad
Hello Teodor,
It's hard to make a distinction between geographical locations and peoples in the Migration period, I think in terms of peoples for that reason.
The Magyars, Khazars, Bulgars and a bunch of other people were mixed up together but I guess it's easiest to say Magyar for the 4th sword in the pic since the Hungarian museums have a lot of similar swords.
The straight sword posted-- that is a nice old one from east of the Urals for sure. I remember it was online a few years ago, been way over cleaned. Whoever found it should have left it alone. Anybody know where it is now?
The last sword on the pics is a real nice one too, does it have the hilt parts? If so it would be great to see them. Will try to post one of mine that is complete.
Tim
Old 29th June 2007, 10:16 PM   #15
HorseNomad
Here's a sword from the same family with the hilt intact. It has a narrow groove running down the blade, you can see it up at the forte. Got lucky on this one, some original surface still on it 88 cm long, blade is 75 cm.
Tim
Old 30th June 2007, 02:57 AM   #16
TVV
TVV's Avatar
Lovely sword Tim,
I have blades from the 19th century in worse shape . Here are some more sabres from a catalogue of archaeological finds in what is now Bulgaria. The first are considered Bulgar and earlier, the second group are conidered Magyar and a little later, towards the Xth century. One of them I believe appears on the picture I posted:
Teodor
Old 30th June 2007, 04:56 PM   #17
Originally Posted by TVV
An interesting hypothesis about the purpose of the collar is that it was used to accomodate for the grip in case an archer's finger was worn. Such rings were worn on the right hand's thumb and in a hurry, when taking the ring off was impossible, a normal grip would be quite uncomfortable, at least according to reenactors who have tried it in practice. To get a good grip in such a case, the easiest thing to put one's forefinger over the guard and in front of the so-called collar, the thumb with the ring lying on the guard. The collar serves to protect the forefinger from the edge. ...
i've found that with my 9c magyar sabre it is more comfortable with the index finger below the guard and the side of the thumb resting on the side of the guard. with the index finger ahead of the guard it's a bit easier to carry but the ring hits the guard and gives a less secure feeling to my grip.
the 16th C. hungarian sabre however, the ring hits the languets wherever you put the forefinger, the thumb resting on the side of the languet and forefinger ahead of the guard seems the most comfortable, tho i'd want to get everything below the guard before i had to parry anything...and with the 16c sabre i'd rather not have the ring on at all. maybe a hard leather thumb patch on a shooting glove would do. may have to try that some time. of course by the 16th c. i wouldn't be a horsebowman....
as thumb rings vary alot in thickness and even shape, this opinion may not apply to other types of ring, i find the ring is fairly easy to rotate with the forefinger to get the working part out of the way, tho it's more difficult with a glove on.....
my bronze thumb ring:
not having access to a horse at the moment, this experimental archeology was done on foot, (and melon targets do not fight back very well either) so results may vary
p.s. - while neither of my repro sabres has the 'collar', the edge is deliberately unsharpened for the 1st two inches from the crossguard as i DO stick my forefinger there on occasion, just not with the archers ring on.
Old 1st July 2007, 03:48 AM   #18
ham
Nice complete example, Tim. Do you have others to share?
Ham
Old 1st July 2007, 05:52 PM   #19
HorseNomad
Hi Ham,
I do have others, too many in fact. Been collecting early swords for a long time now. Will post pics when I get a minute, got a teenage daughter around for the summer... nuff said.
Teodor those are some interesting swords especially the Bulgar one with the pommel. I have one sword similar but it was found way east of that area, it also has a tribal mark on it. Interesting that the pommel on that Bulgar sword isn't much different in shape than the one on my sabre in the pic above. Looks like there are 2 type pommels, this one with the dome top like a can of Coke somebody left in the sun too long and another one looks like a lightbulb, like on the Magyar swords in the next pic you posted. There is a lot of variation in the guards and blade profiles after the 10 century but the pommels don't change much at all.
Tim
Old 7th July 2007, 05:48 PM   #20
Kayahan
It all seems to have started with the canted hilt; it added valueable leverage to the straight, double-edged swords of steppe people. Inevitably, the edge to which the hilt was canted became the “primary cutting edge” in use. Then they started to shorten the “secondary cutting edge” where it had no practical use; in the beginning ¼ from the hilt was left unsharpened. When they realized that they could improve the cutting ability by giving a convex curvature to the blade, they further reduced it to ¼ from the tip and they come up with the earliest saber.
Is this a too short summary?
Kayahan is offline   Reply With Quote
Old 7th July 2007, 06:08 PM   #21
Not at all Odevan! the 'Readers Digest' version!!! Nicely said !
The development of the sabre from the historical perspective is not only complex, covering incredibly vast geography, but lengthy periods of time with varying peoples and civilizations. What you have observed would be the plausible dynamics of development, and well suggests the 'why' of its development.
I very much appreciate this thread and the great illustrations and observations on weapons not often discussed among collectors, obviously due to the scarcity of them. Thanks very much guys !!
All the best,
Old 30th July 2007, 09:33 PM   #22
ham
Tim,
Weren't you going to post images of further sabres??
Ham
Old 2nd August 2007, 02:12 AM   #23
HorseNomad
Well Ham, I'm going to do better than that.
My wife and I have decided it's time to sell off the collection.
I am going to have a website done up but will wait a couple weeks. If any of the forum mebers are interested I'll give them first refusal, everything goes and I will include all the info I have on each one. Just email me
Tim
