Old 16th April 2007, 07:03 PM   #1
galvano
galvano's Avatar
Default blade
hi
Two old blades.
Origin?
Your opinion.
Thank you.
galvano
galvano is offline   Reply With Quote
Old 16th April 2007, 10:29 PM   #2
The blades look like Palestinian Shibriyas. How big are they?
Very peculiar...
Old 16th April 2007, 11:00 PM   #3
galvano
galvano's Avatar
Default hello Ariel
Overall length 23 cm .
jordan ?
thank
galvano
Old 16th April 2007, 11:27 PM   #4
spiral
Jordan,Israel,Palestine,Syria type area.
Spiral
Old 16th April 2007, 11:30 PM   #5
I have seen blades very similar to these , I'm afraid there is a possibillity that these are from an agricultural cutting machine or similar (combine harvester ?) ...they also had the 3 rivet holes
Old 16th April 2007, 11:34 PM   #6
spiral
Any pix or links katana?
Spiral
Old 16th April 2007, 11:56 PM   #7
Hi Spiral,
I saw some similar to these at an auction....I thought they were unusual blades...because of the three 'fixing holes'. Luckily a 'farmer type' informed me they were 'cutters' from a farm machine.
I saw 3 'ethnic spearheads' on eBay, recently, with the same rivet hole pattern...but not with curved blades (long tapering triangle)....but these had remnants of green paint
I could be totally wrong about these....but the wear marks around the rivet holes suggests great force elongated the holes and ripped the rivets out....
Regards David
Old 17th April 2007, 01:13 AM   #8
Come to think of it, you might be right: there still is a big lug nut in one of the holes. Where is the handle it was attached to?
Old 23rd April 2007, 09:30 PM   #9
tom hyle
I'd really like to see these industrial/powered blades that are being discussed. THese look like shabrias; an awful lot like shabrias. The holes appear, BTW, to have been hand-punched, not drilled, and this is responsible for the ridgelike formation around them. Note the marks at the blade base of the one which still contains a rivet (? does not look like a bolt to me?), and its hand forged shoulders. The other seems to have a groove running out the end of its handle; trick of the light? Corrosion?
The cross-section seems to be flattened diamond with rather fine edges, judging from the damage?
Old 23rd April 2007, 10:05 PM   #10
Originally Posted by katana
.....a possibillity that these are from an agricultural cutting machine or similar (combine harvester ?) ...they also had the 3 rivet holes
Regards David
EDITED Sorry Tom I have just realised you were refering to a bolt mentioned in another post on this subject. The missing 'tang' appears to have been 'sheared' off .....a lot of force would be required to have done this...
