Old 5th March 2007, 08:44 PM   #1
Pukka Bundook
Default Should I etch?
This is the old Tulwar blade, shown in the "mend a blade?' thread.
(Has a crack in the spine)
Should I give it an etch?
Thanks in advance!
Richard.
Old 6th March 2007, 01:41 AM   #2
RSWORD
RSWORD's Avatar
This is a pattern welded blade and what is showing now is fairly indicitive of what would be brought out or enhanced, a sort of open distorted lamination. I think Jens is fond of this type of pattern. What you will probably see is some lamellar activity along the edge and spine and the central portion of the blade will be the open, distorted lamination like what you see. An etch may accentuate some heat treatment to the blade as well which would show in changes in color tone. The blade seems to be in good enough shape, ie, no pitting or heavy oxidation that it should be fairly easy to etch.
Old 6th March 2007, 03:41 AM   #3
Andrew
Andrew's Avatar
I'd say yes. That looks like a nice, "tight" pattern which should come up nicely, particularly if the features Rick predicts appear. Some pattern-welded Indian blades are rather unattractive when etched but, in my experience, those blades are not as fine looking as your's.
Old 6th March 2007, 01:37 PM   #4
Jens Nordlunde
Jens Nordlunde's Avatar
Pattern welded blades can be found in a big variation of patterns. Some of them should not be etched, but others I find very interesting, like the attached.
I would etch it to have a look, should the result not be as hoped for, it can always be removed again.
Old 6th March 2007, 01:40 PM   #5
Pukka Bundook
Thank you for your suggestions, RSword, and Andrew.
I'll give it a bash.
Will try and find a local source for 'Metal etch' (Canada.)
Thank you again,
Richard.
Jens, Your post popped up whilst I was answering the first two.
That is an amazing pattern on your blade! certainly would have been a shame to leave that one hidden!
Thanks for posting the picture.
Old 6th March 2007, 03:00 PM   #6
Gt Obach
Hi
now you decided to etch.
you could use white vinegar...it would take a little bit... (less time if heated)
- it'll look abit muddy... .. heres a tip... use some FINE pumice powder on a soft cotton pad..... and rub the oxide off... till you have a nice pattern...
you could do it with ferric chloride.. but shorten the etch time.. its can be very aggressive
remember... this will be a subtle patternweld ..... there won't be a bold look like steels with nickel in the mix... what your seeing here is mostly the weld boundaries in the steel... so try not to over etch...it'll only go so far
my self personally... i'd polish it a little bit higher... then a etch in dilute acid/and pumice rubb
but thats just me
Greg
Old 6th March 2007, 03:33 PM   #7
Jens Nordlunde
Hi Greg,
A good piece of advise, and what you write about the fine pumic powder is a very good piece of advise - seldom given, but good non the less.
Jens
Old 7th March 2007, 02:01 PM   #8
Pukka Bundook
Greg,
Thank you for the reccomendations.
Will find some pumice powder and try & follow your instructions..........
They Must be good if Jens agrees with you!
Thanks again,
R.
Old 7th March 2007, 03:56 PM   #9
Jens Nordlunde
Thanks for the kind words Richard, but when it comes to blades, Greg and a few others are specialists, and I am not, I am only doing what I have learned over the years.
Jens
Old 7th March 2007, 05:35 PM   #10
Gt Obach
welcome
i think everyone has a different idea of how a patternweld should look like.... some people like a heavily etch blade....so much so that you have topography...
- in other cases ... like in japanese blades... you can see the patterns but only due to the high level of polish...
although the etch and pumice works for a nice subtle pattern.... sort of inbetween..
i've used it in the past to bring out quench lines ... same process as above
here's the pumice i use... its something that Don Fogg posted on his forum a good while back.. ... and i've liked it ever since
take care
G
ps... almost forgot the link
http://www.leevalley.com/wood/page.a...at=1,190,43040
Old 8th March 2007, 06:27 AM   #11
Pukka Bundook
Thank you for the further information and link Greg,
I will 'phone them tomorrow for the fine pumice.
I will keep you posted on how I get on with it, (I have Way too many irons in the fire already!.........but this is so interesting I can't wait to get cracking at it!)
Thanks again,
Richard.
