Old 10th February 2007, 09:42 PM   #1
Default A PLUG BAYONET
Not necessarily an ethnographic piece ... depends on the perspective.
However presumptiously a nice piece.
Anyone care for an opinnion ?
Origin, Portugal or Spain ... or other ?
Age, XVIII or XIX century ?
Thanks in advance.
Old 11th February 2007, 06:39 AM   #2
Hi Fernando,
Ethnographic or not, I've always considered the plug bayonet a very intriguing edged weapon, and particularly those from Spain, which were likely the longest enduring in use. While as military weapons they of course became obsolete in the 18th century, as hunting arms they continued. Also, it was characteristic practice in Spain to use salvaged sword blades, much in the manner of dirks, to create these traditional weapons.
This being the case, it would appear that the mounts on this piece are relatively modern, and the blade does seem to have some age, probably early 19th century. The notched carving on the back of the blade would suggest that characteristic seen on many Andulusian examples, as well as the decorated brass ricasso plate also a favored feature (see "The Plug Bayonet", R.D.C. Evans, West Yorkshire, England, 2002, p.174).
Although these plug bayonets obviously are not able to be used in the intended manner in the barrels of more modern guns, they have gained status as a hunting weapon reminiscent of the traditional form, worn in hunting knife fashion.
Interesting piece Fernando, and an edged weapon form seldom discussed so glad to see it posted!
All the best,
Old 11th February 2007, 09:21 PM   #3
Hi Jim
Thank you so much for your comprehensive input.
All the best for you and yours.
Old 11th February 2007, 10:10 PM   #4
spiral
I dont know whether it helps , probably not,
but Handle looks like nice mediteranian grown evergreen oak. very hard & heavy.
Spiral
Old 12th February 2007, 12:41 AM   #5
You're very welcome Fernando, glad I could find info on this nice piece!
Spiral, thank you for adding that! I was actually wondering what type of wood that would be, and honestly know zero on this kind of data, which adds even more support to the attribution. Appreciate the input very much
All the best,
Old 12th February 2007, 03:17 AM   #6
spiral
Thankyou Jim, the medulary rays are quite identifiable realy, I have a spanish marking gauge & plane of the same timber, & have also cut & split for firewood a miss shaped one, Grown in Devon, England as a Victorean experiment for ship building timber. {It splits & warps to much when grown fast in rich wet English farmland soil.}
Spiral
Old 12th February 2007, 09:34 PM   #7
Thank you Spiral.
So its Azinheira ( Holm ) a variant of Carvalho ( Oak ).
I will follow that.
Kind regards
Old 13th February 2007, 03:35 AM   #8
The Double D
Has the handle on this bayonet been replaced? It just doesn't look right to me, to much taper
The Double D is offline   Reply With Quote
Old 13th February 2007, 08:14 PM   #9
It has already been observed above that the mountings are of a later date, although not necessarily ungenuine. To my humble view there is nothing wrong with the peened tang handle , as i see examples in the Net with a similar tapering.
Old 15th February 2007, 11:49 PM   #10
spiral
Originally Posted by fernando
Thank you Spiral.
I will follow that.
Kind regards
Indeed so Fernando! we call it Holm oak as well.
Spiral
Old 16th February 2007, 03:59 AM   #11
The Double D
I brought it up because the plug bayonets I have seen have a more parallel lower section to fit in the bore more solidly and snuggly.
Could this not be a plug bayonet but something else of the same family?
Old 16th February 2007, 10:16 PM   #12
It all makes sense, considering your previous posting. I have checked the woods used in naval architecture in the old days ( Portuguese discoveries ). Holm ( azinho ) was used in the small parts of ships skeletons. Very hard stuff. I also think i remember seeing this wood, full of vains, in carpenter planes.
Old 16th February 2007, 10:37 PM   #13
In the meantime i have managed to check with some more experts in this matter.
This being a plug or hunting bayonet, the spirit remains the same. It has a stylized handle all right, but still is consistent and within the family. It could be because, at a prior late stage, musket barrels became narrower, and at a further late stage the actual use on weapons pluging was dropped but the handle style prevailed in hunting bayonets, as also in a certain manner observed by Jim.
Old 17th February 2007, 03:04 AM   #14
The Double D
That makes a lot of sense Fernando...part of the evolution of the knife and its use.
