Old 6th February 2007, 01:41 PM   #1
Marcokeris
Marcokeris's Avatar
Default unusual gayaman
This Yogya gayaman is unusual: it is made by coconut wood and the result is rather good.
Old 6th February 2007, 03:40 PM   #2
Thumbs up Wow
I like it !!
A very nice effect with the end grain exposed.
Old 7th February 2007, 01:31 AM   #3
Newsteel
Newsteel's Avatar
That is rather unusual, not common. Normally coconut trunk were used for other purposes like musical instruments (rebana drum), part of the house, household items, decorations and etc.. but never for wrangka (or should I say, I've never seen it before). This 'pokka dot pattern' is obtained from the trunk near base area just above the root. This part is were the wood is the strongest.
Newsteel is offline   Reply With Quote
Old 7th February 2007, 02:58 AM   #4
BluErf
BluErf's Avatar
Ooh, I'm getting dizzy looking at it.
Old 7th February 2007, 05:36 AM   #5
Alam Shah
Alam Shah's Avatar
Unique and nice. Correct me if I'm wrong, the material is not a preferred wood for a wrangka. But nevertheless, in this case, its is nicely executed. I like it.
Based on my experience with similar material, in time, the whiter part of the wood would shrink a little and the blacker 'dots', being a stronger material would sort of 'protrude' a little, making the surface a bit rough to the touch. That is through use, but in this case it might take quite a while since it would not be subjected to daily use.
Old 7th February 2007, 12:31 PM   #6
Marcokeris
Marcokeris's Avatar
Newsteel:
thank you a lot for your comment about the kind of wood.
Alam:
The surface is really a little rough to the touch
Old 7th February 2007, 03:26 PM   #7
A novel use for this wood but by no means a classic material for the wrangka.
Old 7th February 2007, 06:16 PM   #8
BluErf
BluErf's Avatar
In Northern Malay kerises, though the coconut trunk would not be used to make any part of the sheath, the coconut itself could be used to make the buntut. Apparently, the coconut is chosen because it has a certain number of 'eyes', which has some mystical significance. I have 1 such keris. Will try to post some pictures.
Meanwhile, here's a ladle carved from a coconut. Carves surprisingly well.
