Old 3rd February 2007, 06:27 PM   #1
Default African Tribal Arm dagger .... possibly WW2 ?
Hi all,
bought this very cheaply...believing it to be 'tourist grade'. On receiving it, the very rusty blade was indeed thin (approx. 2mm) yet seemed highly tempered (with very little flex, with fairly sharp edges.)
Some wire wool and a little effort revealed a guality steel blade with the number '4' stamped on it (both sides of the blade and in the same place).
The blade under magnification shows file marks to shape the blade and possibily laminations in the metal structure.
The handle seems to be composed of horn or similar material, it feels 'plasticky' and is warm to the touch but the 'hot pin' test does not give that burnt plastic smell The creamy white 'rings' are some sort of hard plastic which has become age hardened and seems quite old. The 'pommel' is missing I have no idea whether the original was shaped like a Baja hilt or had the more familiar 'disc'.
The construction overall is 'good or better' quality. Where the blade came from...I have no idea.....but I am getting the notion that perhaps this was manufactured WW2 era. Perhaps a modified military blade. I don't think this was made from a machete because the blade is to thin (the stamped '4' either side suggests this was the original thickness)
If anyone has any ideas...or similar examples I would be grateful for your input.
Old 3rd February 2007, 11:21 PM   #2
Emanuel
Emanuel's Avatar
Hi David,
This arm dagger is very similar to my newest one. It also has what looks to be a four close to the ghard/hilt...but could also be pitting from inclusions. The scabbard on mine is near identical to yours. What are the dimensions? Mine has a 6"blade with a 3 3/4" handle. The blade seems to be of fair-good quality...it has some flex but it is strong...I'd have no problem stabbing, cutting and causing mayhem with it. Mine looks like it has been cut from a piece of steel and then ground and chiseled to a distal taper. These could very well have been machete blades to begin with...the Martindale variety used for the modern seme aren't much thicker.
Are you sure the white disks are plastic and not bone or ivory?
Emanuel
Old 4th February 2007, 02:29 AM   #3
Hi Emanuel,
thanks for the reply. The dimensions are very similar blade nearly 6 1/2" and handle without 'pommel' nearly 3 3/4". The blade is definately functional and the blade edges retained alot of sharpness even though they have not been 'dressed' for quite awhile. With a little 'honing' this blade would be a very sharp indeed.
As to the creamy white 'plastic'.....I think you are right.....after cleaning some more....I think they could be bone. Under a magnifying glass....looking down at the surface of the 'top ring', you can see areas of circular 'structures'. ( Similar to what you would see if you tied a number of bamboo canes in a bundle....and looked at them from one of the two ends.)
Actually....for some reason...I keep picking it up and handling it......even though it was cheap......it has something
Old 4th February 2007, 04:40 PM   #4
Emanuel
Emanuel's Avatar
I know what you mean, David...It's a funky little knife to hold. Perfect proportions I think, it just feels good to handle them. I also suspect they are quite devastating in experienced hands.
Old 4th February 2007, 05:32 PM   #5
Hi Emanuel,
I have a number of arm daggers some of which are late 19c / early 20c. (but no real 'status' quality).
Now that the 'plastic' issue is sorted..... I am not certain as to age....had it been the 'aged' plastic I originally thought... then WW2 seemed reasonable ( I have seen a number of WW2 artefacts with plastic parts that have the similarly aged look and colouration.)
If the blade is from a machete ( AFAIK a number of Masai Seme have Victorian/ Edwardian machete blades ) it could be dated early 20c or even earlier ( the bone is quite old and degraded.) Also bearing in mind that it was 'hand filed' to shape.
I am not certain...but the 'style' of the stamped '4' seems 'old fashioned' but cannot find any other examples (of this type set, to prove/disprove this)
I do feel that the sheath, although it fits the blade perfectly, is a later replacement, the arm loop seems older....so perhaps reused on a newer sheath.
One thing I am not certain about is whether the lower end of the sheath is strapped / tied to the arm (in conjunction with the 'loop' ) to stop the knife/ sheath moving around, similar to a 'diver's knife'......but attached to the arm.
I too like these knives.......I think Lew does aswell
Old 4th February 2007, 08:11 PM   #6
roanoa
roanoa's Avatar
Hi, Katana. Here is one of my daggers that seems to be identical (almost) to yours. Mine is ebony and ivory (?? perhaps bone?) The pommel/disk should be fairly easy to machine out of fossil ivory (lots of that around) Mine is 6.5mm thick and 46mm in diameter. I'll try to get a picture of the top showing concentrical rings cut with a lathe. I think these daggers pre-date WWII. Maybe 1930's?
Old 4th February 2007, 09:41 PM   #7
Hi Roanoa and thanks,
I agree ...the blade profile ..the handle are almost identical. I would like to 'repair' the pommel ..so it is appreciated that you gave the dimensions. The view of the top of the disc would be helpful I'm not certain as to the handle being horn/bone ...so ebony/ (ivory/bone) could still be a possibillity
I also wouldn't be surprised at the 1930's as a possible date either.
Old 5th February 2007, 06:05 AM   #8
Lew
Lew's Avatar
Here are a few from that crowded draw
Lew
Old 5th February 2007, 06:16 AM   #9
roanoa
roanoa's Avatar
Here's a picture of the top of the disk. The lathe work is easy to figure out. Hav fun.
Old 5th February 2007, 12:13 PM   #10
Lew
.....a few......my...what BIG drawers you Americans have In England we would call this lot ...a 'cupboard full' Nice collection Lew, I know you have some real quality ones
Thanks Roanoa, will definately try the 'repair' in the very near future....and post pics ....only, of course, if successful
Old 5th February 2007, 04:29 PM   #11
Emanuel
Emanuel's Avatar
Thumbs up :eek:
Lew
Sssssweeeeeetttt, Lew!! That's a foine drawer!!
Old 6th February 2007, 07:52 PM   #12
spiral
Roanoa, Its Elephant ivory, the Schreger lines are clearly visible on the end grain.
Nice daggers !
Spiral
Old 8th February 2007, 01:19 AM   #13
roanoa
roanoa's Avatar
Here are a couple of pictures of the writing on my dagger. The fish drawing is puzzling... but does not need a translation. I do need someone who can read Arabic to tell me about the rest. I can make out that one of the writing is a date. No idea about the rest. Help, anyone?
Old 8th February 2007, 06:04 AM   #14
roanoa
roanoa's Avatar
Guess all I had to do was to Google "Arabic Numbers" to find out that the date is 1945. So, that makes me think that it was probably sold in Karthum to soldiers going home after WWII wanting to take an African souvenir with them.
Old 9th February 2007, 09:09 PM   #15
I've been gently cleaning the handle of the dagger and have had a very nice surprise.....the 'creamy white' sections are IVORY There are Lines of Retzius visible (under magnification) on the top surface of the top section of the handle.
The Lines of Retzius....
These fine intersecting lines are visible in cross section, and give an engine-turned effect (intersecting lines with a diamond shape between them) which is unique to elephant ivory.
On Tim's 'rate of exchange' this cost me a little more than a 'fish supper'......and that included delivery
