Old 18th February 2005, 04:00 AM   #1
JPSF
JPSF's Avatar
Default unique patterned blade
This is one beautiful hanshee and Phil Tom is responsible for bringing out the pattern which was barely visible. Have any of you ever seen a pattern like this?
JPSF is offline   Reply With Quote
Old 18th February 2005, 08:44 AM   #2
Yannis
Yannis's Avatar
Amazing! How old is this beauty?
Old 18th February 2005, 03:32 PM   #3
Justin
Justin's Avatar
Gorgeous knife! The answer is NO I have not seen a pattern like that before,I havent even seen anything similar in modern custom knives much less on an antique,but if the smiths had the knowlewdge to make damascus at all then it would have been quite possible for them to have made any pattern they wanted.
I read about an English/American colonist who was a blacksmith in the 18th century and he did quite a bit of experimentation with making different damascus patterns. Supposedly he got to the point where he could produce billets with readable sentences and words in them......
Old 18th February 2005, 03:41 PM   #4
RSWORD
RSWORD's Avatar
Absolutely georgeous blade. The pattern welded effect looks quite deliberate and controlled. Is the blade a tripartite construction? There is a clear line of demarcation between the edge and the body. Perhaps a high carbon edge with softer cheeks sandwhiched around it? I have never seen anything just like it but the closest would be to some Indian pattern welded blades. Phil has some magical concoctions to bring out patterns doesn't he!
Old 18th February 2005, 03:44 PM   #5
tom hyle
Lovely; wonderful craftsmanship. Looks like pines and/or snowy, pointy mountains.
Old 18th February 2005, 05:26 PM   #6
Jens Nordlunde
Jens Nordlunde's Avatar
This quite fantastic and unusual, if not unique as I think it is. I must agree with the others who have posted – no I have never seen anything like it. How old is it? Thank you for posting.
Jens
Old 18th February 2005, 07:24 PM   #7
Ferguson
Ferguson's Avatar
My goodness. That is incredible.
Steve
Old 18th February 2005, 08:11 PM   #8
Conogre
Wow! That's an unbelievable combination of smithing and artistry, true painting with a forge and hammer.
I too would love to know the age and origin of the piece.
Mike
Old 18th February 2005, 08:21 PM   #9
Thumbs up Just beautiful John
Please tell us more about this piece and how you acquired it. Wonderful find.
Old 19th February 2005, 12:09 AM   #10
sirupate
Hello JPSF,
That really is a superb Hanshee, been trying to get blades made in that style in Nepal for several years now, but the Kami can't quite do it yet, just about got them to make good quality military models of the past, so there is hope yet
Simon, Tora Kukri Supplies www.toratoratora.co.uk
sirupate is offline   Reply With Quote
Old 19th February 2005, 01:33 AM   #11
JPSF
JPSF's Avatar
Details: a hanshee from c1770-1820, very well made dark red (once upon a time)velvet covered scabbard with beautifully chiselled and pierced silver chape and locket, elaborate sangli remarkable polished chandan grip, the kalti and its tinder pouch are decorated with silver thread.
17.5" o/a.
I didn't find it, it found me via a very good friend.
the whole rig
Old 19th February 2005, 03:17 AM   #12
Andrew
Andrew's Avatar
A very good friend, indeed, JP! Outstanding kuk. Thanks for sharing it with us.
Old 19th February 2005, 03:50 AM   #13
BSMStar
BSMStar's Avatar
Default Possible Meteoric.....
Looking at the pattern on this beautiful blade reminds me of a "lightly" forged Widmanstatten structure. Did Phil Tom use an acid blend like Aqua Regia (a mixture of hydrochloric acid and nitric acid) to bring out this pattern?
BSMStar
Old 19th February 2005, 03:53 AM   #14
LabanTayo
LabanTayo's Avatar
WOW!!!!!
beautiful piece. congrats and what a great friend.
LabanTayo is offline   Reply With Quote
Old 19th February 2005, 04:23 AM   #15
JPSF
JPSF's Avatar
I think Phil uses a very secret formula and techniques. If you ply him with demon rum at the EEWRS get together in a few weeks maybe he'll talk.
Yes, this is a very good friend but it doesn't mean that large amounts of cash weren't involved.
If you want to see more kukris you can check out www.kukris.net
The site has a long way to go, but it's a start.
Old 19th February 2005, 09:22 PM   #16
sirupate
JP is that the original scabbard?
Cheers Simon
Old 19th February 2005, 10:47 PM   #17
Mark
Mark's Avatar
Gorgeous. It goes without saying. As for the pattern, from looking at it I am going to venture a guess that it was made by braiding wire of two or more different types of steel, then bending it back and forth in a series of tight S curves and forging the whole thing together. You can see both the braided pattern, and the S turns near the eges. I know it sounds like it would be a very weak ingot, but I has seen some pretty damn amazing things done with pattern welding, notably by "Grandpa" Daryl Meier.
http://www.meiersteel.com/main.html
Old 20th February 2005, 02:38 AM   #18
tom hyle
The pattern may only be on the outside of a sandwich type blade?
Old 20th February 2005, 02:41 AM   #19
Mark
Mark's Avatar
Very good point. It does look at the edges like there is an homogenous inner layer.
Old 21st February 2005, 08:42 PM   #20
JPSF
JPSF's Avatar
Check with Philip Tom about the composition of the blade. He repolished it and knows a lot more about patterned steel than I do.
The scabbard is original as are the kalti, karda and chakmak. The sangli which is actually the carry belt has been restored.
Old 22nd February 2005, 08:01 AM   #21
Philip
Philip's Avatar
Default composition of blade
The blade consists of a homogenous, high-carbon center plate (which forms the cutting edge when exposed by grinding the V-shaped edge bevel) flanked on each side by "cheeks" of the pattern-welded laminate. I'm still trying to figure out how the alternative fern-leaf patterns were done. A previous post mentioned the likelihood that such a pattern might be susceptible to lateral stresses, compared to simple linear lamination. The beauty of sandwiching a hard steel core between laminates is that you get a lot of structural support, and are free to do wild patterns like this on the outer plates without fear of sacrificing strength.
This tripartite assembly is widely used in the Orient. It's called sanmai in Japanese, sanmei in Chinese. I've seen it on Moro campillions and krises, on mandaus, and so forth.
What the photos don't show on this hanshee is the heat treat details. When viewed from a particular angle, this blade has a slightly darkened zone along the edge, just over 1/2 in. wide at most. The smith heated up the edge portion in his forge, and then quenched it in water. The dark zone represents the crystallization of the steel into the molecular structure which makes the edge harder than the rest of the blade, which stays somewhat softer, avoiding the tendency towards brittleness.
Old 22nd February 2005, 10:31 AM   #22
tom hyle
My experience of kukuris, while limitted, is that they are differentially hardened in much this way.
