Old 13th August 2006, 09:13 PM   #1
Lew
Lew's Avatar
Default Long Somali Sword For Comment
Hi All
This just ended on ebay seems to be a nice one complete with scabbard
http://cgi.ebay.com/abbysinian-sword...QQcmdZViewItem
Lew
Old 13th August 2006, 09:20 PM   #2
Nice one!!!!!
Old 13th August 2006, 09:21 PM   #3
Flavio
Flavio's Avatar
Hello Lew, i'm looking at this too. Yeah, seems a very nice one, Congrats
Old 13th August 2006, 09:59 PM   #4
Congrats Lew, the pommel looks to be aluminium...but the blade IMHO looks to be older......perhaps re-hilted? Nice sword never the less....another one that should be in MY collection
Old 14th August 2006, 10:35 PM   #5
Valjhun
Valjhun's Avatar
Nice one Lew!
I would call it a Billao.
Old 15th August 2006, 02:33 PM   #6
CharlesS
CharlesS's Avatar
Nice one Lew, and to find complete with scabbard is no small feat! Congrats!
Old 24th August 2006, 04:20 AM   #7
Lew
Lew's Avatar
Default Somali Trio
Hi All
The Somali sword arrived today it's a real nice one and the scabbard is in great shape just a bit of the tip of the leather near the point is undone otherwise it is intact. Here it is with it's two other brothers.
Old 24th August 2006, 10:30 AM   #8
Flavio
Flavio's Avatar
A very beautiful piece, Lew!!! Congrats
Old 24th August 2006, 12:14 PM   #9
Very nice Lew,
the first sword ...is the pommel spike aluminium?
Old 24th August 2006, 01:21 PM   #10
Lew
Lew's Avatar
Originally Posted by katana
Very nice Lew,
I think it's aluminium but the steel tang is sandwiched into the spike some how I can see the steel coming out of the end of the spike.
Old 24th August 2006, 08:10 PM   #11
A great example very nice. The grey metal on these is zinc. I have one almost identical in size shape and scabbard. Another weapon that only seems to function in the thumb and forefinger grip.
Old 24th August 2006, 09:00 PM   #12
Lew
Lew's Avatar
Tim
Is this a 19th century or 20th century sword?
Lew
Old 24th August 2006, 09:08 PM   #13
Tim, .....Wow......zinc......Now that is significant
Zinc is used as a sacrifical anode..... when fixed /attached to iron or steel it helps PREVENT RUST. Due to electrolytic action the atoms of zinc 'sacrifice' themselves preventing the formation of iron oxide. The two metals have to be in contact. Lew mentioned the tang (iron/steel) passes through the pommel (zinc) therefor contact with each other is insured.
One question is ....was this effect 'learned' from outside Africa, or did they discover this themselves......or possibly...and highly unlikely (IMHO) that these two metals usage was just coincidental.
If this effect was known.....then you could summise that having a sword that 'does not rust' would be highly regarded ....perhaps even endowed with 'magical powers'.......bearing in mind the spiritual significance of blacksmiths and iron (in Africa) A substance that could 'protect' the revered iron..must have been seen as very 'powerful medicine'.
Old 24th August 2006, 09:27 PM   #14
Hi David,
I know nothing of the qualities of zinc that you mention. The blade of mine has had some rust. Zinc has been been used as a decorative white metal in the east for a very long time. People have a tendancy to think zinc is a modern western metal.
Old 24th August 2006, 09:48 PM   #15
Electrochemists to the rescue!
How would the presence of a zinc pommel with a tang passing through it affect the ability of oxygen to attack iron at the tip of the sword? Surely, zinc molecules do not travel along the blade. If this were so, why do we use time consuming and expensive zinc plating instead of just attaching a lump of zinc somewhere at the periphery?
Old 24th August 2006, 09:50 PM   #16
The 'sacrifical anode' effect is used on many maritime structures and ships ...Zinc primer (paint) has excellent rust preventative qualities. Zinc protects the iron by cathodic protection, since it is higher on the electrochemical scale than iron and will sacrifice itself to protect the iron, reducing it to the metal and eliminating rust. This phenomenon was noted by Faraday in 1829. If it sacrifices too much, however, the iron is exposed to oxidation, as is sometimes seen with old or damaged galvanized iron.
The purity of the zinc would be important and directly proportional to its effect.....the more pure..the more powerful. This power comes at a price... as its action is stronger (more reactive), it is quicker to be 'used up' and looses mass more rapidly.
If the pommel is pure zinc, it would be highly likely that the sword would have had the pommel replaced several times ...because over a period of time the pommel would have gradually 'melted away'.
I can only assume the pommel is a zinc alloy.... as Lew's and your example have clean, smooth pommels, showing little deteriation.
Africa, has very few mines and produces little zinc (globably).... Zinc would be in very short supply locally.......but the trade routes from India and the Arab states would have made it more accessable.
Hi Ariel, I'm suggesting that in certain climates, with high humidity, condensation forming on the blade would act as a carrier of ions between metals. The effect would most certainly be strongest at the point of contact.
I had a speedboat, the outboard motor made of aluminium, it had a zinc 'scarifial anode' shaped like a fin bolted to it (2 functions..1 item) This zinc 'fin' gradually 'wears' away as it sacrifies itself protecting the motor.
Trim Tab Kit BF25-BF50
Sacrificial anode metal protects the engine from corrosion.
3700952 - $13.59
Old 24th August 2006, 09:53 PM   #17
One has to be very careful about this zinc-aluminium thing. Some years ago I lost a very good kaskara because I was unaware of the use of zinc. Being badgered into believing the fittings were aluminium thus 20th cent, i let it go for peanuts. Once bitten twice shy. Dull it can look like aluminium, polished it can also pass as silver. So watch out!
Old 24th August 2006, 10:22 PM   #18
Thanks Tim, sounds like good advice
Old 24th August 2006, 11:07 PM   #19
Been checking the properties of zinc.....
Stability and Reactivity Comments:
Zinc metal is normally coated with a protective layer of zinc carbonate, which forms in air in the presence of carbon dioxide and moisture, resulting in a low corrosion rate.
On that basis both the pommels could indeed be ..a higher purity of Zinc ..because of the protective layer preventing the interaction of iron/zinc.
It would seem that the sacrifical anode effect can only occur when both metals are immersed in water, this ...quite likely...prevents the carbonate layer forming....leaving the more reactive zinc exposed.
So I have to conclude that even in humid conditions, the zinc pommel would have a carbonate layer develop, preventing the interaction with the iron/steel.
My theory would only work if you constantly used it underwater........
now.....did the African's invent the aqua-lung
Old 24th August 2006, 11:16 PM   #20
Lew
Lew's Avatar
Good point unfortunately Solmalia is mostly desert Unless these are used by Somali frogmen and these are their diving knives
Lew
Old 24th August 2006, 11:32 PM   #21
Lew
Are you sure theres no water?..... they do 'SURF' the dunes......
Old 25th August 2006, 12:41 AM   #22
Where is he hiding his Billao? Must be a really small one...
