Hi All,
My wife gave me this very nice 3 luk Bugis keris with its very well carved, ivory Java demam hilt and silver selut for my birthday. I have four questions about the sheath which appears to be fairly recent. I know that I will need to make a small modification to the throat in order for the blade to seat properly but the size of the wranka appears to be proportionate to the hilt. 1) Is the sheath (which appears to be Sulawesi) appropriate for a Sumatera hilt? 2) Even though the gandar is considerably longer than the blade, can I leave it as is? 3) If the gandar needs to be shortened, how short can I make it without it appearing too “stumpy” 4) I would like to replace the damaged buntut with something to match the hilt. Would camel bone be appropriate?. I have some ivory scraps that could work also but I would prefer to use bone. Sincerely, RobT |
Rob, before you start doing something, could you please post a picture of mouth of the sheath, blade sitting in it?
You have here a Malay hilt and Pendokok, and Malay sheath. Even if the sheath was not made for this blade, I wouldn't shorten it. There are a lot of sheaths ruined by collectors, who think sheath should match the length of blade, and blade shouldn't be visible when sitting in sheath. |
Gustav is correct Rob.
In times past Bugis & Malay & Balinese keris were often fitted to the scabbard with the gonjo visible. |
Hello Rob,
Like Gustav stated, you have a Malay keris, the handle will be from hippo ivory. And please don't shorten the gandar, it would be a great mistake. I would polish the scabbard with a good oil, it will look much better after this. And I wouldn't replace the little damaged buntut of the scabbard with bone of some sort, I would use ivory or wood instead. Regards, Detlef |
Gustav & A. G. Maisey,
Here are the pictures of the blade seated in the throat. As you can see, the aring side is an exact fit but there is a lot of room in front of the blade on the dagu side. Ordinarily, I wouldn’t be too bothered by the ganja sitting slightly proud of the wranka but in this case, the width of the of the blade just below the tang is slightly wider than the throat. This has made that area a pivot point so that the blade rocks back and forth like a teeter totter when seated. I think that widening that area by 1/64” (.0396875 mm) or less will allow the blade to seat solidly in the sheath. A light pass or two on each side of the throat with a fine cut riffler file should do the trick. I have enough woodworking experience to be confidant about doing this properly. Unfortunately, I don’t think there is anything to be done about the gap in front of the blade on the dagu side. Sajen, I am very happy that you and Gustav agree that the gandar should be left as is. I was very loath to cut it down in the first place and was only willing to do so if it were absolutely necessary. Since shortening the gandar is no longer needed, I think that repair of the existing buntut is preferable to replacement. Sincerely, RobT |
Yes, you are correct, it's not the original scabbard for the blade.
We often see keris fitted to a sheath that is not originally made for it. It is both common and acceptable. However, given the great gap in the fit here i have my doubts that this was anything that was done in culture for traditional use. Generally if that much of a gap was left after fitting a keris to an unrelated sheath it would be filled in some way to create a more acceptable fit. It seems more likely to me that the seller had a naked keris and a spare sheath and that he simply paired them for the sale. While i agree with Gustav that sheaths are not always meant to match the length of the blade, this keris appears to be a keris selit/sisip and if this is the case the sheath most definitely should match the blade length. These are small, secondary keris that are meant to be tucked into a waistband. As such they should be is much smaller dress that allows for this kind of wear.
The best solution would, of course, be to have a new sheath created for this keris, but i understand all too well how that is not really possible for collectors that live far outside the culture. My suggestion in this case would be that you don't alter the sheath length. If you were to replace the buntut i would chose the ivory material you have if you really want to match the hilt. You might consider trying to fill the space in the gap for a better blade fit. You could shape a wooden piece for that purpose. In some cases shellac has been used. |
Hello Rob,
Here are two pics from a Malay keris where the scabbard isn't original to the blade and someone, I guess in Malaysia, filled the gap with resin or like David said with shellac. Regards, Detlef |
David,
Thanks for your input. I agree with you and Sajen. There is no doubt that the sheath isn’t original to the blade. I’m just thankful that the style of the sheath is appropriate to the style of the hilt. I’m not too sure about this selit/sisip thing. In the example you show, the hilt and wranka of the smaller blade are noticeably smaller than those components on the full size keris. My hilt, when the blade is sheathed, looks proportionately correct for the wranka. Also, I eyeballed my selut against a number of Garuda hilted keris I have and it looks like it is large enough to fit them. In addition to this, I had to reseat the hilt because it was loose. The tang hole in the selut is certainly large enough for a full size keris, So, if the blade is for a selit/sisip, it was fitted with a full size hilt. Even though I think the sheath is fairly new, I was not at all keen about modifying it by shortening the gandar and since everybody (you included) that has commented on this has recommended against it, I will follow this good advice. Since I am not cutting down the gandar, there is no reason to replace the buntut. I think that, the more things that can be left as original, the better so I will just repair the damage to the existing buntut. The only other change I will make is to widen the sheath throat a hair so the blade seats properly and doesn’t wobble. Sajen, Thanks for the example. I could fairly easily fit a piece of wood to fill the gap on the dagu side of the blade. I don’t think I could match the tiger figure of the wood on my sheath but I’m pretty sure my efforts would look a bit better than the example you show. Do you think it would be acceptable to fit a contrasting material in that area (eg a piece of ebony or ivory)? Sincerely, RobT |
#10 | |
Yes, that's a job which can be done much better, just want to show how such a gap is filled up by some locals. ![]() I have had a repair done by a professional restorer here in Germany which is hardly visible, I tried to make pics of these but I need daylight for these pictures, I'll take them tomorrow and post them here. I wouldn't use such contrasting materials for such a repair/restoration, I personally would look for wood with a similar colour. Regards, Detlef |
Rob, my keris experience is very considerable where Jawa & Bali are concerned, it stretches over more than 60 years & is ongoing, however my field experience with Malaysia & other parts of Indonesia is very limited.
In Jawa & Bali the keris is a required part of formal dress, in both of these places it is not at all unusual for a small blade to be fitted to, or accommodated in, a full size scabbard. Nobody knows what the blade looks like when the keris is worn as an item of dress. Perhaps a similar approach to the wearing of a keris as an item of dress might apply in places other than just Jawa & Bali. |
Here is an example of a small Surakarta Pasupati fitted to a normal size Surakarta ladrangan wrongko.
Perfect for dress purposes, and nobody knows what the blade is like. Sorry for the sub-standard foto, pressed for time. |
Here are two examples where the sheath was professionally adapted to a blade. By both scabbards was a gap in front.
Rob, how long is the blade of your keris?
A. G. Maisey,
Thanks for those examples. If the folks in Java fit a full size hilt to a short blade to make the ensemble work with a full size sheath, I think it is reasonably likely that the practice is followed in other areas of the keris world. It’s the way I’m going, for sure. Sajen, I have already opened the sheath throat slightly to seat the blade so it no longer wobbles. As I thought it would, the aring side now fits very well so I have decided to carve a piece of wood to fill the gap on the dagu side. Your examples show me what to shoot for. Cutting the wood to fit isn’t really the problem. Color and figure (aka grain) matching the existing wood is where it gets dicey. Once the type of wood is selected, various staining methods can be tried out on scraps of the same wood. This narrows the odds a bit because you really only have one shot to get it right after the piece is cut to fit. It will take a while to get this project done but I’ll post the results when I finish. David, I can’t believe I neglected to give the blade length. It’s 8.5” (21.59 cm). Sincerely, RobT |
Here's an example of a keris fitted to a sarong. The gap has been lined and the blade properly fitted. In this case the filled area is dark and is not really jarring to the eye as the keris itself is a near color match.
Rick, the way in which your scabbard has been adapted for use is a style that some m'ranggis in Solo (Jawa Tengah) call "wayang" style, yours looks as it it has been done with some sort of compound, but the preferred way to do this is to enlarge the gap by about 1/8th of an inch, & then very neatly fit a wooden plug in a contrasting wood, this new wood is then inlet to take the new blade.
The end result --- when done well --- is pretty impressive. |
#18 | |
Well, the thing is this isn't just a "short keris". As far as i know there is not any evidence of patrem (small women's keris) in Malay culture. That is something you find in Jawa and Madura mostly. At 8.5" it is almost certainly intended as a keris selit. Again, i think it is more likely that this dress came together inorder to sell the keris, not as an ensemble that was intended to actually be worn in culture. Yes, perhaps the hilt seems somewhat OK with the size of the hilt. Perhaps it is not even the original hilt for that blade. I don't think this should change your plans for this keris in its current dress, but i am fairly sure this was once is a much smaller sheath and an may or may not have had a different hilt, though this current hilt doesn't really look too large for this blade and frankly does look just a bit too small for the current sheath. |
#19 |
This is an old and worn example of a sheath adjusted to fit a smaller blade.
#20 |
Rob, as I have said, my experience in locations other than Jawa/Bali is limited, by that I mean my field experience, and truly, form my own perspective that is really the experience that counts.
What applies in Jawa/Bali might apply elsewhere, or might not apply elsewhere, I do not know. However, in your situation, where you do not have access to craftsmen in SE Asia, you really do not have any options other than to fit this small blade neatly to the scabbard it is already in, it is best to leave that scabbard as it is, do not shorten, maybe just burnish and stain the chipped buntut, I would not replace it. As to proportions of hilts and anything else, again, from my perspective everything is fine just as it is, for now. At some point in the future you might come across other fittings that better suit this keris, but for right now it is best to just make the best of what you have, I did this for the first 20 or so years of my collecting life, before I had access to SE Asian craftsmen, & I learnt one hell of a lot along the way. |
#21 |
David,
There is no question that the sheath is not original to the blade and In my previous post I had mentioned the possibility that the hilt and selut weren’t either. Of course, you are far more knowledgeable about keris than I am but it’s funny how different people see things. To me, the hilt and selut look a tad too large for the blade but just right for the sheath. That’s not to say that the hilt wouldn’t still look good in the sheath if it were a bit larger but, as it stands, it’s a pretty whacking big chunk of ivory already. A. G. Maisey, I am following your recommendations exactly. As I mentioned in my last post, I have already widened the sheath throat (at best 1/64” on each side) so the blade seats fully without wobbling and aring side fits well. It took at most 30 minutes work making flight passes with a fine cut riffler and checking the blade for fit between strokes. I have cut the wooden plug for the dagu side and it fits well. Now comes the really hairy part, matching the color of the plug to the sheath. This will probably take about a week as I test various agents on pieces of scrap wood and wait for them to dry fully. The buntut has been covered with a rather opaque stain. I have examined the chip with a magnifying glass and it appears for all the world to be some sort of poplar. The bottom of the buntut (where the stain is less opaque) shows a figure like poplar also. Ideally, I would like to fit a wood piece to fill the chip but that looks like it might be tough to do. I’ll give it a shot but, if I fail, plastic wood will work. Sincerely, RobT |
#22 |
I grew up on hand tools, not electric, & for fitting a blade to a scabbard I prefer a scraper to remove excess material. The method is to smear fine oil onto the gonjo & scrape away the material that the oil leaves a mark on.
In real life, the keris that are worn by people in Bali & Jawa are often less than perfect in their dress, they get a bit knocked around, the wood gets scuffed & bruised, pendoks get dents, ordinary keris often look less than perfect. A chip such as the one to the buntut of your keris could most certainly be easily repaired, but my choice would be to leave as is and to make it look like old damage. If I felt compelled to repair that little chip, I would square the irregular surface of the chip to permit a tight, straight-line joint. Then paper off the entire buntut & hit it with black japan spirit based stain. I would use tinted 5 minute Araldite as the adhesive, make the patch oversize reshape and paper back. Araldite can be tinted with artists powder colour. I would not use plastic wood. Ever. |
#23 |
Hi All,
Here are photos of my efforts to modify the sheath throat and repair the buntut. Thanks to all for your advice about what and what not to do with the sheath. Sincerely, RobT |
#24 |
#25 |
#26 |
Sajen and David,
Thank you for your kind words and thanks again for the information and advice you have provided. I find the fit of the wood plug to be adequate but am not satisfied with the color match of my first effort. I am continuing to work on this aspect and seem to have been able to achieve some improvement. Hopefully, I will be able to get a better color match. Sincerely, RobT |
#27 |
Rob, for a first attempt at this sort of modification, I consider that you have done a pretty fair job.
However, if you are prepared to spend more time on the job --- as your remarks do seem to indicate --- I suggest that you have a look at Post 16 & Post 17. If you were to completely line the mouth with a contrasting wood, this would turn the minor defect of poor fit into an enhancement. Yes, it will take time & care, but it will look a lot better than just taking up the space in front of the gonjo with a piece of wood. I have found that the easiest way to do this job is to fit a plug of wood into the mouth of the wrongko first, I use tinted 5 minute Araldite as the adhesive. The mouth of the wrongko can be enlarged a bit first but be careful to follow the shape of the gonjo. After the new wood is in place and the adhesive has cured I drill a hole in the middle of the plug and line that hole up with the tang of the blade --- you place the blade onto the wrongko so that the gandar will accept it, & the top of the gonjo is level with the top of the wrongko (gambar, atasan). Then you just gradually enlarge to hole you have drilled to accept the gonjo, you smear light oil onto the sides of the gonjo & just scrape away where the oil shows on the new wooden plug. I prefer a dark wood for the plug, black ebony works well, but it is not all that easy to work with. |
#28 |
A. G. Maisey,
I am sure that your contrasting border solution would look far better than the wood plug but it would also significantly modify the sheath throat and that change couldn’t be undone. While it is true that I widened the throat slightly, it was by only .5mm or less on each side so I don’t think that small amount matters. I deliberately glued in the wood plug with a 50/50 mix of liquid hide glue and pine tar which is solid enough to hold the plug firmly but can also be fairly easily undone and is susceptible to heat from a heat gun should some future owner wish to undo my work. The only other change I made to the sheath was to repair the chip in the buntut with a piece of wood. That repair is permanent (I used zap-a-gap cyanoacrylate glue) but it is also invisible so no future owner would even know the repair was made. I’m pretty sure I could make the border but I’m not 100% certain. The wood for the border would have to be very solidly glued in place before carving out the center, or sections of the border could chip out during the work. If I made a mistake, getting the ruined piece out to start again would be a bear and might damage the wranka beyond repair. I’ll admit it, I’m a chicken. Sincerely, RobT |
#29 |
All understood Rob.
My objective was to make you aware of how premium repair of this type is done in Solo, Central Jawa, now & going back to at least the 1920's, of course different adhesive was used way back. Super-glue is not a satisfactory adhesive to use on a repair that we wish to last. Over time it tends to lose adhesion and come loose. How much time? I've seen it come loose in a couple of years, and within 20 years it often comes loose. The favourite brand of super-glue in Central Jawa is Alteco, & m'ranggis & dealers have been using it since the mid-1990's. They love it. I personally prefer button shellac where a weak joint is preferable & possible, & Araldite where a strong, permanent joint is required. Araldite will soften at about 70C and an Araldite joint will fail at about 130C. However, my preferred method if an Araldited wooden joint needs removal is to either carve it away, or pack the joint with moist cloths, the moisture penetrates the wood and after a few days the joint can be separated. |
#30 |
Here’s another scabbard that was modified on both ends to fit a smaller blade.
A Sulu scabbard😁 |
