Old 5th February 2026, 02:59 PM   #1
stekemest
stekemest's Avatar
Default Short spear, India/Indonesia?
Dear Forum, I need your help again – this short spear (?) comes from an old museum collection. I suspect it might be from India/Indonesia. Does anyone know anything more about it?
Thank you in advance.
Peter
stekemest is offline   Reply With Quote
Old 5th February 2026, 06:55 PM   #2
Hello Peter,
It's for sure not Indonesian, too crudely worked.
Old 5th February 2026, 07:34 PM   #3
To me the tip looks like an Indonesian spear. I had some very fancy worked metal spears of the same shape particulary at the base. I have no idea why this item almost looks like two picese put together. I am sure it is not. We have enough opinionated experts to pour cold water on anything new or unresearched. Hopefully we might see something similar in time.
Old 5th February 2026, 11:57 PM   #4
RobT
RobT's Avatar
Default Corrosion?
Hi All,
A rather odd piece. While the blade appears, as Sajen pointed out, to have been very crudely done, all the haft (or perhaps hilt) components look to be quite well done indeed. Also, while the blade doesn’t appear to be up to standard for an Indonesian piece, it is shaped like a tumbuk. Could this be a badly beaten up and corroded tumbuk blade with 1 luk at the base that meant enough to someone to have warranted a hilt made especially for it?
Sincerely,
RobT
Old 6th February 2026, 06:56 AM   #5
I would suggest cleaning the blade, polishing it back to bright, and seeing what's underneath the oxidation. Etching may help identify a pamor or lamination. I would not venture any comment until that is done. I'm leaning towards what Detlef has said.
Old 9th February 2026, 04:29 PM   #6
Could you show us a photo of the Metuk where the tang begins please.
Old 13th February 2026, 12:21 PM   #7
stekemest
stekemest's Avatar
Thank you for your opinions! I will try to make new photos next week.
