Old 18th January 2026, 10:55 PM   #1
Ed
Ed's Avatar
Default Cannon Projectiles I
12 Pounder Shell
Diameter = 4.625" (Nominal = 4.52”)
Wall thickness = 0.91”
Volume = 1 Cup (250ml) (inside volume: to base of fuse opening)
Weight = 8.75 lbs (Nominal = 8.34)
I had a fairly active interest in artillery at one time. This is a 12pdr. shell. A wood bung with a fuse inserted would be forced into the hole.
You can see the parting line from the molding process in the second picture.
It is a bit of a challenge teasing more than one photo out of a round hunk of metal. I hope you approve of my efforts.
I have looked for marks on this object but it is a bit of a Rorschach after staring at it for an extended period. Suffice it to say there is nothing glaringly obvious.
Ed is offline   Reply With Quote
Old 19th January 2026, 12:52 AM   #2
Question
Is that the Kings Broad Arrow I see?
Old 19th January 2026, 01:49 AM   #3
Ed
Ed's Avatar
Old 19th January 2026, 02:11 PM   #4
Will M
Will M's Avatar
here's a 24 pdr with broad arrow circ 1760 (dated by where found and historical accounts)
Old 21st January 2026, 01:06 PM   #5
Ed
Ed's Avatar
Dunno... maybe.
