Old 19th December 2025, 07:09 PM   #1
Triple Jack
Default Mau Mau Rebellion?
In my first post about the Jerzail Matchlock (incorrectly identified/named by me) I mentioned a couple of rifles. This one was gifted by the antique shop owner as part of the purchase. It was stated that there may have been a connection to the Mau Mau rebellion. To me this musket looks homemade and I have no idea if it was ever functional. I googled the rebellion and found out that many weapons where improvised. Could this be one of them?
To be honest I did not know what “Ethnographic” meant until I looked it up. I believe that this musket could fit into this category. If not please delete this post. I hope that you find the photographs interesting.
Cheers Jack
Triple Jack is offline   Reply With Quote
Old 20th December 2025, 05:20 AM   #2
RobT
RobT's Avatar
Default Archaic for Mau Mau
Triple Jack,
Here my impressions (again with the caveat that I’m no firearms expert). You have another cap lock here and it appears to be a muzzle loader. I can’t be sure about the muzzle loader part because the breach looks really, really odd. Since the Roland White cartridge patient expired on Dec 11, 1869 and the Mau Mau uprising happened 1920-1963, if the insurrectionists were using muzzle loading caplocks, they were sadly outgunned because the Brits were certainly armed with breach loading cartridge firearms. Your bore photo shows that your long gun is a smoothbore and, judging by the grip (with checkering on it), it began life as a sporting arm. I think that you should take your photos and any letters/serial numbers to a shotgun expert for ID. You should also ask about dismantling the gun so you can stop the live rust on the steel parts.
Sincerely,
RobT
Old 20th December 2025, 07:36 AM   #3
Quite possibly a Mau Mau gun but rather fancy. As I know little about guns and ammunition I am unsure how this gun would function. Many Mau Mau guns were very simple often having a door bolt as the firing mechanism, just ramming the bolt into the bullet. Very similar guns (Zip guns) are made by Solomon Island rascals local name for gangsters, criminals and so on.
https://www.iwm.org.uk/collections/item/object/30036466
https://www.rememuseum.org.uk/blog/c...mau-mau-pistol
Old 20th December 2025, 01:16 PM   #4
This is a most interesting topic, and honestly I do not think ever really brought up in all the years here, that of the Mau Mau rebellion and certainly not these incredibly fascinating ersatz guns.
For me most of the exposure to the curious term, like many people in my age group (really old) came from the novelty song of early 60's "Oom Papa ooo Mau Mau' and the term 'mau mau' used rather collectively in various cases. Probably from the British colonial slang term for the Kenyan fighters.
There does not appear to be any viable etymology for the rather derisively applied term, which was of course not used by the tribal groups involved in these uprisings leading up to the Mau Mau Rebellion (1952-60). This was but one of the many and constant struggles in colonial Africa, and while these were it seems constantly in the news in the 60s, it was hard to really understand what these were about for the average lay person, nor especially where these places were.
From what I read in the links Tim kindly added here, the mostly Kikuyu tribes among other tribal groups involved used these kinds of improvised and even imitation guns as symbols of rank and status, when actual serviceable weapons were unavailable. The suggestion that this was the case with many of the 'Mau Mau' tribal leaders would seem to elevate these rough, crudely assembled weapons to rather unique collectible status.
Indeed, there seems to be numbers of these types of tribal guns in the collections at National Army Museum in London.
It seems there are examples which fall into the popular term 'zip gun' type of crudely assembled guns innovatively created as mentioned by Tim.
Interestingly one of the key creators of many of these 'Mau Mau' guns was a self styled gunsmith who used the name "General Doctor Russia", rather a bizarre but catchy title, located in remote areas near Mt. Kenya foothills.
Examples of military type rifles with bolt action even with dummy magazines and pistols with open breech etc. are found in these groups of imitation and improvised guns.
As noted, this example posted by Jack seems to have been a sporting shotgun, which seems unusual as mostly double barrel versions were the norm. Also as such sporting guns were made by notable gun makers with ornate and signed locks, this crude assembly is entirely out of character.
The markings stamped into the stock are interesting, and it seems that there may have been some copying of 'official' issue type markings and numbers used in imitation of military guns with these improvisations.
Most interesting topic and example Jack! Thank you for posting this.
Rob and Tim thank you guys for your valuable input and Tim for the links.
I really enjoyed learning more on this topic, which really has my interest piqued now as an area I know even less about than guns!!! and that is most notable
All best regards
Old 20th December 2025, 02:42 PM   #5
Posted some time ago.
http://www.vikingsword.com/vb/showth...ight=home+made
Dangerous one shot, close up bang.
Old 20th December 2025, 10:47 PM   #6
RobT
RobT's Avatar
Default NYC Zip Guns
Tim Simmons,
Zip guns were rather common in New York when I was growing up and a door bolt firing pin was the ignition device of choice. Heavy duty rubber bands were used to propel the bolt forward when it was manually unlocked. The force was sufficient to set off the rimfire primer of a 22 short and send the round through the short section of pipe used as a barrel. I had heard that some enterprising individuals fitted the wooden stocks of these guns with a trigger attached to an external lever set-up that would release the bolt but that may have just been an urban legend. In any event, carrying these things around “cocked and locked” was as dangerous as all get out and only favored by those with more anger than sense. I wonder if NYC zip guns would qualify as ethnographic weapons?
Sincerely,
RobT
Old 21st December 2025, 07:25 AM   #7
A New York zip gun would be an ethnographic weapon.
Old 29th December 2025, 04:57 PM   #8
Richard G
This could well be a gun from the Mau Mau Uprising.
However degrading breech loading firearms to muzzle-loading black power was not uncommon in Africa, particularly W Africa, in the late 19th to mid 20th centuries in a quest for simplicty and economy.
Richard
Old 29th December 2025, 05:42 PM   #9
Another analogy concerning gun conversions in latter 19thc.
The ZULU shotguns were ex- French muskets from Franco-Prussian war were apparently converted in Belgium to smooth bore shotguns about 1885. Depending on which guns were used, these rifled barrels were bored out to either .12 GA or .16GA and the 'brand' name, as in those times used clever sensational terms ...used the word ZULU to capitalize on the Zulu Wars of 1877-79.
These shotguns became ubiquitous in the American west, in ranches and households and were marketed by retailers including Sears, Roebuck.
They had the 'Tabatiere' system of breech loading, so sort of a converse example, but the point is that gun conversions of sorts was apparently not uncommon, even in these contexts.
Old 5th January 2026, 12:43 AM   #10
Triple Jack
Hi all,
I hope that you all enjoyed the festive period and thanks for your interesting replies which have given me something to think about.
I will discuss with the owner and let you know what her intentions are.
Cheers Jack
