Old 18th November 2025, 03:29 PM   #1
Default A somewhat unusual faca de ponta for sharing
I won this faca de ponta recently at a German auction. It's a somewhat unusual example since it doesn't show the usual brass or with other metals plated ricasso, also the blade shape is a little bit unusual.
It's 35 cm long inside scabbard, 34 cm without, the blade is 23,2 cm long.
One picture shows it together with some other long facas from my collection.
Old 20th November 2025, 12:21 AM   #2
RobT
RobT's Avatar
Default They are Out There
Sajen,
Here are six more examples. The first one shown has a whopping 12.5” (31.75cm) blade and is double edged with a scarf weld close to the hilt. The rest of the examples are of typical length. I am not sure if the brass sheath for number four is original to the dagger but it fits well. Number 5 has a bit of an odd looking blade. We will most likely never know why some FDP have a ricasso cover and some don’t but I wonder if if isn’t due to different areas of manufacture.
Sincerely,
RobT
Old 20th November 2025, 09:44 AM   #3
Hello Rob,
Thank you for your comments! And you could be correct, I just may have not seen enough examples of the long version without the ricasso but after some research I found long examples without ricasso. And also it's possible that it's a regional distinction if they have a ricasso or not.
Funny was the original description from the auction house:
"Finnish puukko with birch bark/brass handle and leather sheath. Overall length: approx. 34.5 cm. Materials: Carbon steel; handle made of stacked birch bark discs with brass spacers and brass end cap (tang riveted/peened at the top); sewn leather sheath with belt loop. Identification, origin, dating: The design, handle construction (stacked birch bark with brass rings), and end cap with continuous tang are typical of Finnish puukkos (Kauhava/Lapland tradition). The technique and function of the birch bark handle are described precisely as such in specialist and dealer literature. The narrow, single-edged blade type with a short shoulder and no guard, along with the simple leather scabbard with a high-set belt loop, correspond to common 20th-century puukkos. Dating: based on workmanship, materials, and patina, circa 1930-1960 (mid-20th century), thus classic post-war/pre-war production. (Classification based on comparison to typical period mass-produced puukkos with a uniform age patina and localized rust/pitting; edge functional, refinishing possible. Handle firm; slight drying cracks between bark slices. Scabbard complete, heavily worn (seam and edge abrasion, seams partially open); overall authentic used condition.)"
Old 20th November 2025, 09:53 AM   #4
One of the original auction pictures. And the same view after it has received some TLC.
Old 21st November 2025, 06:51 PM   #5
RobT
RobT's Avatar
Default Not Just Funny
Sajen,
Re the auction house description: So well written, so comprehensive yet brief in scope, so authoritatively presented, and so entirely clueless. I have copied the description and will put it with my FDP. I would love to know the name of the auction house.
Sincerely,
RobT
Old 21st November 2025, 10:01 PM   #6
Lol, had the same thoughts when I read it the first time! Will pm you.
Old 22nd November 2025, 12:09 AM   #7
RobT
RobT's Avatar
Default Thanks for the Info
Sajen,
The ID has been added to the text.
Sincerely,
RobT
